11 Replies Latest reply on Jul 13, 2014 11:48 AM by strikingfx
    Photoshop cs6 running extremely slow on opening a file. have reset prefs and set type to none.
    rkford Level 1
      Photoshop cs6 running extremely slow on opening a file. have reset prefs and set type to none. have to force quit  most of the time.
        • 1. Re: Photoshop cs6 running extremely slow on opening a file. have reset prefs and set type to none.
          Trevor.Dennis Adobe Community Professional (Moderator)
          Where are you opening the file from?  Is it an external, or non OS drive, for instance?  If yes, what are your power saving settings? (are you waiting for the drive to wake up?)
          I'm not sure what you mean by 'set type to none'.  Where was this setting?
          • 2. Re: Photoshop cs6 running extremely slow on opening a file. have reset prefs and set type to none.
            rkford Level 1
            Internal drive and  I set the font preview size to none under edit type. I thinking about reinstalling Photoshop. This is a 27 imac with 16 gigs of ram.
            • 3. Re: Photoshop cs6 running extremely slow on opening a file. have reset prefs and set type to none.
              Noel Carboni Level 8
              What are the pixel dimensions of the file?  Does it have a very large number of layers?  When you do get it open what is the Document Size as reported by Photoshop?  Is it possible there are many pixels beyond the edge of the visible canvas (e.g. possibly as a result of a Crop operation with the Delete Cropped Pixels setting off)?
              I'm thinking that somehow the document is much larger than you expect it to be.
              -Noel
              • 4. Re: Photoshop cs6 running extremely slow on opening a file. have reset prefs and set type to none.
                rkford Level 1
                Document size doesn't matter. A 1 meg file will take 5-20 minutes to open. Once the file is open, everything seems to work fast.
                I trying to recall if this started after the last CC update.
                Roger
                • 5. Re: Photoshop cs6 running extremely slow on opening a file. have reset prefs and set type to none.
                  Sounds like the kind of problem that might respond to a reset of Photoshop preferences to defaults.
                  How to Reset Photoshop CS6’s Preferences File | The Complete Picture with Julieanne Kost | Adobe TV
                  Another thing I'd suggest is validating all your fonts to make sure you don't have one that's corrupted.
                  Troubleshoot fonts | Photoshop CC, CS6, CS5
                  -Noel
                  • 6. Re: Photoshop cs6 running extremely slow on opening a file. have reset prefs and set type to none.
                    rkford Level 1
                    I cleaned and validated all the fonts and removed all questionable fonts. Reset preferences and still have problem. Slow to open and in force quit "Photoshop not responding"
                    Roger
                    • 7. Re: Photoshop cs6 running extremely slow on opening a file. have reset prefs and set type to none.
                      rkford Level 1
                      Should I uninstall and start over?
                      Thanks for your help.
                      Roger
                      • 8. Re: Photoshop cs6 running extremely slow on opening a file. have reset prefs and set type to none.
                        I can't easily say, though I might suggest trying to understand the problem better before trying to jump to a solution.
                        Have you looked through your system logs?  Is it possible your disk is failing and it's having to do a lot of retries during load and save operations?  If so, stressing it by uninstalling / reinstalling might be the worst thing you can do.
                        Do you have a good backup?
                        -Noel
                        • 9. Re: Photoshop cs6 running extremely slow on opening a file. have reset prefs and set type to none.
                          rkford Level 1
                          Where do I find the system logs and what would I be looking for?
                          • 10. Re: Photoshop cs6 running extremely slow on opening a file. have reset prefs and set type to none.
                            You're on a Mac, right?  I am unfortunately only expert in PC operations.  I hope a Mac expert will hop in here and help advise you.
                            -Noel
                            • 11. Re: Photoshop cs6 running extremely slow on opening a file. have reset prefs and set type to none.
                              strikingfx Level 1
                              I'm experiencing the same trouble.  Photoshop takes 5 minutes to open then runs fine.
                              I recently bought a new iMac AND updated to Adobe Master Collection CS6.  My concern is that PhotoShop now takes 5 minutes to open. The Photoshop desktop pops up immediately, but the moment you click on a tool or try to open a file (no matter the size) results in the spinning wheel for five minutes before you can do anything.  After that, Photoshop appears to work fine.
