4 Replies Latest reply on Feb 21, 2017 6:54 PM by tulsagraphics
    Add Margins in Illustrator
    Eiranix Level 1
      I have made this little script to quickly add margins to an illustrator document and am posting it here to anyone that might find this helpful.
      The script will bring up a dialog where you can enter the sizes. Checking the equal box makes all sizes the same as the first.
      You have the option of using Millimetres, Inches or Pixels for your units and a last option to apply to all artboards or just the active one.
      The script then adds the guides to a locked layer called 'Margins' for convenience.
      There are two versions for your taste- The first creates 4 seperate guidelines. The second creates one rectangle guide.
      #target illustrator
      var docRef = app.activeDocument;
      var artboardRef = docRef.artboards;
      var workingLayer = docRef.activeLayer;
      //window
      var win = new Window('dialog', "Add Margins");
      this.windowRef = win;
      //panels
      win.fieldpanel = win.add("panel", undefined, "");
      win.radiopanel = win.add("panel", undefined, "");
      win.radiopanel2 = win.add("panel", undefined, "");
      //panel orientation
      win.fieldpanel.orientation='row';
      win.radiopanel.orientation='row';
      win.radiopanel2.orientation='row';
      //fieldpanel
      win.fieldpanel.panel1 = win.fieldpanel.add('panel', undefined, "Left");
      win.fieldpanel.panel2 = win.fieldpanel.add('panel', undefined, "Right");
      win.fieldpanel.panel3 = win.fieldpanel.add('panel', undefined, "Top");
      win.fieldpanel.panel4 = win.fieldpanel.add('panel', undefined, "Bottom");
      win.fieldpanel.panel1.left_input = win.fieldpanel.panel1.add('edittext', undefined, "0");
      win.fieldpanel.panel2.right_input = win.fieldpanel.panel2.add('edittext', undefined, "0");
      win.fieldpanel.panel3.top_input = win.fieldpanel.panel3.add('edittext', undefined, "0");
      win.fieldpanel.panel4.bottom_input = win.fieldpanel.panel4.add('edittext', undefined, "0");
      win.fieldpanel.panel1.left_input.characters = 5;
      win.fieldpanel.panel2.right_input.characters = 5;
      win.fieldpanel.panel3.top_input.characters = 5;
      win.fieldpanel.panel4.bottom_input.characters = 5;
      win.fieldpanel.check1 = win.fieldpanel.add('checkbox', undefined, "Equal");
      //radiopanel
      win.radiopanel.radio1 = win.radiopanel.add('radiobutton',undefined, "mm");
      win.radiopanel.radio2 = win.radiopanel.add('radiobutton',undefined, "in");
      win.radiopanel.radio3 = win.radiopanel.add('radiobutton',undefined, "px");
      //radiopanel2
      win.radiopanel2.radio1 = win.radiopanel2.add('radiobutton',undefined, "All Artboards");
      win.radiopanel2.radio2 = win.radiopanel2.add('radiobutton',undefined, "Active Artboard");
      //select first radio buttons
      win.radiopanel.radio1.value = true;
      win.radiopanel2.radio1.value = true;
      //ok button
      win.okbutton = win.add('button', undefined, "Ok");
      //disable fields with checkbox and equal values
      win.fieldpanel.check1.onClick = function() {
        if(win.fieldpanel.check1.value){
          var leftvalue = win.fieldpanel.panel1.left_input.text;
          win.fieldpanel.panel2.right_input.text = leftvalue;
          win.fieldpanel.panel3.top_input.text = leftvalue;
          win.fieldpanel.panel4.bottom_input.text = leftvalue;
          win.fieldpanel.panel2.right_input.enabled = false;
          win.fieldpanel.panel3.top_input.enabled = false;
          win.fieldpanel.panel4.bottom_input.enabled = false;
        } else {
          win.fieldpanel.panel2.right_input.enabled = true;
          win.fieldpanel.panel3.top_input.enabled = true;
          win.fieldpanel.panel4.bottom_input.enabled = true;
      //sync values while checked
      win.fieldpanel.panel1.left_input.onChanging = function (){
      //event listener for ok button
      win.okbutton.onClick = function(){
        var rightvalue = win.fieldpanel.panel2.right_input.text;
        var topvalue = win.fieldpanel.panel3.top_input.text;
        var bottomvalue = win.fieldpanel.panel4.bottom_input.text;
        if(win.radiopanel.radio1.value) {
          var multiplier = 2.834645669291339
        if(win.radiopanel.radio2.value) {
          var multiplier = 72
        if(win.radiopanel.radio3.value) {
          var multiplier = 1
        //close window
        win.close();
        //make a margins layer
        var guideLayer = docRef.layers.add();
        guideLayer.name = "Margins";
        if(win.radiopanel2.radio1.value) {
          //repeat for each artboard
          for(i=0;i<artboardRef.length;i++){
            //get artboard size
            var left=artboardRef[i].artboardRect[0];
            var top=artboardRef[i].artboardRect[1] ;
            var right=artboardRef[i].artboardRect[2] ;
            var bottom=artboardRef[i].artboardRect[3] ;
            //create lines
            var lineLeft = docRef.pathItems.add();
            var lineRight = docRef.pathItems.add();
            var lineTop = docRef.pathItems.add();
            var lineBottom = docRef.pathItems.add();
            //set line points
            var leftmargin = (leftvalue * multiplier);
            var rightmargin = (rightvalue * multiplier);
            var topmargin = (topvalue * multiplier);
            var bottommargin = (bottomvalue * multiplier);
            //set line points
            lineLeft.setEntirePath([[left + leftmargin, top], [left + leftmargin, bottom]]);
            lineRight.setEntirePath([[right - rightmargin, top], [right - rightmargin, bottom]]);
