1 Reply Latest reply on May 5, 2014 2:00 AM by Adolfonaiz
    PercentLoaded returns negative value
    Juju75
      Hi there,
      I use some javascript on the website I'm working on to check if a swf file is loaded. I use the PercentLoaded method like explained here How should I judge that the flash has been loaded completed
      It works well except that sometimes the file loads until 50-70% and then PercentLoaded starts to return negative values. This seems to only happen with really large swf files, usually bigger than 30MB.
      Is there a reason to that? Is it a known issue? Is there a workaround?
      Thanks!
