1. Re: Adobe Connect UAC Pop Up Problems - Blocks Clicking
Jorma Jennings May 5, 2014 9:24 AM (in response to EGS IT - Greg)OK, to be fair, Connect is not an RDP application, and simply gives remote access to someones computer through the Flash Player. So, that said, UAC is doing exactly what it is supposed to, stopping someone from changing something on your computer. This is a Windows setting issue, not Connect. The UAC controls have prevented more interaction with the shared control function since Windows 7.
I wouldn't call it a known issue, but more of a known limitation of Windows. You can have the users click past the dialog (as you have mentioned) or reduce the setting of the UAC on their computer.
2. Re: Adobe Connect UAC Pop Up Problems - Blocks Clicking
EGS IT - Greg May 5, 2014 5:22 PM (in response to Jorma Jennings)Jorma Jennings wrote:
I appreciate you taking time to reply, however you completely ignored the main problem of this post and only focused on one subcategory that honestly isn't that big of an issue.
We have no problem getting by the popups. Asking people to click a button is easy. It's the fact that any screen that receives a UAC popup is completely inaccessible post message. If it has focus, the cursor stops working. After that window loses focus, we have control again. That's an issue.
Also, I'm aware there's a difference between remote desktop applications and using adobe connect as a remote app. But after allowing UAC access, no application should be inaccessible. That completely defeats the point of *allowing* access.
My question still stands and I'm hoping someone has some type of helpful solution or workaround to this problem.