            lineTop.setEntirePath([[left, top - topmargin], [right, top - topmargin]]);
            lineBottom.setEntirePath([[left, bottom + bottommargin], [right, bottom + bottommargin]]);
            //make lines guides
            lineLeft.guides = true;
            lineRight.guides = true;
            lineTop.guides = true;
            lineBottom.guides = true;
        } else {
          //get artboard size
          var activeAB = docRef.artboards[docRef.artboards.getActiveArtboardIndex()]; // get active AB
          var left = activeAB.artboardRect[0];
          var top = activeAB.artboardRect[1] ;
          var right = activeAB.artboardRect[2] ;
          var bottom = activeAB.artboardRect[3] ;
          //create lines
          //set line points
          //set line points
          //make lines guides
        //lock margins layer and activate original layer
        guideLayer.zOrder (ZOrderMethod.SENDTOBACK);
        guideLayer.locked = true;
        docRef.activeLayer = workingLayer;
      win.show();
      Box Margin Version:
      #target illustrator
      //window
      //panels
      //panel orientation
      //fieldpanel
      //radiopanel
      //radiopanel2
      //ok button
        } else {
          var multiplier = 72
          var multiplier = 1
        //close window
        win.close();
            //get artboard size
            var width=artboardRef[i].artboardRect[2]-artboardRef[i].artboardRect[0];
            var height=artboardRef[i].artboardRect[1]-artboardRef[i].artboardRect[3];
            //set margin sizes
            //create box
            var box = docRef.pathItems.rectangle (top - topmargin, left + leftmargin, width - rightmargin - leftmargin, height - topmargin - bottommargin);
            box.fillColor = box.strokeColor = new NoColor();
            //make box guides
            box.guides = true;
        } else {
          //get artboard size
          var width = activeAB.artboardRect[2]-activeAB.artboardRect[0];
          var height = activeAB.artboardRect[1]-activeAB.artboardRect[3];
          //set margin sizes
          //create box
          //make box guides
          box.guides = true;
      win.show();
        • 1. Re: Add Margins in Illustrator
          CarlosCanto Adobe Community Professional & MVP
          nice, thanks for sharing.
          may I suggest something? combine them into one!!
          • 2. Re: Add Margins in Illustrator
            Eiranix Level 1
            Yes that would be sensible! don't know why I didn't...
            Here is a combined script:
            #target illustrator
            //window
            //panels
            win.fieldpanel = win.add("panel", undefined, "Sizes");
            win.radiopanel = win.add("panel", undefined, "Units");
            win.optionpanel = win.add("panel", undefined, "Options");
            win.optionpanel.radiopanel2 = win.optionpanel.add("panel", undefined, "Artboard");
            win.optionpanel.radiopanel3 = win.optionpanel.add("panel", undefined, "Margin Type");
            //panel orientation
            win.optionpanel.radiopanel2.orientation='row';
            win.optionpanel.radiopanel3.orientation='row';
            win.optionpanel.orientation='row';
            //fieldpanel
            //radiopanel
            //radiopanel2
            win.optionpanel.radiopanel2.radio1 = win.optionpanel.radiopanel2.add('radiobutton',undefined, "All Artboards");
            win.optionpanel.radiopanel2.radio2 = win.optionpanel.radiopanel2.add('radiobutton',undefined, "Active Artboard");
            //radiopanel3
            win.optionpanel.radiopanel3.radio1 = win.optionpanel.radiopanel3.add('radiobutton',undefined, "Margin Lines");
            win.optionpanel.radiopanel3.radio2 = win.optionpanel.radiopanel3.add('radiobutton',undefined, "Margin Box");
            win.optionpanel.radiopanel2.radio1.value = true;
            win.optionpanel.radiopanel3.radio1.value = true;
            //buttons
              } else {
                var multiplier = 72
                var multiplier = 1
              if(win.optionpanel.radiopanel2.radio1.value) {
                  //get artboard size
                  var left = artboardRef[i].artboardRect[0];
                  var top = artboardRef[i].artboardRect[1] ;
                  var right = artboardRef[i].artboardRect[2] ;
                  var bottom = artboardRef[i].artboardRect[3] ;
                  var width = artboardRef[i].artboardRect[2]-artboardRef[i].artboardRect[0];
                  var height = artboardRef[i].artboardRect[1]-artboardRef[i].artboardRect[3];
                  //create lines
                  //set margin values
                  if(win.optionpanel.radiopanel3.radio1.value) {
                    //set line points
                    //make lines guides
                  } else {
                    //create box
                    //make box guides
                    box.guides = true;
              } else {
                //get artboard size
                //create lines
                //set margin values
                  //set line points
                  //make lines guides
                } else {
                  //create box
                  //make box guides
                  box.guides = true;
              //close window
              win.close();
            win.show();
            • 3. Re: Add Margins in Illustrator
              thanks, much more efficient.
              thanks
              • 4. Re: Add Margins in Illustrator
                tulsagraphics
                I know it's been a few years, but I just discovered your script.  Very handy.  Thank you!!
