10 Replies Latest reply on May 12, 2014 1:21 AM by Shraddha Prajapati
    QueryToJson
    Shraddha Prajapati
      Hi i want to convert Query object into json data::
      But i got this type record:
      [{"PRODUCTNAME":"2014 Kia Cadenza Premium 4dr Sedan (3.3L 6cyl 6A)","PRODUCTCATEGORYID":1,"PRODUCTID":1},{"PRODUCTNAME":"2014 Chevrolet Cruze Diesel 4dr Sedan (2.0L 4cyl Turbodiesel 6A)","PRODUCTCATEGORYID":1,"PRODUCTID":2}]
      And I wan  to this type record::
      [{"ProductName":"2014 Kia Cadenza Premium 4dr Sedan (3.3L 6cyl 6A)","ProductCategoryId":1,"ProductId":1},{"ProductName":"2014 Chevrolet Cruze Diesel 4dr Sedan (2.0L 4cyl Turbodiesel 6A)","ProductCategoryId":1,"ProductId":2}]
      I want Field name according to my Table Column Name...(Not all characters of columns are capital like above)
      my code:
      QueryToJson.cfm
      <!DOCTYPE html>
      <html>
        <body>
      <cfscript>
        myJSON=new Component.queryTojson().queryToJSON();
      </cfscript>
        <cfdump var="#myJSON#" >
        </body>
      </html>
      queryTojson.cfc
      <cfcomponent>
      <cffunction name="queryToJSON" returntype="string" access="public" output="yes">
        <cfquery name="getallproducts" datasource="TestingDataSource">
           SELECT TOP 2 * from Product;
          </cfquery>
        <cfset var o=ArrayNew(1)>
        <cfset var i=0>
        <cfset var r=0>
        <cfloop query="getallproducts">
          <cfset r=Currentrow>
          <cfloop index="i" list="#(getallproducts.columnList)#">
            <cfset o[r][i]=Evaluate(i)>
          </cfloop>
        </cfloop>
          <cfreturn SerializeJSON(o)>
      </cffunction>
      </cfcomponent>
      Product(Table)
      ProductId
      ProductCategoryId
      ProductName
        • 1. Re: QueryToJson
          Steve Sommers Level 4
          Query column names and structure key names are capitalized in CF and I that is just something you have to deal with. There is one exception with structures that I am aware of:
               <cfset variables.s.FieldName="abc" />
          will be capitalized when using StructKeyList() whereas
               <cfset variables.s["FieldName"]="abc" />
          will preserve the upper/lower case. I'm not aware of any such exception with query column names.
          If I have full control of the end using the json data, I send the column names through LCase() and just deal with lower case names. Other than that, the only other option is to create a hard coded field name translater: PRODUCTID--> ProductId.
          Hope this helps.
          • 2. Re: QueryToJson
            BKBK Adobe Community Professional & MVP
            You could use replaceList() on the resulting JSON string. It does a case-sensitive replacement.
            <cfsavecontent variable="jsonString">
            </cfsavecontent>
            <cfset list1="PRODUCTNAME,PRODUCTCATEGORYID,PRODUCTID,PRODUCTNAME">
            <cfset list2="ProductName,ProductCategoryId,ProductId,ProductName">
            <cfset newJsonString = replaceList(jsonString,list1,list2)>
            <p><cfoutput>#newJsonString#</cfoutput></p>
            • 3. Re: QueryToJson
              Hmmm. I've never used (or knew about) replaceList() -- learn something new everyday. I'll have to file that in my arsenal of tricks.
              • 4. Re: QueryToJson
                Shraddha Prajapati Level 1
                Only this way replaceList(), i can do this , Have you any other way???
