11 Replies Latest reply on May 4, 2014 7:07 AM by kglad
    Help!! Setting "body" for enemy in shooter!!
    Leonyipa
      I tried some code for my enemyShooter's hitTest and it worked.
       if (_root.enemyShooter.body.hitTest(_root.ship.body)) {...}
      (enemyShooter is the instance name of movieclip)
      However, this doesn't work.
      var name = _name
       if (_root.name.body.hitTest(_root.ship.body)) {...}
      The reason I am doing this is because there are many enemies like enemyShip1, enemyShip2, enemyShip3.
      The name if it is set by
       "EnemyShip" + _root.getNextHighestDepth()
      because I use
       _root.attachMovie("EnemyShip", "EnemyShip" + _root.getNextHighestDepth(), _root.getNextHighestDepth());
      I cannot find the instance name unless using _name
      How can I make it work?
        • 1. Re: Help!! Setting "body" for enemy in shooter!!
          in most situations it's best to store those enemy references in an array and loop through the array especially if you're sometimes removing enemies and they no longer need to be checked for a hittest (or anything else).
          • 2. Re: Help!! Setting "body" for enemy in shooter!!
            Leonyipa Level 1
            Yes, I already used the Array feature.
            My whole code:
            class EnemyBasic extends MovieClip
                var _x, _y, speed, removeMovieClip, hitTest, health, shaking, shakeDuration, _rotation, name, _name;
                function EnemyBasic()
                    super();
                } // End of the function
                function onLoad()
                    _x = 700;
                    _y = Math.random() * 200 + 50;
                    speed = Math.random() * 3 + 3;
                    _root.ship.enemies.push(this);
                                health = 2;
                                shaking = false;
                    shakeDuration = 10;
                    _rotation = 0;
                                                    name = _name;
                function onEnterFrame()
                    _x = _x - speed;
                    if (_x < -100)
                        this.removeMovieClip();
                    } // end if
                                trace(name)
                    if (_root.ship.enemies.hitTest(_root.ship.body))
                        this.explode();
            } // End of Class
            Some of the code are removed to make this simpler.
            How do I change the HitTest part? _root.ship.enemies doesn't work
            • 3. Re: Help!! Setting "body" for enemy in shooter!!
              why doesn't _root.ship.enemies work?
              is it populated when you start your hittest?  if yes, how are you trying to use it?
              • 4. Re: Help!! Setting "body" for enemy in shooter!!
                Leonyipa Level 1
                What means populated when starting hittest?
                If I use if (this.hitTest(_root.ship.body))
                then no problem
                but I want _root.ship.body to have hit Test with the Enemy movieclip's body.
                so  I try to use:
                if (_root.ship.enemies.body.hitTest(_root.ship.body)) or
                if (_root.ship.name.body.hitTest(_root.ship.body)) or
                if (_root.ship._name.body.hitTest(_root.ship.body))
                I tried all of them and doesn't work.
                (I am very new to flash, so I just put anything I can think of into it)
                • 5. Re: Help!! Setting "body" for enemy in shooter!!
                  use:
                  for(var i:Number=_root.ship.enemies.length-1;i>=0;i--){
                  _root.ship.enemies[i].hitTest(_root.ship.body){
                  // do whatever
                  // if _root.ship.enemies[i] is destroyed and no longer needed use the two lines below:
                  _root.ship.enemies[i].removeMovieClip();
                  _root.ship.enemies.splice(i,1);
                  • 6. Re: Help!! Setting "body" for enemy in shooter!!
                    Leonyipa Level 1
                    I copied and paste this code but it doesn't work.
                    The enemy exploded before it enter the screen(before it collide with ship)
                    I am using ActionScript 2, also can you explain this piece of code?
                    • 7. Re: Help!! Setting "body" for enemy in shooter!!
                      show the code you used so i can see where you placed this code.
                      • 8. Re: Help!! Setting "body" for enemy in shooter!!
                        Leonyipa Level 1
                        whole piece of code:
                                super();
                            function onLoad()
                                _x = 700;
                          health = 2;
                          shaking = false;
                                shakeDuration = 10;
                                _rotation = 0;
                          name = _name;
                                _x = _x - speed;
                                if (_x < -100)
                                } // end if
                                    this.explode();
                                    if (_root.ship.shield._visible == false)
                                         _root.ship.updateHealth(-20);
                                         _root.ship.initShake();
                                    } // end if
                                    var _loc3 = _root.attachMovie("SmallExplosion", "SmallExplosion" + _root.getNextHighestDepth(), _root.getNextHighestDepth());
                                    _loc3._x = _root.ship._x;
                                    _loc3._y = _root.ship._y;
                                }} // end if
                          if(shaking == true){ this.shake(); }
                            function takeDamage()
                          if (health < 2) { this.explode(); }
                          else { health -= 1; initShake();}
                            function explode()
                                var _loc4 = _root.attachMovie("Explosion", "Explosion" + _root.getNextHighestDepth(), _root.getNextHighestDepth());
                                _loc4._x = _x;
                                _loc4._y = _y;
                                _root.ship.updateScore(100);
                                _root.ship.kills = _root.ship.kills + 1;
                                var _loc3 = _root.attachMovie("RewardPoints", "RewardPoints" + _root.getNextHighestDepth(), _root.getNextHighestDepth());
                                _loc3._x = _x;
                                _loc3._y = _y;
                                _loc3.field.text = 100;
                                _root.soundFX.attachSound("big_explosion.wav");
                                _root.soundFX.start();
                            function initShake()
                                shaking = true;
                                shakeDuration = 10;
                                _rotation = 5;
                          var _loc5 = _root.attachMovie("SmallExplosion", "SmallExplosion" + _root.getNextHighestDepth(), _root.getNextHighestDepth());
                                _loc5._x = _x;
                                _loc5._y = _y;
                            function shake()
                                _rotation = _rotation * -1;
                                shakeDuration = shakeDuration - 1;
                                if (shakeDuration == 0)
                                    shaking = false;
                                    _rotation = 0;
                                } // end if
                        } // End of Class
                        • 9. Re: Help!! Setting "body" for enemy in shooter!!
                          that hittest shouldn't be in the enemy class.  it should be in some kind of controller class.
                          or, if you want to have each enemy run its own hittest, don't use an array to store enemy instances and use this.hitTest(_root.ship.body)
                          • 10. Re: Help!! Setting "body" for enemy in shooter!!
                            Leonyipa Level 1
                            this.hitTest works for enemy, but I am trying to make it like enemy.body.hitTest or something like that because I want to make a "mask" for the enemy.
                            how do I do it in controller class?
                            • 11. Re: Help!! Setting "body" for enemy in shooter!!
                              you can do it in a controller class using the array and code i showed previously, but you should probably use a this.body.hitTest() in your enemy class.
