Can we please get help with these errors in the FlashInstall.log file. Please stop giving us the run around on "performing a clean install" and providing the link. I can assure both FlashPlayerApp.exe and .CPL file are being removed during my script process.
My script calls another .bat to taskkill IE and Acrobat for 3 minutes as my install happens. So nothing can be open during the entire process. Rest of my script is as follows.
@echo off
@cd /d "%~dp0"
start kill_IE.bat
start kill_Adobe.bat
uninstall_flash_player.exe -uninstall activex
timeout 5
uninstall_flash_player.exe -uninstall plugin
timeout 3
RD /S /Q "C:\Windows\system32\Macromed\flash"
RD /S /Q "C:\Windows\SysWOW64\Macromed\flash"
RD /S /Q "%appdata%\Adobe\Flash Player"
RD /S /Q "%appdata%\Macromedia\Flash Player"
msiexec /i "install_flash_player_13_active_x.msi" ALLUSERS=1 /q /norestart
timeout 5
msiexec /i "install_flash_player_13_plugin.msi" ALLUSERS=1 /q /norestart
timeout 3
echo AutoUpdateDisable=1 > C:\Windows\System32\Macromed\Flash\mms.cfg
echo AutoUpdateDisable=1 > C:\Windows\SysWOW64\Macromed\Flash\mms.cfg
exit /B 0
Everything is cleanly removed, no files are left over. The FlashPlayerApp.exe and .CPL files I can assure you are removed successfully. My output log produces the following in both SYSWOW64 and System32.
Here is the System32 Log (Which is Fine).
=O====== M/13.0.0.206 2014-04-30+13-30-35.849 ========
0000
0001 00000010 "C:\Users\xxxxxxxx\AppData\Local\Temp\{9986E684-3312-463C-8CCA-08738A4AAA3A}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 2 -au 4294967295
0002
0003
0004 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0005
0006 00000013 C:\Windows\system32\Macromed\Flash\Flash64_13_0_0_206.ocx
0007 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_13_0_0_206_ActiveX.exe
0008 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_13_0_0_206_ActiveX.dll
0009 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
0010 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0011 00000012
=X====== M/13.0.0.206 2014-04-30+13-30-40.426 ========
=O====== M/13.0.0.206 2014-04-30+13-30-55.044 ========
0000 00000010 "C:\Users\xxxxxxxxx\AppData\Local\Temp\{F04FDB26-F31D-4D58-AE27-D0EEEA502CC9}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 2 -au 4294967295
0001
0002
0003 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0004
0005
0006
0007
0008
0009
0010 00000014 C:\Windows\system32\Macromed\Flash\NPSWF64_13_0_0_206.dll
0011 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_13_0_0_206_Plugin.exe
0012 00000024 C:\Windows\system32\Macromed\Flash\plugin.vch
0013 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0014 00000012
=X====== M/13.0.0.206 2014-04-30+13-30-59.405 ========
Here is my syswow64 install log
014-4-30+13-30-43.188 [error] 1226 1062
=O====== M/13.0.0.206 2014-04-30+13-30-32.086 ========
0000 00000010 "C:\Users\xxxxxxx\AppData\Local\Temp\InstallAX_13_0_0_206.exe" -install -msi
0001
0002
0003 00000011 1
0005
0006 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_13_0_0_206.ocx
0007 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_13_0_0_206_ActiveX.exe
0008 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_13_0_0_206_ActiveX.dll
0009 00000023 C:\Windows\SysWOW64\Macromed\Flash\activex.vch
0011 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
0012
0013
0014 00000012
=X====== M/13.0.0.206 2014-04-30+13-30-44.583 ========
2014-4-30+13-31-2.90 [error] 1226 1062
=O====== M/13.0.0.206 2014-04-30+13-30-51.164 ========
0000 00000010 "C:\Users\xxxxxxxx\AppData\Local\Temp\InstallPlugin_13_0_0_206.exe" -install -msi
0001
0002
0003 00000011 1
0005
0006
0007
0008
0009
0010
0011
0012 00000014 C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_13_0_0_206.dll
0013 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_13_0_0_206_Plugin.exe
0014 00000024 C:\Windows\SysWOW64\Macromed\Flash\plugin.vch
0015 00000017 C:\Windows\SysWOW64\Macromed\Flash
0016 00000022 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_13_0_0_206.exe
0017 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0018
0019
0020 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
0021
0022
0023
0024 00000012
=X====== M/13.0.0.206 2014-04-30+13-31-03.181 ========
I can attest though Flash is working properly, but this is bothering me when you need to distribute to thousands of computers. I don't like hearing answers of "Well as long as it works" when I need to relay things to my boss.
Thank You.