                              What I’ve done:
                              • Ran Adobe updater
                              • Reset Photoshop Preferences
                              • Validated all fonts and removed any trouble fonts
                              • Ran the font test
                              • Set font preview size to none
                              • Cleared the Photoshop type cache and system cache
                              • Disabled Symantec Endpoint
                              • Tried running with the GPU processor on/off and in basic
                              • Tried opening Photoshop with optional third party plug-ins turned off (still took five minutes but this time I didn’t even get the Photoshop desktop view until AFTER the five minutes)
                              I’m wondering since I migrated the files form my old computer (and older versions of Master Collection) did something get corrupted.
                              System Info
                              Adobe Photoshop Version: 13.0.6 (13.0.6 20131025.r.54 2013/10/25:21:00:00) x64
                              Operating System: Mac OS 10.9.4
                              System architecture: Intel CPU Family:6, Model:60, Stepping:3 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, HyperThreading
                              Physical processor count: 4
                              Logical processor count: 8
                              Processor speed: 3500 MHz
                              Built-in memory: 32768 MB
                              Free memory: 21330 MB
                              Memory available to Photoshop: 30850 MB
                              Memory used by Photoshop: 70 %
                              Image tile size: 1024K
                              Image cache levels: 4
                              OpenGL Drawing: Enabled.
                              OpenGL Drawing Mode: Advanced
                              OpenGL Allow Normal Mode: True.
                              OpenGL Allow Advanced Mode: True.
                              OpenGL Allow Old GPUs: Not Detected.
                              OpenCL Version: 1.2 (Apr 25 2014 22:04:25)
                              OpenGL Version: 2.1
                              Video Rect Texture Size: 16384
                              OpenGL Memory: 2047 MB
                              Video Card Vendor: NVIDIA Corporation
                              Video Card Renderer: NVIDIA GeForce GTX 780M OpenGL Engine
                              Display: 1
                              Main Display
                              Display Depth: 32
                              Display Bounds: top=0, left=0, bottom=1440, right=2560
                              Video Renderer ID: 16918308
                              Video Card Memory: 2048 MB
                              Application folder: /Applications/Adobe Photoshop CS6/
                              Photoshop scratch has async I/O enabled
                              Scratch volume(s):
                                Macintosh HD, 931.0G, 713.2G free
                              Required Plug-ins folder: /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/
                              Primary Plug-ins folder: /Applications/Adobe Photoshop CS6/Plug-ins/
                              Additional Plug-ins folder: not set
                              Installed components:
                              adbeape.framework adbeape 3.3.8.19346   66.1025012
                              AdbeScriptUIFlex.framework AdbeScriptUIFlex 6.2.29.18602 66.490082
                              adobe_caps.framework adobe_caps 6.0.29.0   1.276181
                              AdobeACE.framework AdobeACE 2.19.18.20743   66.507768
                              AdobeAGM.framework AdobeAGM 4.26.20.20743   66.507768
                              AdobeAXE8SharedExpat.framework   AdobeAXE8SharedExpat   3.7.101.18636   66.26830
                              AdobeAXEDOMCore.framework AdobeAXEDOMCore 3.7.101.18636 66.26830
                              AdobeBIB.framework AdobeBIB 1.2.02.20743   66.507768
                              AdobeBIBUtils.framework AdobeBIBUtils 1.1.01   66.507768
                              AdobeCoolType.framework AdobeCoolType 5.10.33.20743 66.507768
                              AdobeCrashReporter.framework AdobeCrashReporter 6.0.20120720
                              AdobeExtendScript.framework AdobeExtendScript 4.2.12.18602 66.490082
                                 AdobeJP2K.framework   AdobeJP2K   2.0.0.18562   66.236923
                              AdobeLinguistic.framework      17206
                              AdobeMPS.framework AdobeMPS 5.8.0.19463   66.495174
                              AdobeOwl.framework AdobeOwl   5.0.4   79.517869
                              AdobePDFL.framework AdobePDFL   10.0.1.18562   66.419471
                              AdobePDFSettings.framework AdobePDFSettings 1.4
                              AdobePIP.framework AdobePIP 7.0.0.1686
                              AdobeScCore.framework AdobeScCore 4.2.12.18602   66.490082
                              AdobeUpdater.framework AdobeUpdater 6.0.0.1452   "52.338651"
                              AdobeXMP.framework AdobeXMPCore 66.145661   66.145661
                              AdobeXMPFiles.framework AdobeXMPFiles 66.145661   66.145661
                              AdobeXMPScript.framework AdobeXMPScript 66.145661   66.145661
                              ahclient.framework ahclient 1.7.0.56
                                 aif_core.framework   AdobeAIF   3.0.00   62.490293
                              aif_ocl.framework AdobeAIF   3.0.00   62.490293
                              aif_ogl.framework AdobeAIF   3.0.00   62.490293
                              AlignmentLib.framework xcode   1.0.0.1
                              amtlib.framework amtlib   6.0.0.75
                              boost_date_time.framework boost_date_time 6.0.0.0
                              boost_signals.framework boost_signals 6.0.0.0
                              boost_system.framework boost_system 6.0.0.0
                              boost_threads.framework boost_threads 6.0.0.0
