1 Reply Latest reply on May 5, 2014 7:50 AM by jcktxt
    InDesign Workflow for DPS
    jcktxt
      I've been working on this project for a while now and I wonder if anyone has any ideas or can point me to some resources about how to set up this script.
      I recieve PDFs and I want to convert them to PNGs (using Photoshop) and then place them in an InDesign document. This is how I ideally see it happening.
      I drag the PDF onto a app and the script creates a folder structure based on the file name.
      filename_stack
      - links
      - original
      Takes the PDF and convert it to a PNG, using Photoshop CS5 (in RGB, at 300 dpi)
      Moves the PDF to "original" folder
      Moves the PNG to "links" folder
      Creates an InDesign document (746 px by 1024 px, for web use)
      Places the PNG in the document, centered in frame that is 746 x 1024, with the picture at 130%
      Saves the InDesign document in the "filename_stack" folder with the name "filename_v.indd"
        • 1. Re: InDesign Workflow for DPS
          jcktxt Level 1
          I've actually made a lot of progress so far using applescript.
          I have a script that makes all of the basic folders and moves the file into the right folder. Now on to having InDesign create a new document and place the file.
          Here is what I have so far:
          on open mgItems
            repeat with mgItem in mgItems
            tell application "Finder"
            set mgName to name of mgItem
            set mgExtension to name extension of mgItem
            set the mgFolderPath to (the container of mgItem) as text
            set text item delimiters of AppleScript to {"."}
            set mgNewName to text item 1 of mgName
            set text item delimiters of AppleScript to {"_"}
            set mgNewName to text item 1 of mgNewName
            set text item delimiters of AppleScript to ""
            set stackName to "_stack"
            try
            set mgFinalFolder to mgFolderPath & mgNewName & ":" as alias
            on error
            set mgFinalFolder to make folder at mgFolderPath with properties {name:mgNewName & (stackName)}
            end try
            set folder1 to make new folder at mgFinalFolder with properties {name:"original"}
            set folder2 to make new folder at mgFinalFolder with properties {name:"links"}
            move mgItem to mgFinalFolder
            move mgItem to folder2
            set the templateFile to "Macintosh HD:Users:jcavicchi:Desktop:scriptopia:donotmove.indd"
            set templateRename to duplicate templateFile to mgFinalFolder
            set extentionName to "_v.indd"
            set name of templateRename to mgNewName & (extentionName)
            end tell
            end repeat
          end open
