1 Reply Latest reply on May 30, 2007 4:18 AM by pgherveou
    Chart / Business Day
    pgherveou
      Hello
      Is there a way to use the DateAndTimeAxis or to create a subclass of it to display only business day
        • 1. Chart / Business Day
          pgherveou Level 1
          Hello
          As Flex does not provide "busines day" time and date axis. I finally used a category axis.
          My problem now is to display only key point date on the X axis.
          I tried to use the custom display label function above but I can fix the label size neither the unused ticks
          Is there a better way to do that ?
          thanks for your help
          public function labelFunction(categoryValue:Object, previousCategoryValue:Object, axis:CategoryAxis, categoryItem:Object):String {
          if (previousCategoryValue == null )
          return categoryValue.toString();
          var previousDate : Date = new Date(previousCategoryValue.toString());
          var currentDate : Date = new Date(categoryValue.toString());
          if (currentDate.date < previousDate.date)
          return formatter.format(currentDate);
          return "";
