1. Re: Photoshop cs5-no video card detected in GPU settings
Curt Y May 1, 2014 5:37 PM (in response to Kayleebaker)With a Mac this is difficult as you are at mercy of Apple to provide drivers. This is solely a dirver issue. Make sure you are running latest OS.
2. Re: Photoshop cs5-no video card detected in GPU settings
Atiqur Sumon May 3, 2014 3:00 AM (in response to Kayleebaker)Running the latest OS.
3. Re: Photoshop cs5-no video card detected in GPU settings
AimsIRM Oct 1, 2014 10:04 AM (in response to Atiqur Sumon)Same issue here.
Running the same system here with the Geforce GTX 775m. Currently running OS 10.9.5. Photoshop CC 2014 shows no GPU detected under Preferences and all video card related options are disabled. I've tried installing nVidia's web driver, but it's not compatible, unfortunately. The 10.9.5 update hasn't helped either and I haven't found any further driver update from Apple.
Is there a way to force detection or manually specify video card specs?
System Information output:
Adobe Photoshop Version: 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00) x64
Operating System: Mac OS 10.9.5
System architecture: Intel CPU Family:6, Model:60, Stepping:3 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, HyperThreading
Physical processor count: 4
Logical processor count: 8
Processor speed: 3500 MHz
Built-in memory: 8192 MB
Free memory: 4809 MB
Memory available to Photoshop: 7236 MB
Memory used by Photoshop: 70 %
Image tile size: 1024K
Image cache levels: 4
Font Preview: Medium
TextComposer: Latin
Display: 1
Main Display
Display Bounds: top=0, left=0, bottom=1024, right=1280
OpenGL Drawing: Disabled.
OpenGL Allow Old GPUs: Not Detected.
OpenGL Drawing Mode: Basic
OpenGL Allow Normal Mode: False.
OpenGL Allow Advanced Mode: False.
AIFCoreInitialized=1
AIFOGLInitialized=1
OGLContextCreated=1
NumGPUs=1
gpu[0].OGLVersion="2.1"
gpu[0].MemoryMB=2048
gpu[0].RectTextureSize=16384
gpu[0].Renderer="NVIDIA GeForce GTX 775M OpenGL Engine"
gpu[0].RendererID=16918308
gpu[0].Vendor="NVIDIA Corporation"
gpu[0].VendorID=4318
gpu[0].HasNPOTSupport=1
gpu[0].CompileProgramGLSL=1
gpu[0].TestFrameBuffer=1
gpu[0].OCLPresent=1
gpu[0].OCLVersion="1.2 (Jul 29 2014 21:24:39)"
gpu[0].CUDASupported=0
gpu[0].OCLBandwidth=1.98623e+10
gpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.20"
gpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[16384]
gpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
gpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[16]
gpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[16]
gpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[16]
gpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
gpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
gpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[2048]
gpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
gpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
gpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
gpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
gpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
gpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
gpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
gpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
gpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
License Type: Perpetual Volume License
Serial number: 90960111439975080147
Application folder: /Applications/Adobe Photoshop CC/
Photoshop scratch has async I/O enabled
Scratch volume(s):
Startup, 116.4G, 53.7G free
Required Plug-ins folder: /Applications/Adobe Photoshop CC/Adobe Photoshop CC.app/Contents/Required/Plug-Ins/
Primary Plug-ins folder: /Applications/Adobe Photoshop CC/Plug-ins/
Installed components:
adbeape.framework adbeape 3.4.0.29366 0.1160850
AdbeScriptUIFlex.framework AdbeScriptUIFlex 6.3.2.31983 79.546835
adobe_caps.framework adobe_caps 7.0.0.21 1.248010
AdobeACE.framework AdobeACE 2.20.02.31977 79.548223
AdobeAGM.framework AdobeAGM 4.30.29.31977 79.548223
AdobeAXE8SharedExpat.framework AdobeAXE8SharedExpat 3.7.101.18636 66.26830
AdobeAXEDOMCore.framework AdobeAXEDOMCore 3.7.101.18636 66.26830
AdobeBIB.framework AdobeBIB 1.2.03.31977 79.548223
AdobeBIBUtils.framework AdobeBIBUtils 1.1.01 79.548223
AdobeCoolType.framework AdobeCoolType 5.15.00.31977 79.548223
AdobeCrashReporter.framework AdobeCrashReporter 7.0.1
AdobeExtendScript.framework AdobeExtendScript 4.5.5.31983 79.546835
AdobeJP2K.framework AdobeJP2K 1.2.2.31977 79.248139
AdobeLinguistic.framework 19061
AdobeMPS.framework AdobeMPS 5.8.1.31977 79.535029
AdobeOwl.framework AdobeOwl 5.0.24 79.547804
AdobePDFL.framework AdobePDFL 11.0.0.31977 79.508720
AdobePDFSettings.framework AdobePDFSettings 1.4
AdobePIP.framework AdobePIP 7.0.0.1786
AdobeScCore.framework AdobeScCore 4.5.5.31983 79.546835
AdobeUpdater.framework AdobeUpdater 6.0.0.1452 "52.338651"
AdobeXMP.framework AdobeXMPCore 79.154911 79.154911
AdobeXMPFiles.framework AdobeXMPFiles 79.154911 79.154911
AdobeXMPScript.framework AdobeXMPScript 79.154911 79.154911
ahclient.framework ahclient 1.8.0.31
aif_core.framework AdobeAIF 5.0.00 79.534508
aif_ocl.framework AdobeAIF 5.0.00 79.534508
aif_ogl.framework AdobeAIF 5.0.00 79.534508
AlignmentLib.framework xcode Copyright © 2013 Adobe Systems Incorporated
amtlib.framework amtlib 7.0.0.249
boost_date_time.framework boost_date_time 7.0.0.0
boost_signals.framework boost_signals 7.0.0.0
