3 Replies Latest reply on May 1, 2014 7:51 AM by Dave LaRonde
    Very large scale rendering
    4500 Times
      Hi.
      I need to create an AVI in 3DS Max that will be played on a screen 4.8m x 3.2m (made up of 30 modules 0.96m x 0.8m).  The modules are 10mm dot pitch (e.g. 254DPI).  It seems to be a large enough task rendering @ 100DPI from Max and the file output size is ~700Mb per frame (x ~4000 frames =~ 3Tb in total) for the main components.  I will then have other render components to composite with these.
      Q.  Lets say that I can render off about 3Tb of data from Max.  Would AE be able to handle compositing something like this for such a large display?
      This is new ground for me so any advice at all would be gratefully received.
      T
        • 1. Re: Very large scale rendering
          AE can handle anything up to 16000x16000 pixels. For the matter at hand it's irrelevant most likely, anyway. At most this will probably be normal 4k output, or 3 or 4 HD streams split and played back via synchronized devices. Either way, the actual physical layout of the panels will not be mapped 1:1 because: Why should anyone? That's the same thing like when in print large format posters are printed at effectively 15 DPI at times. You know, viewing distance vs. dot size vs. perceived visual density. You really need to inquire/figure out what exact resolution is required and how you are supposed to deliver it because otherwise you might end up with a 12k output or something liek that for which no playback device exists. That also will take care of your insane amounts of data and render times - they simply will never be necessary.
          Mylenium
          • 2. Re: Very large scale rendering
            Todd_Kopriva Level 8
            The maximum pixel dimensions for a composition are 30,000x30,000.
            • 3. Re: Very large scale rendering
              Dave LaRonde Level 6
              Thanks for all the details about the screens, but that stuff is pretty irrelevant and dpi is absolutely useless.  Here's why:
              You can play a 1280x720 video from Vimeo on your phone.  How big is that screen?  What would be the dpi on it?
              You can play that very same 1280x720 video on your 72-inch HD TV set.  NOW what's the dpi?
              You say, "It's still 1280x720".... and you're RIGHT!  It's the playback device that has the greatest bearing on what you'd do in AE.  So you have to find that out before we can get you useful advice.
