0 Replies Latest reply on May 24, 2007 8:57 AM by Brandt_Wilson
    Consistent but random pitch changes
    Brandt_Wilson
      Hi all,
      I've just started using Captivate last week, so I'm still learning the ropes.
      My setup is this:
      Captivate 2.0
      Rode NT1-A mic
      M-Audio MobilePre amplifier
      When I record a full-screen demonstration, the record process works fine.
      However, if I do a project preview, the narration in some slides suddenly speeds up dramatically, sometimes in the middle of the slide. I take the audio out to Sound Forge 8.0 to perform a pitch shift of -12 to the affected part of the tracks to correct the audio, but the synchronization is all fouled up. Note that I have not done any single-slide scrubbing at this point.
      I also find that some of the relevant audio is on the slide preceding or proceding the one I want the audio to be associated with, so getting a good synch requires a complete audio remix between several slides to get proper timing.
      Is this a known issue? If so, what is the fix?
      Thanks a bunch!
      Brandt