boost_system.framework boost_system 7.0.0.0
boost_threads.framework boost_threads 7.0.0.0
Cg.framework NVIDIA Cg
CIT.framework CIT 2.1.6.30929 151865
CITThreading.framework CITThreading 2.1.6.30929 151865
dvaaudiodevice.framework dvaaudiodevice 7.0.0.0
dvacore.framework dvacore 7.0.0.0
dvamarshal.framework dvamarshal 7.0.0.0
dvamediatypes.framework dvamediatypes 7.0.0.0
dvaplayer.framework dvaplayer 7.0.0.0
dvatransport.framework dvatransport 7.0.0.0
dvaunittesting.framework dvaunittesting 7.0.0.0
dynamiclink.framework dynamiclink 7.0.0.0
FileInfo.framework FileInfo 79.154511 79.154511
filter_graph.framework AdobeAIF 5.0.00 79.534508
ICUConverter.framework ICUConverter 3.61 "gtlib_3.0" "." "16615"
ICUData.framework ICUData 3.61 "gtlib_3.0" "." "16615"
LogSession.framework LogSession 2.1.2.1785
mediacoreif.framework mediacoreif 7.0.0.0
patchmatch.framework patchmatch 1.2.00.31977 79.542390
PlugPlugOwl.framework PlugPlugOwl 4.2.0.36
UpdaterNotifications.framework UpdaterNotifications 7.0.1.102 "7.0.1.102"
WRServices.framework
Required plug-ins:
3D Studio 14.2.1 x001 ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
Accented Edges 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Adaptive Wide Angle 14.2, Copyright © 2014 Adobe Systems Incorporated - from the file “Adaptive Wide Angle.plugin”
Angled Strokes 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Average 14.2.1 x001 ©1993-2014 Adobe Systems Incorporated - from the file “Average.plugin”
Bas Relief 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
BMP 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Camera Raw 8.4.1 (200), Copyright © 2014 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
Camera Raw Filter 8.4.1 (200), Copyright © 2014 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
Chalk & Charcoal 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Chrome 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Cineon 14.2.1 x001 ©2002-2014 Adobe Systems Incorporated - from the file “Cineon.plugin”
Clouds 14.2.1 x001 ©1993-2014 Adobe Systems Incorporated - from the file “Clouds.plugin”
Collada DAE 14.2.1 x001 ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
Color Halftone 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Colored Pencil 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
CompuServe GIF 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Conté Crayon 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Craquelure 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Crop and Straighten Photos 14.2.1 x001 ©2003-2014 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
Crop and Straighten Photos Filter 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Crosshatch 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Crystallize 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Cutout 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Dark Strokes 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
De-Interlace 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Dicom 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “dicom.plugin”
Difference Clouds 14.2.1 x001 ©1993-2014 Adobe Systems Incorporated - from the file “Clouds.plugin”
Diffuse Glow 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Displace 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Dry Brush 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Eazel Acquire 14.2.1 x001 ©1997-2014 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
Embed Watermark NO VERSION - from the file “DigiSign.plugin”
Entropy 14.2.1 x001 ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
Extrude 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
FastCore Routines 14.2.1 x001 ©1990-2014 Adobe Systems Incorporated - from the file “FastCore.plugin”
Fibers 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Film Grain 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Filter Gallery 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Flash 3D 14.2.1 x001 ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
Fresco 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Glass 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Glowing Edges 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Google Earth 4 KMZ 14.2.1 x001 ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
Graphic Pen 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Halftone Pattern 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
HDRMergeUI 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
IFF Format 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Ink Outlines 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
JPEG 2000 14.2.1 x001 ©2001-2014 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
Kurtosis 14.2.1 x001 ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
Lens Blur 14.2, Copyright © 2002-2014 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
Lens Correction 14.2, Copyright © 2002-2014 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
Lens Flare 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Liquify 14.2, Copyright © 2001-2014 Adobe Systems Incorporated - from the file “Liquify.plugin”
Matlab Operation 14.2.1 x001 ©1993-2014 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
Maximum 14.2.1 x001 ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