                • 5. Re: QueryToJson
                  Hi, i try to write queryTojson.cfc in script format:
                  component
                    public string function queryToJSON() output="yes"
                    q = new Query();
                    q.setdataSource("TestingDataSource");
                    q.setsql("SELECT * FROM Product");
                    qResult = q.execute().getresult();
                    o=ArrayNew(1);
                    i=0;
                    r=0;
                    x=0;
                    for(x=1;x LTE qResult.recordcount;x=x+1)
                    r=qresult.Currentrow;
                    var l = ListLen(qResult.Columnlist);
                       for (i = 1; i lte l; i = i + 1)  // you also can use i++ instead
                        o[r][i]=Evaluate(i);
                    jsonString = SerializeJSON(o);
                    return jsonString;
                  But i got the output in this format:
                  [{"3":3,"2":2,"1":1}]
                  How to write queryTojson.cfc in script format??
                  • 6. Re: QueryToJson
                    You are getting that output because r remains fixed. The dynamic value of row number you should use in setting rows in o is x, not r. You could modify the code as follows:
                    var q = new Query();
                    var qResult = "";
                    var colList = "";
                    var l = 0;
                    var x = 0;
                    var i = 0;
                    var o=ArrayNew(1);
                    colList = qResult.Columnlist;
                    l = ListLen(colList);
                    for(x=1;x LTE qResult.recordcount;x=x+1) // x is row number
                        columnName = listGetAt(colList,i);
                        o[x][i]=qResult[columnName][x];
                    return jsonString;
                    Anyway, why do you serialize an array representation of the result-set? You can just serialize the result-set itself directly, like this:
                    var qResult = "";
                    jsonString = SerializeJSON(qResult);
                    return jsonString;
                    • 7. Re: QueryToJson
                      Yet another suggestion: use a struct instead of an array. A struct would give more information, as it can hold the column name as key. Here is the struct version of your code:
                      var qResult = "";
                      var colList = "";
                      var l = 0;
                      var x = 0;
                      var i = 0;
                      var str=structNew();
                          str[x][columnName]=qResult[columnName][x];
                      jsonString = SerializeJSON(str);
                      return jsonString;
                      • 8. Re: QueryToJson
                        Hi , Thanks for your reply....
                        Your 1St Method, i got this type output:
                        [{"3":"2014 Kia Cadenza Premium 4dr Sedan (3.3L 6cyl 6A)","2":1,"1":1},{"3":"2014 Chevrolet Cruze Diesel 4dr Sedan (2.0L 4cyl Turbodiesel 6A)","2":2,"1":1}]
                        And Your 2nd Method, i got this type output:
                        {"COLUMNS":["PRODUCTID","PRODUCTCATEGORYID","PRODUCTNAME"],"DATA":[[1,1,"2014 Kia Cadenza Premium 4dr Sedan (3.3L 6cyl 6A)"],[2,1,"2014 Chevrolet Cruze Diesel 4dr Sedan (2.0L 4cyl Turbodiesel 6A)"]]}
                        And your 3rd method struct version , in this i got following output:
                        {"2":{"PRODUCTNAME":"2014 Chevrolet Cruze Diesel 4dr Sedan (2.0L 4cyl Turbodiesel 6A)","PRODUCTCATEGORYID":1,"PRODUCTID":2},"1":{"PRODUCTNAME":"2014 Kia Cadenza Premium 4dr Sedan (3.3L 6cyl 6A)","PRODUCTCATEGORYID":1,"PRODUCTID":1}}
                        But actually i want to get this type of json output, because its suit for kendo Model:
                        Have you any other script code to get this type of json Data, from Query object???
                        • 9. Re: QueryToJson
                          What you want is so close to the third result, it requires just a slight change in that code.
                          var qResult = "";
                          var colList = "";
                          var l = 0;
                          var x = 0;
                          var i = 0;
                          var arr=arrayNew(1);
                              arr[x]=str[x]; // each row x is stored in the array arr as a struct
                          jsonString = SerializeJSON(arr);
                          return jsonString;
                          • 10. Re: QueryToJson
                            Thanks its work...
