0 Replies Latest reply on May 6, 2014 2:11 PM by Steven Boese
    Check if a single Text Item in a cell is bold and then grab the string that is bold
    Steven Boese
      I have written a script that runs through a table and parses out the information I need to create another table with some added information.
      The last piece that I can't seem to figure out is how to check if some text in a cell is bold and then grab said text to put in the new table.
      I will give a small table demo of what I am try to retrieve.
      Table A.
      Column 1Description
      123456This is a description (This is a note)
      789123
      This is a description (This is note A) (This is note B) (This is more stuff that isn't needed.
      Table B.
      Column 1Column 2Note
      1123456(This is a note)
      2789123(This is note A) (This is note B)
      I can pull all of the other information across that I am trying to get without any issue.
      I can't seem to figure out how to check the formatting of a TextItem to see if it is bold. I have been able to figure out how to check if a cell has bold text in it. using if ((tItems[counterVar].idata & Constants.FTF_WEIGHT) > 0). This ends up not working well because of a few issues. I was wondering if there is any way to check the formatting of a single character?
      I tried something similar to the following:
      prop_Change = tbl_Description_Cell.GetText(Constants.FTI_CharPropsChange);
      txt_String = tbl_Description_Cell.GetText(Constants.FTI_String);
      if (prop_Change.len > 0)
              if((prop_Change[0].idata & Constants.FTF_WEIGHT) > 0)
                      pOffset = prop_Change[0].offset;
                      for (var tbl_tItems = 0; tbl_tItems < txt_String.len; tbl_tItems++)
                              tOffset = txt_String[tbl_tItems].offset
                              if(tOffset == pOffset)
                                      alert(txt_String[tbl_tItems].sdata);
      Steven