Mean 14.2.1 x001 ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
Measurement Core 14.2.1 x001 ©1993-2014 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
Median 14.2.1 x001 ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
Mezzotint 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Minimum 14.2.1 x001 ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
MMXCore Routines 14.2.1 x001 ©1990-2014 Adobe Systems Incorporated - from the file “MMXCore.plugin”
Mosaic Tiles 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Multiprocessor Support 14.2.1 x001 ©1990-2014 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
Neon Glow 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Note Paper 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
NTSC Colors 14.2.1 x001 ©1993-2014 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
Ocean Ripple 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Oil Paint 14.2, Copyright © 2014 Adobe Systems Incorporated - from the file “Oil Paint.plugin”
OpenEXR 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Paint Daubs 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Palette Knife 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Patchwork 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Paths to Illustrator 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
PCX 14.2.1 x001 ©1989-2014 Adobe Systems Incorporated - from the file “PCX.plugin”
Photocopy 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Photoshop 3D Engine 14.2.1 x001 ©2006-2014 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
Photoshop Touch CC (14.2.0.0) ©1993-2014 Adobe Systems Incorporated - from the file “PSDX.plugin”
Picture Package Filter 14.2.1 x001 ©1993-2014 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
Pinch 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Pixar 14.2.1 x001 ©1989-2014 Adobe Systems Incorporated - from the file “Pixar.plugin”
Plaster 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Plastic Wrap 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
PNG 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Pointillize 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Polar Coordinates 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Portable Bit Map 14.2.1 x001 ©1989-2014 Adobe Systems Incorporated - from the file “PBM.plugin”
Poster Edges 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Radial Blur 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Radiance 14.2.1 x001 ©2003-2014 Adobe Systems Incorporated - from the file “Radiance.plugin”
Range 14.2.1 x001 ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
Read Watermark NO VERSION - from the file “DigiRead.plugin”
Reticulation 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Ripple 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Rough Pastels 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Save for Web 14.2, Copyright © 1999-2014 Adobe Systems Incorporated - from the file “Save for Web.plugin”
ScriptingSupport 14.2.1, Copyright © 2014 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
Shake Reduction 14.2, Copyright © 2014 Adobe Systems Incorporated - from the file “Shake Reduction.plugin”
Shear 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Skewness 14.2.1 x001 ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
Smart Blur 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Smudge Stick 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Solarize 14.2.1 x001 ©1993-2014 Adobe Systems Incorporated - from the file “Solarize.plugin”
Spatter 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Spherize 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Sponge 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Sprayed Strokes 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Stained Glass 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Stamp 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Standard Deviation 14.2.1 x001 ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
STL 14.2.1 x001 ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
Sumi-e 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Summation 14.2.1 x001 ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
Targa 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Texturizer 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Tiles 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Torn Edges 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Twirl 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Underpainting 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Vanishing Point 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
Variance 14.2.1 x001 ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
Water Paper 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Watercolor 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Wave 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Wavefront|OBJ 14.2.1 x001 ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
Wind 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Wireless Bitmap 14.2.1 x001 ©1989-2014 Adobe Systems Incorporated - from the file “WBMP.plugin”
ZigZag 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Optional and third party plug-ins: NONE
Plug-ins that failed to load: NONE
Flash:
Mini Bridge
Adobe Exchange
Kuler
Installed TWAIN devices: NONE
