3 Replies Latest reply on May 5, 2014 9:53 PM by csm_phil
    Getting the correct page number
    schiuma24 Level 1
      Hi, Im stuck with this project...
      I have this xml tag
      <page id="p4" type="cyan">some content</page>
      so, what I want to do is, use this attributes to apply a B-Cyan, B-Magenta or B-Yellow master spread to
      (well to whatever page number there is on the tag) in this case page 4 (and 5 implicitly)
      im stuck here
      if( !myRoot.xmlAttributes.itemByName("xmlns:xml").isValid )
      myRoot.xmlAttributes.add( "xmlns:xml", "http://www.w3.org/XML/1998/namespace" );
      if( !myRoot.xmlAttributes.itemByName("xmlns:aid").isValid )
      myRoot.xmlAttributes.add( "xmlns:aid", "http://ns.adobe.com/Adobe InDesign/4.0/" );
      if( !myRoot.xmlAttributes.itemByName("xmlns:aid5").isValid )
      myRoot.xmlAttributes.add( "xmlns:aid", "http://ns.adobe.com/Adobe InDesign/5.0/" );
      //**Types of pages
      var myPageNode= myRoot.evaluateXPathExpression("//page");
      for (var x = 0; x < myPageNode.length; x++){
                          var pageNumber  =  myPageNode[x].xmlAttributes.itemByName("id").value.replace("p","").replace(" ","");
                          var myTypeOfPage = myPageNode[x].xmlAttributes.itemByName("type").value;
                          if (myTypeOfPage = "cyan"){
                               app.activeDocument.pages.itemByName().appliedMaster = app.activeDocument.masterSpreads.item("B-Cyan")
                          if (myTypeOfPage = "magenta"){
                              app.activeDocument.pages.itemByName().appliedMaster = app.activeDocument.masterSpreads.item("B-Magenta")
                          if (myTypeOfPage = "yellow"){
                              app.activeDocument.pages.itemByName().appliedMaster = app.activeDocument.masterSpreads.item("B-Yellow")
      i dont know how to pass the correct value to: pages.itemByName( my page tag id number should get here )
      help!!!!!!!!!!!
        • 1. Re: Getting the correct page number
          csm_phil Level 4
          Hi schiuma24,
          I just modified your JS code, Please try the below code its works fine!
          var myRoot = myDoc.xmlElements[0];
              var pageNumber  =  myPageNode[x].xmlAttributes.itemByName("id").value.replace(/[a-z]/gi, "");
              if (myTypeOfPage == "cyan"){
                  myDoc.pages.item(pageNumber).appliedMaster = myDoc.masterSpreads.item("B-Cyan");
              else if (myTypeOfPage == "magenta"){
                  myDoc.pages.item(pageNumber).appliedMaster = myDoc.masterSpreads.item("B-Magenta");
              else if (myTypeOfPage == "yellow"){
                  myDoc.pages.item(pageNumber).appliedMaster = myDoc.masterSpreads.item("B-Yellow");
          here is your mistake!!
             if (myTypeOfPage = "cyan"){// Here your not compare the the cyan, you assign the value.
          thx,
          csm_phil.
          • 2. Re: Getting the correct page number
            schiuma24 Level 1
            Hi Phil, im not comparing to cyan, im checking if the attribute of Type is cyan
            • 3. Re: Getting the correct page number
              csm_phil Level 4
              Hi schium24,
              You said your comparing the cyan value, but you you using the "=" is assign the value. not compare, If you need to compare you have to use "==" or etc.
              I tried my code its working fine. You get any error the above code.
              thx,
              csm_phil
