4 Replies Latest reply on Nov 21, 2014 12:05 PM by MSDN70
    Captive-runtime on nexus 5
    dennington-bear Newcomer
      Im using flash builder 4.6 but have tried on 4.7 too, using the captive runtime apk creation method.(I want air to install with my app not have a third party install) but its not working. I am testing this with a hello world app and I keep getting the message "unfortunately, (myappname) has stopped" I don't know how when this is a simple app. Ive looked at tutorials and updated the airSDK any ideas would be greatly appreciated!
      This is code for the mxml:
      <!-- Styles I think not sure -->
      <s:View xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:s="library://ns.adobe.com/flex/spark" title="Home">
      <fx:Declarations>
      <!-- Place non-visual elements (e.g., services, value objects) here -->
      </fx:Declarations>
      <!-- Basic structure of the app page -->
      <!-- Label on the screen -->
      <!-- Label onn the screen -->
      <s:Label text="HelloWorld"/>
      </s:View>
      This my xml file:
      <?xml version="1.0" encoding="utf-8" standalone="no"?>
      <application xmlns="http://ns.adobe.com/air/application/13.0">
      <!-- Adobe AIR Application Descriptor File Template.
        Specifies parameters for identifying, installing, and launching AIR applications.
        xmlns - The Adobe AIR namespace: http://ns.adobe.com/air/application/3.1
        The last segment of the namespace specifies the version
        of the AIR runtime required for this application to run.
        minimumPatchLevel - The minimum patch level of the AIR runtime required to run
        the application. Optional.
      <!-- A universally unique application identifier. Must be unique across all AIR applications.
        Using a reverse DNS-style name as the id is recommended. (Eg. com.example.ExampleApplication.) Required. -->
      <id>app</id>
      <!-- Used as the filename for the application. Required. -->
      <filename>app</filename>
      <!-- The name that is displayed in the AIR application installer.
        May have multiple values for each language. See samples or xsd schema file. Optional. -->
      <name>app</name>
      <!-- A string value of the format <0-999>.<0-999>.<0-999> that represents application version which can be used to check for application upgrade.
        Values can also be 1-part or 2-part. It is not necessary to have a 3-part value.
        An updated version of application must have a versionNumber value higher than the previous version. Required for namespace >= 2.5 . -->
      <versionNumber>0.0.0</versionNumber>
      <!-- A string value (such as "v1", "2.5", or "Alpha 1") that represents the version of the application, as it should be shown to users. Optional. -->
      <!-- <versionLabel></versionLabel> -->
      <!-- Description, displayed in the AIR application installer.
      <!-- <description></description> -->
      <!-- Copyright information. Optional -->
      <!-- <copyright></copyright> -->
      <!-- Publisher ID. Used if you're updating an application created prior to 1.5.3 -->
      <!-- <publisherID></publisherID> -->
      <!-- Settings for the application's initial window. Required. -->
      <initialWindow>
      <!-- The main SWF or HTML file of the application. Required. -->
      <!-- Note: In Flash Builder, the SWF reference is set automatically. -->
      <content>[This value will be overwritten by Flash Builder in the output app.xml]</content>
      <!-- The title of the main window. Optional. -->
      <!-- <title></title> -->
      <!-- The type of system chrome to use (either "standard" or "none"). Optional. Default standard. -->
      <!-- <systemChrome></systemChrome> -->
      <!-- Whether the window is transparent. Only applicable when systemChrome is none. Optional. Default false. -->
