5 Replies Latest reply on May 3, 2014 7:32 AM by BKBK
    ColdFusion 9 and ColdFusion 10
    iccsi Level 1
      I have following JavaScrip code which works for ColdFusion 10, but not ColdFsuion 9.
      Because I have ColdFusion production server so I need find a solution for ColdFusion 9.
      I use SQL Server 2008 as backend.
      If SQL server returns datetime type then I can get curr_date, curr_month and curr_year.
      The datetime type return is 'April, 25 2014 00:00:00', but I want to dispaly without time section and if it is possible that I need display like mm-dd-yyyy or yyyy-mm-dd have more compact display.
      If SQL server returns date type then rowdata, curr_date, curr_month, and curr_year are NaN.
      SQL returns '2014-04-25' when I use Date Type which is what I need, but ColdFusion does not recognize when I pass to the other form and it reads NaN.
      I understand that it is JavaScrip code, but for some reason they have different behavior on ColdFusion 9 and ColdFusion 10.
      I would like to know is it possible to get compact date format and ColdFusion can recognize as a date field to parse right information,
      Your help and information is great appreciated,
      Regards,
      Iccsi,
      var d = new Date(rowdata[1]);
            var curr_date = d.getDate();
           var curr_month = d.getMonth() +1 ;
           var curr_year = d.getFullYear();
        • 1. Re: ColdFusion 9 and ColdFusion 10
          Steve Sommers Level 4
          Need more data. How is the date from the cfquery (I'm assuming you are using cfquery to get the data from MS-SQL 2008 server) making it into the rowdata array?
          My guess is you are using whatever native format that the SQL server returns. I always format date and time variables with DateFormat and/or TimeFormat.
          • 2. Re: ColdFusion 9 and ColdFusion 10
            iccsi Level 1
            Thanks a million for the information and help,
            I use cfstoredproc, I just return convert(char(10), myDate, 101) and it works, since 101 returns mm/dd/yyyy.
            Thanks again for helping,
            Regards,
            Iccsi,
            • 3. Re: ColdFusion 9 and ColdFusion 10
              BKBK Adobe Community Professional & MVP
              I still don't understand. In fact, I have the same question as Steve. How do you pass date data from the query to Javascript?
              • 4. Re: ColdFusion 9 and ColdFusion 10
                iccsi Level 1
                Thanks for the message,
                The date time value I got from stored procedure to my lookup form from user criteria to fill jqGrid.
                I let user click on the row to go to specific row, the date and time fields are part of key.
                I pass the information from jqGrid to my edit form, technically, it is from jqQuery, not directory from MS SQL server.
                The only question I have is that ColdFusion 9 and ColdFusion 10 behavior are different.
                Regards,
                iccsi,
                • 5. Re: ColdFusion 9 and ColdFusion 10
                  Get the SQL server to return datetime type. That works. So it is a good place to start.
                  You could, using what you already have, create a date as a string in the format you need, and return it.
                  var theDate = d.toLocaleDateString();
                  An alternative:
                  var curr_date = ('0'+d.getDate()).slice(-2); // dd format
                  var curr_month = ('0'+(d.getMonth() +1)).slice(-2) ; // mm format
                  var curr_year = d.getFullYear().toString();
                  // Your preferred format
                  var dateAsString = curr_month + '-' + curr_date + '-' + curr_year;