                              Cg.framework   NVIDIA Cg
                              CIT.framework CIT   2.1.0.20577   146758
                              data_flow.framework AdobeAIF   3.0.00   62.490293
                              dvaaudiodevice.framework dvaaudiodevice 6.0.0.0
                              dvacore.framework dvacore   6.0.0.0
                              dvamarshal.framework dvamarshal 6.0.0.0
                              dvamediatypes.framework dvamediatypes 6.0.0.0
                              dvaplayer.framework dvaplayer 6.0.0.0
                              dvatransport.framework dvatransport 6.0.0.0
                              dvaunittesting.framework dvaunittesting 6.0.0.0
                              dynamiclink.framework dynamiclink 6.0.0.0
                                 FileInfo.framework   FileInfo   66.145433   66.145433
                              filter_graph.framework AdobeAIF   3.0.00   62.490293
                              hydra_filters.framework AdobeAIF   3.0.00   62.490293
                              ICUConverter.framework ICUConverter 3.61   "gtlib_3.0" "." "16615"
                                 ICUData.framework   ICUData   3.61 "gtlib_3.0" "." "16615"
                              image_compiler.framework AdobeAIF   3.0.00   62.490293
                              image_flow.framework AdobeAIF   3.0.00   62.490293
                              image_runtime.framework AdobeAIF   3.0.00   62.490293
                              LogSession.framework LogSession 2.1.2.1681
                              mediacoreif.framework mediacoreif 6.0.0.0
                              PlugPlug.framework PlugPlug 3.0.0.383
                              UpdaterNotifications.framework   UpdaterNotifications   6.0.0.24 "6.0.0.24"
                              wrservices.framework
                              Required plug-ins:
                                 3D Studio 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “U3D.plugin”
                                 Accented Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                 Adaptive Wide Angle 13.0, Copyright © 2012 Adobe Systems Incorporated - from the file “Adaptive Wide Angle.plugin”
                                 Angled Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                 Average 13.0.6 x001  ©1993-2013 Adobe Systems Incorporated - from the file “Average.plugin”
                                 Bas Relief 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                 BMP 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                 Camera Raw 8.4 (199), Copyright © 2014 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
                                 Camera Raw Filter 8.4 (199), Copyright © 2014 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
                                 Chalk & Charcoal 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                 Chrome 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                 Cineon 13.0.6 x001  ©2002-2013 Adobe Systems Incorporated - from the file “Cineon.plugin”
                                 Clouds 13.0.6 x001  ©1993-2013 Adobe Systems Incorporated - from the file “Clouds.plugin”
                                 Collada DAE 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “U3D.plugin”
                                 Color Halftone 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                 Colored Pencil 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                              CompuServe GIF 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                 Conté Crayon 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                 Craquelure 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                 Crop and Straighten Photos 13.0.6 x001 ©2003-2013 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
                                 Crop and Straighten Photos Filter 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                              Crosshatch 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                              Crystallize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                 Cutout 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                 Dark Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                              De-Interlace 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                 Dicom 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “dicom.plugin”
                                 Difference Clouds 13.0.6 x001  ©1993-2013 Adobe Systems Incorporated - from the file “Clouds.plugin”
                                 Diffuse Glow 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                 Displace 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                 Dry Brush 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                 Eazel Acquire 13.0.6 x001  ©1997-2013 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
                                 Embed Watermark NO VERSION - from the file “DigiSign.plugin”
                                 Entropy 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
                                 Extrude 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                 FastCore Routines 13.0.6 x001  ©1990-2013 Adobe Systems Incorporated - from the file “FastCore.plugin”
                                 Fibers 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                 Film Grain 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                 Filter Gallery 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                 Flash 3D 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “U3D.plugin”
                                 Fresco 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                 Glass 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                 Glowing Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                 Google Earth 4 KMZ 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “U3D.plugin”
