6 Replies Latest reply on Apr 30, 2014 9:16 AM by Trevorׅ
    How to get the response of a vbscript ran from extended js?
    Shadowfax Level 1
      Hi All,
      I  want to get the result from a vbscript, how to get that in my jsx? This is what I'm doing-
      vbscript (this will return me something, i've added just a sample string)
      Wscript.Echo "Like this?"
      jsx
       var a = File("C:\\Users\\Sahil\\AppData\\Roaming\\CreativeWorx\\1.vbs");
       var b=a.execute();
      Now, variable b returns me true/false; and the output i.e. "Like this?"  is alerted! So my question is-
      1. How to get the output in a variable?
      2. How to avoid the alert
      So, I simply wish to get the output from my vbscript and then perform certain functions accordingly, alos, I dont want  this to be alerted!
      Any help will be highly appreciated!
        • 1. Re: How to get the response of a vbscript ran from extended js?
          Trevorׅ Adobe Community Professional
          Hi Shadow fax,
          Use scriptArgs and doScript
          var VBScript = 'app.scriptArgs.SetValue "myResult", "Like This"';
          app.doScript(VBScript, ScriptLanguage.visualBasic);
          alert(app.scriptArgs.getValue("myResult"));
          Trevor
          Message was edited by: Trevorׅ P.s. I didn't read what you read about the alert stuff but HTH anyway
          • 2. Re: How to get the response of a vbscript ran from extended js?
            Shadowfax Level 1
            @Travor, thanks for your reply
            I forgot to mention in the question but, this script is for Windows. And I guess, doscript is for Macintosh right?
            If I'm right, how could I get the output of vbscript back in my extendscript?
            • 3. Re: How to get the response of a vbscript ran from extended js?
              Wrong, doScript is for both Mac and Windows
              So it should work for you
              Give it a go
              • 4. Re: How to get the response of a vbscript ran from extended js?
                Shadowfax Level 1
                @Trevor, Thanks again, but it says method not found "app.doScript"
                Another thing- my vbscript actually returns the network's mac address, so your method will work with this right?
                This will be my vbscript-
                dim WMI:  set WMI = GetObject("winmgmts:\\.\root\cimv2")
                dim Nads: set Nads = WMI.ExecQuery("Select * from Win32_NetworkAdapter where physicaladapter=true")
                dim nad
                for each Nad in Nads
                if not isnull(Nad.MACAddress) then Wscript.Echo Nad.description, Nad.MACAddress
                next
                • 5. Re: How to get the response of a vbscript ran from extended js?
                  The capitalization is app.doScript and not app.doscript that is if you are trying to get a jsx script to run and access a string from from a vbs script.
                  When defining the VBscript for multiline scripts the easiest method is to use triple quotes
                  VBscript = """dim WMI:  set WMI = GetObject("winmgmts:\\.\root\cimv2")
                  dim nad
                  next"""
                  when using the scriptArgs you can either make a loop of them and send the string value of each one something like this
                  For (n = 0 .........
                  myArg = "myArg" & n
                  myStringToPassOver = "Shaddow Fax " & n
                  app.scriptArgs.SetValue myArg, myStringToPassOver
                  Next
                  or probably better to make a long comma or something else separated string and pass it over after the loop
                  var VBScript = """myArg = ""
                  For n = 0 To 15
                  myArg = myArg & "Shaddow Fax " & n & ","
                  Next
                  app.scriptArgs.SetValue "myResult", myArg
                  var myResult = app.scriptArgs.getValue("myResult").replace(/\,$/,"").split(",");
                  // if neaded use "replace" to remove final "," and "split" to convert into an array
                  alert(myResult.join("\r")); // alert the array
                  The above script is a jsx script that runs a vbs
                  If you want a vbs script to run and access a string from from a jsx script then you would use xxx.DoScript see the sample from the manual below.
                  Set myInDesign = CreateObject("InDesign.Application")
                  myJavaScript = "alert(""First argument: "" + arguments[0] + ""\rSecond argument: "" +
                  arguments[1]);"
                  myInDesign.DoScript myJavaScript, idScriptLanguage.idJavascript, Array("Hello from
                  DoScript", "Your message here.")
                  myVBScript = "msgbox arguments(1), vbOKOnly, ""First argument: "" & arguments(0)"
                  myInDesign.DoScript myVBScript, idScriptLanguage.idVisualBasic, Array("Hello from
                  P.s.Please mark the question as answered, thanks
                  • 6. Re: How to get the response of a vbscript ran from extended js?
                    P.s.
                    Although I quite possibly make it into the worlds top 2 billion vb programmers I can't help you with your specific script which is trying to get the network mac address.