      <!-- <transparent></transparent> -->
      <!-- Whether the window is initially visible. Optional. Default false. -->
      <!-- <visible></visible> -->
      <!-- Whether the user can minimize the window. Optional. Default true. -->
      <!-- <minimizable></minimizable> -->
      <!-- Whether the user can maximize the window. Optional. Default true. -->
      <!-- <maximizable></maximizable> -->
      <!-- Whether the user can resize the window. Optional. Default true. -->
      <!-- <resizable></resizable> -->
      <!-- The window's initial width in pixels. Optional. -->
      <!-- <width></width> -->
      <!-- The window's initial height in pixels. Optional. -->
      <!-- <height></height> -->
      <!-- The window's initial x position. Optional. -->
      <!-- <x></x> -->
      <!-- The window's initial y position. Optional. -->
      <!-- <y></y> -->
      <!-- The window's minimum size, specified as a width/height pair in pixels, such as "400 200". Optional. -->
      <!-- <minSize></minSize> -->
      <!-- The window's initial maximum size, specified as a width/height pair in pixels, such as "1600 1200". Optional. -->
      <!-- <maxSize></maxSize> -->
      <!-- The initial aspect ratio of the app when launched (either "portrait" or "landscape"). Optional. Mobile only. Default is the natural orientation of the device -->
      <!-- <aspectRatio></aspectRatio> -->
      <!-- Whether the app will begin auto-orienting on launch. Optional. Mobile only. Default false -->
      <!-- <autoOrients></autoOrients> -->
      <!-- Whether the app launches in full screen. Optional. Mobile only. Default false -->
      <!-- <fullScreen></fullScreen> -->
      <!-- The render mode for the app (either auto, cpu, gpu, or direct). Optional. Default auto -->
      <!-- <renderMode></renderMode> -->
      <!-- Whether or not to pan when a soft keyboard is raised or lowered (either "pan" or "none"). Optional. Defaults "pan." -->
      <!-- <softKeyboardBehavior></softKeyboardBehavior> -->
      <autoOrients>true</autoOrients>
      <fullScreen>false</fullScreen>
      <visible>true</visible>
      <softKeyboardBehavior>none</softKeyboardBehavior>
      </initialWindow>
      <!-- We recommend omitting the supportedProfiles element, -->
      <!-- which in turn permits your application to be deployed to all -->
      <!-- devices supported by AIR. If you wish to restrict deployment -->
      <!-- (i.e., to only mobile devices) then add this element and list -->
      <!-- only the profiles which your application does support. -->
      <!-- <supportedProfiles>desktop extendedDesktop mobileDevice extendedMobileDevice</supportedProfiles> -->
      <!-- The subpath of the standard default installation location to use. Optional. -->
      <!-- <installFolder></installFolder> -->
      <!-- The subpath of the Programs menu to use. (Ignored on operating systems without a Programs menu.) Optional. -->
      <!-- <programMenuFolder></programMenuFolder> -->
      <!-- The icon the system uses for the application. For at least one resolution,
        specify the path to a PNG file included in the AIR package. Optional. -->
      <!-- <icon>
        <image16x16></image16x16>
        <image32x32></image32x32>
        <image36x36></image36x36>
        <image48x48></image48x48>
        <image57x57></image57x57>
        <image72x72></image72x72>
        <image114x114></image114x114>
        <image128x128></image128x128>
        </icon> -->
      <!-- Whether the application handles the update when a user double-clicks an update version
        of the AIR file (true), or the default AIR application installer handles the update (false).
      <!-- <customUpdateUI></customUpdateUI> -->
      <!-- Whether the application can be launched when the user clicks a link in a web browser.
