3 Replies Latest reply on Apr 30, 2014 9:30 PM by A.T. Romano
    Jerky Play
    Speedybee
      I have Just Re-Installed Elements 11 into my PC and loaded AVCHD Files into a new project but It does not play in real time video is Jerky
        • 1. Re: Jerky Play
          nealeh Level 5
          Under Edit> Project Settings> General do the video and audio parameter match with the actual clip parameters (you can check with a utility like GSpot or MediaInfo) ? PRE does not always get it right when you first add your clip.
          In Expert mode is there an orange line running the length of your clip ? This is another sign that the project setting is wrong.
          Cheers,
          Neale
          If this post or another user's post resolves the original issue, please mark the posts as correct and/or helpful accordingly. This helps other users with similar trouble get answers to their questions quicker. Thanks.
          • 2. Re: Jerky Play
            Some other notes on Jerky or slow playback http://forums.adobe.com/thread/1071217
            • 3. Re: Jerky Play
              A.T. Romano Level 7
              Speedybee
              Did you reinstall Premiere Elements 11 as part of an uninstall/reinstall because the program was not working correctly? If so, what problems were you having before the uninstall/reinstall?
              Were these same AVCHD files importing and playing back OK on Premiere Elements 11 before the uninstall/reinstall?
              Please review the following blog post on problems that can be encountered by letting the program set the project preset for you automatically.
              http://www.atr935.blogspot.com/2013/04/pe11-accuracy-of-automatic-project.html
              Depending on your details, you may have to do a manual set of the project preset as described in the How To section of the link.
              But, let us explore the background information on your issue to make sure that we are not taking anything for granted.
              Thanks.
              ATR