                                 Graphic Pen 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                 Halftone Pattern 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                              HDRMergeUI 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
                                 IFF Format 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                 Ink Outlines 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                 JPEG 2000 13.0.6 x001  ©2001-2013 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
                                 Kurtosis 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
                                 Lens Blur 13.0, Copyright © 2002-2012 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
                                 Lens Correction 13.0, Copyright © 2002-2012 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
                                 Lens Flare 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                 Liquify 13.0, Copyright © 2001-2012 Adobe Systems Incorporated - from the file “Liquify.plugin”
                                 Matlab Operation 13.0.6 x001  ©1993-2013 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
                                 Maximum 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
                                 Mean 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
                              Measurement Core 13.0.6 x001 ©1993-2013 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
                                 Median 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
                              Mezzotint 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                 Minimum 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
                                 MMXCore Routines 13.0.6 x001  ©1990-2013 Adobe Systems Incorporated - from the file “MMXCore.plugin”
                                 Mosaic Tiles 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                              Multiprocessor Support 13.0.6 x001 ©1990-2013 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
                                 Neon Glow 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                 Note Paper 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                 NTSC Colors 13.0.6 x001  ©1993-2013 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
                                 Ocean Ripple 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                 Oil Paint 13.0, Copyright © 2011 Adobe Systems Incorporated - from the file “Oil Paint.plugin”
                                 OpenEXR 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                 Paint Daubs 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                 Palette Knife 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                              Patchwork 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                 Paths to Illustrator 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                 PCX 13.0.6 x001  ©1989-2013 Adobe Systems Incorporated - from the file “PCX.plugin”
                              Photocopy 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                              Photoshop 3D Engine 13.0.6 x001 ©2006-2013 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
                                 Picture Package Filter 13.0.6 x001 ©1993-2013 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
                                 Pinch 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                 Pixar 13.0.6 x001  ©1989-2013 Adobe Systems Incorporated - from the file “Pixar.plugin”
                                 Plaster 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                 Plastic Wrap 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                 PNG 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                              Pointillize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                 Polar Coordinates 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                 Portable Bit Map 13.0.6 x001  ©1989-2013 Adobe Systems Incorporated - from the file “PBM.plugin”
                                 Poster Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                 Radial Blur 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                 Radiance 13.0.6 x001  ©2003-2013 Adobe Systems Incorporated - from the file “Radiance.plugin”
                                 Range 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
                                 Read Watermark NO VERSION - from the file “DigiRead.plugin”
                              Reticulation 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                 Ripple 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                 Rough Pastels 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                 Save for Web 13.0, Copyright © 1999-2012 Adobe Systems Incorporated - from the file “Save for Web.plugin”
                                 ScriptingSupport 13.0, Copyright © 2013 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
                                 Shear 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                 Skewness 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
                                 Smart Blur 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                 Smudge Stick 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                 Solarize 13.0.6 x001  ©1993-2013 Adobe Systems Incorporated - from the file “Solarize.plugin”
                                 Spatter 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                 Spherize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                 Sponge 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                 Sprayed Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                 Stained Glass 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                 Stamp 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                 Standard Deviation 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
                                 STL 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “U3D.plugin”