      <!-- <allowBrowserInvocation></allowBrowserInvocation> -->
      <!-- Listing of file types for which the application can register. Optional. -->
      <!-- <fileTypes> -->
      <!-- Defines one file type. Optional. -->
      <!-- <fileType> -->
      <!-- The name that the system displays for the registered file type. Required. -->
      <!-- <name></name> -->
      <!-- The extension to register. Required. -->
      <!-- <extension></extension> -->
      <!-- The description of the file type. Optional. -->
      <!-- The MIME content type. -->
      <!-- <contentType></contentType> -->
      <!-- The icon to display for the file type. Optional. -->
      <!-- <icon>
        </icon> -->
      <!-- </fileType> -->
      <!-- </fileTypes> -->
      <!-- iOS specific capabilities -->
      <!-- <iPhone> -->
      <!-- A list of plist key/value pairs to be added to the application Info.plist -->
      <!-- <InfoAdditions>
        <![CDATA[
        <key>UIDeviceFamily</key>
        <array>
        <string>1</string>
        <string>2</string>
        </array>
        <key>UIStatusBarStyle</key>
        <string>UIStatusBarStyleBlackOpaque</string>
        <key>UIRequiresPersistentWiFi</key>
        <string>YES</string>
        </InfoAdditions> -->
      <!-- A list of plist key/value pairs to be added to the application Entitlements.plist -->
      <!-- <Entitlements>
        <![CDATA[
        <key>keychain-access-groups</key>
        <array>
        <string></string>
        <string></string>
        </array>
        </Entitlements> -->
      <!-- Display Resolution for the app (either "standard" or "high"). Optional. Default "standard" -->
      <!-- <requestedDisplayResolution></requestedDisplayResolution> -->
      <!-- </iPhone> -->
      <!-- Specify Android specific tags that get passed to AndroidManifest.xml file. -->
      <!--<android> -->
      <!-- <manifestAdditions>
        <![CDATA[
        <manifest android:installLocation="auto">
        <uses-permission android:name="android.permission.INTERNET"/>
        <uses-permission android:name="android.permission.WRITE_EXTERNAL_STORAGE"/>
        <uses-permission android:name="android.permission.ACCESS_FINE_LOCATION"/>
        <uses-feature android:required="true" android:name="android.hardware.touchscreen.multitouch"/>
        <application android:enabled="true">
        <activity android:excludeFromRecents="false">
        <intent-filter>
        <action android:name="android.intent.action.MAIN"/>
        <category android:name="android.intent.category.LAUNCHER"/>
        </intent-filter>
        </activity>
        </application>
        </manifest>
        </manifestAdditions> -->
      <!-- Color depth for the app (either "32bit" or "16bit"). Optional. Default 16bit before namespace 3.0, 32bit after -->
      <!-- <colorDepth></colorDepth> -->
      <!-- </android> -->
      <!-- End of the schema for adding the android specific tags in AndroidManifest.xml file -->
      <android>
      <colorDepth>16bit</colorDepth>
      <manifestAdditions><![CDATA[
      <!--See the Adobe AIR documentation for more information about setting Google Android permissions-->
      <!--Removing the permission android.permission.INTERNET will have the side effect
        of preventing you from debugging your application on your device-->
      <!--<uses-permission android:name="android.permission.WRITE_EXTERNAL_STORAGE"/>-->
      <!--<uses-permission android:name="android.permission.READ_PHONE_STATE"/>-->
      <!--<uses-permission android:name="android.permission.ACCESS_FINE_LOCATION"/>-->
      <!--The DISABLE_KEYGUARD and WAKE_LOCK permissions should be toggled together
        in order to access AIR's SystemIdleMode APIs-->
      <!--<uses-permission android:name="android.permission.DISABLE_KEYGUARD"/>-->
      <!--<uses-permission android:name="android.permission.WAKE_LOCK"/>-->
      <!--<uses-permission android:name="android.permission.CAMERA"/>-->
      <!--<uses-permission android:name="android.permission.RECORD_AUDIO"/>-->
      <!--The ACCESS_NETWORK_STATE and ACCESS_WIFI_STATE permissions should be toggled
        together in order to use AIR's NetworkInfo APIs-->
      <!--<uses-permission android:name="android.permission.ACCESS_NETWORK_STATE"/>-->
      <!--<uses-permission android:name="android.permission.ACCESS_WIFI_STATE"/>-->
      <!--Removing the permission android.permission.INTERNET will have the side effect of preventing you from debugging your application on your device-->
      <!--The DISABLE_KEYGUARD and WAKE_LOCK permissions should be toggled together in order to access AIR's SystemIdleMode APIs-->
      <!--The ACCESS_NETWORK_STATE and ACCESS_WIFI_STATE permissions should be toggled together in order to use AIR's NetworkInfo APIs-->
      </manifest>
      </android>
      <iPhone>
      <InfoAdditions><![CDATA[
      <array>
      <string>1</string>
      <string>2</string>
      </array>
      </InfoAdditions>
      <requestedDisplayResolution>high</requestedDisplayResolution>
      </iPhone>
      </application>
      The AIRSDK version says 13.0 on the readme so I assume thats the one i am using
