1 Reply Latest reply on Apr 30, 2014 11:43 PM by Mylenium
    File Compression
    hneyer
      I've created a rack card for a client and need to reduce the file size to upload to the printer's website. How can compress (48MB down to 8MB or less) without losing print quality? Most of the card is text and illustration, however there is a high res photo.
        • 1. Re: File Compression
          Mylenium Legend
          Without seeing the artwork and info about the actual dimensions and resolution nobody can tell, but well, if you use a printer that only allows 8MB files and doesn't provide an alternate way to handle larger files then it's probably time to find another one... This should be no problem whatsoever. Still, depending on the size the key is probably to resize the embedded image in Photoshop before using it...
          Mylenium
