1 Reply Latest reply on Apr 30, 2014 9:54 PM by j9lemmon
    Deleting Folder Layer makes Flash CC lock
    j9lemmon Level 1
      In Flash CC, in Win 7 Home Premium 64-bit, I'm trying to delete a folder with layers in it. I get the message 'Deleting this layer folder will also delete the layers nested within it. Are you sure you want to delete this layer folder? As soon as this window appears, Flash is frozen and I must use Task Manager to close it.
      The same thing happens when I try to open an FLA that was created in Flash CS3 with Action Script set to 1.0 in Publish Settings. I get the window stating that Flash will convert the file to AS 3.0, but I cannot click the button to approve that, and Flash is locked.
      Any ideas on what's causing this?
        • 1. Re: Deleting Folder Layer makes Flash CC lock
          j9lemmon Level 1
          Similar issues I'm having with Flash CC (the program is essentialy unusable):
          - When I Save As, the Confirm Save As Window opens, and says 'The file already exists.' Yes and No are the options. Rollover with mose highlights the 'Yes' or 'No' but you cannot click either button. Flash CC freezes.
          - When I try to change the outline color by clicking the square beside the Padlock in a layer, the Layer Properties Window opens, but when I click the color swatch next to ' Outline color:' the swatch does not appear.
          - Flash CS3 works OK on this computer.
          - Generally, it seems that no dialog windows function correctly. I can draw with no problems.
          Any suggestions are greatly appreciated.