                                 Sumi-e 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                              Summation 13.0.6 x001 ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
                                 Targa 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                              Texturizer 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                 Tiles 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                 Torn Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                 Twirl 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                              Underpainting 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                              Vanishing Point 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
                                 Variance 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
                                 Water Paper 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                              Watercolor 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                 Wave 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                              Wavefront|OBJ 13.0.6 x001 ©2006-2013 Adobe Systems Incorporated - from the file “U3D.plugin”
                                 Wind 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                 Wireless Bitmap 13.0.6 x001  ©1989-2013 Adobe Systems Incorporated - from the file “WBMP.plugin”
                                 ZigZag 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                              Optional and third party plug-ins:
                                 Alien Skin Blow Up 3 Blow Up 3 3.0.0.672 20633 Copyright © 2011 Alien Skin Software, LLC - from the file “Alien Skin Blow Up 3 Automation.8li.plugin”
                                 Analog Efex Pro 1.0.11.180, Copyright ©2000-2014, Google - from the file “Analog Efex Pro.plugin”
                                 Analog Efex Pro 2 2.0.4.288, Copyright ©2000-2014, Google - from the file “Analog Efex Pro 2.plugin”
                              BackgroundFilter 2.2.16.288, Copyright ©2000-2014, Google - from the file “BackgroundFilter.plugin”
                                 Blow Up Blow Up 3 3.0.0.672 20633 Copyright © 2011 Alien Skin Software, LLC - from the file “Alien Skin Blow Up 3 Photoshop.8bf.plugin”
                                 Color Efex Pro 4 4.3.16.288, Copyright ©2000-2014, Google - from the file “Color Efex Pro 4.plugin”
                                 Dfine 2 2.2.16.288, Copyright ©2000-2014, Google - from the file “Dfine2.plugin”
                              FineStructuresFilter 2.2.16.288, Copyright ©2000-2014, Google - from the file “FineStructuresFilter.plugin”
                                 HDR Efex Pro 2 2.2.16.288, Copyright ©2000-2014, Google - from the file “HDR Efex Pro 2.plugin”
                                 Hidden Topaz Labs Denoise - from the file “TopazRemaskAutomate.plugin”
                              HotPixelsFilter 2.2.16.288, Copyright ©2000-2014, Google - from the file “HotPixelsFilter.plugin”
                                 Merge to HDR Efex Pro 2 2.2.16.288, Copyright ©2000-2014, Google - from the file “HDR Efex Pro 2 Automation.plugin”
                                 Nik Collection Selective Tool 2.1.21.288, Copyright ©2000-2014, Google - from the file “SelectivePalette.plugin”
                              ShadowsFilter 2.2.16.288, Copyright ©2000-2014, Google - from the file “ShadowsFilter.plugin”
                                 Sharpener Pro 3: (1) RAW Presharpener 3.1.16.288, Copyright ©2000-2014, Google - from the file “SHP3RPS.plugin”
                              Sharpener Pro 3: (2) Output Sharpener 3.1.16.288, Copyright ©2000-2014, Google - from the file “SHP3OS.plugin”
                                 Silver Efex Pro 2 2.2.16.288, Copyright ©2000-2014, Google - from the file “Silver Efex Pro 2.plugin”
                              SkinFilter 2.2.16.288, Copyright ©2000-2014, Google - from the file “SkinFilter.plugin”
                              SkyFilter 2.2.16.288, Copyright ©2000-2014, Google - from the file “SkyFilter.plugin”
                                 StrongNoiseFilter 2.2.16.288, Copyright ©2000-2014, Google - from the file “StrongNoiseFilter.plugin”
                                 Topaz Adjust 5 CS3 (10.0) ©1993-2007 Adobe Systems Incorporated - from the file “Topaz_adjust5.plugin”
                                 Topaz B&W Effects 2 CS3 (10.0) ©1993-2007 Adobe Systems Incorporated - from the file “Topaz_BW2_Effects.plugin”
                                 Topaz Clean 3 CS3 (10.0) ©1993-2007 Adobe Systems Incorporated - from the file “Topaz_clean3.plugin”
                                 Topaz DeJpeg 4 CS3 (10.0) ©1993-2007 Adobe Systems Incorporated - from the file “Topaz_dejpeg4.plugin”
                                 Topaz DeNoise 5 CS3 (10.0) ©1993-2007 Adobe Systems Incorporated - from the file “Topaz_denoise5.plugin”
                                 Topaz Detail 3 CS3 (10.0) ©1993-2007 Adobe Systems Incorporated - from the file “Topaz_detail3.plugin”
                                 Topaz InFocus CS3 (10.0) ©1993-2007 Adobe Systems Incorporated - from the file “Topaz_infocus.plugin”
                                 Topaz Lens Effects CS3 (10.0) ©1993-2007 Adobe Systems Incorporated - from the file “Topaz_Lens_Effects.plugin”
                                 Topaz ReMask 3 CS3 (10.0) ©1993-2007 Adobe Systems Incorporated - from the file “Topaz_remask3.plugin”
                                 Topaz Simplify 4 CS3 (10.0) ©1993-2007 Adobe Systems Incorporated - from the file “Topaz_simplify4.plugin”
                                 Viveza 2 2.1.16.288, Copyright ©2000-2014, Google - from the file “Viveza2.plugin”
                              WhiteWindowWorkaround 1.0.5, Copyright 2013-2014 - from the file “WhiteWindowWorkaround.plugin”
                              Plug-ins that failed to load: NONE
                              Flash:
                                 Gallery Wrapper
                                 Mini Bridge
                                 Kuler
                              Installed TWAIN devices: NONE
