0 Replies Latest reply on May 21, 2007 3:31 AM by bernardsumption
    Compiling AS documentation in Flash CS3?
      The flex SDK has a documentation compiler called asdoc. It is possible to download the flex SDK and compile documentation for actionscript files used in a flash project.
      However, my flash file has objects exported for actionscript using the "Linkage" settings, and the actionscript source files refers to these exported classes, causing a compile-time error when I compile the project with the flex compiler. Asdoc won't generate documentation unless the project compiles with the flex compiler.
      Is there a way of generating documentation for Flash Actionscript? I've considered creating dummy classes with the same names as the exported classes just to persuade the project to compile, but it seems a bit ugly!
      Any help appreciated!
