12 Replies Latest reply: May 12, 2014 9:18 AM by Muppet Mark RSS
    Activating Browser window from within an InDesign Javascript
    Roy Marshall Community Member
      Hi All
      A part of a Javascript I have inherited, relies on Applescript to call to open the active Safari/Chrome window, and extract some information, then use this in the JS with InDesign.
      What I would like to do is eliminate AS altogether, as this restricts me to using Macs, and would like to open this up to PC users too.
      I know I can do a platform query, and may be an option to use VBScript to do the equivalent AS routine. I have absolutely no experience with VBScript, so would need some help if this is the option.
      Ideally I would like to stay as native JS, but that may be wishful thinking on my part.
      Here is a sample of the AS I am using within a doScript:
      tell application "Safari"
      activate
      set imagePath to do JavaScript "frames[2].frames[1].document.links[0].href" in document 1
      end tell
      then...
      tell application "InDesign"
      activate
      end tell
      Does anyone know if this may be possible?
      Cheers
      Roy
        • 2. Re: Re: Activating Browser window from within an InDesign Javascript
          pixxxel schubser Community Member
          Searching the forum you can find examples like this (written by Muppet Mark):
          // OpenBrowserWithJavascript.jsx
          // siehe http://forums.adobe.com/message/4904789#4904789
          openURL( 'www.google.com' );
          function openURL( address ) {
                    var f = File( Folder.temp + '/aiOpenURL.url' );
                    f.open( 'w' );
                    f.write( '[InternetShortcut]' + '\r' + 'URL=http://' + address + '\r' );
                    f.close();
                    f.execute();
          Have fun
          • 3. Re: Activating Browser window from within an InDesign Javascript
            Laubender Community Member
            @pixxxel schubser – that code by Muppet Mark is working very well.
            Thank you for sharing the link.
            Leaves the question: Is it possible to determine a specific browser but the one the operating system is chosing?
            On my Mac OSX 10.6.8 I'd like to open a particular URL not in Safari, but in Firefox.
            Firefox seems to be my default browser, because if I saved a website to my file system and double click the *.html file I will always get Firefox (even if it's *not* already open).
            With the script above executed Safari will open.
            I did not find a control for that behavior in my OSX 10.6.8.
            Uwe
            • 4. Re: Activating Browser window from within an InDesign Javascript
              Hallo Uwe,
              kannst du überprüfen, mit welchem Standardprogramm dein Dateityp *.url verknüpft ist?
              Oder noch einfacher: suche einfach nach der vom Skript angelegten "aiOpenURL" Internetverknüpfung und öffne dann die Informationen am Mac bzw. die Eigenschaften unter Windows dieser Datei ( Die im Screenshot beispielhaft gezeigte "aiOpenURL" ist der im OpenBrowser-Skript vergebene Name für die Url)
              Hello Uwe,
              can you check, which is the standard programm for the file format *.url?
              Viele Grüße
              pixxxelschubser
              • 5. Re: Activating Browser window from within an InDesign Javascript
                Jacob_Marshall Community Member
                Sadly, if you read the original post, you will see that Roy does not need to open a new page, he needs to extract information from a browser window that is already open by the user. This is a specific requirement, in which Muppet Mark's script does not correctly solve.
                • 6. Re: Re: Activating Browser window from within an InDesign Javascript
                  Hi pixxxel Schubser
                  thanks for the reply, but what I am really needing (if possible) is a way to extract information from the current page open in the browser, then return the results back to ID for actions.
                  do you know of a way to do this without resorting to AS?
                  thanks again
                  Royston.
                  • 7. Re: Activating Browser window from within an InDesign Javascript
                    @pixxxelschubser – thank you for that tip. But it didn't work as expected with Firefox.
                    I changed it back to Safari. And that was working quite well.
                    See what happened.
                    First I set file type url to open with Firefox with a text file renamed with *.url instead of *.txt. Clicked "Change All":
                    (Change should affect all files with file type url, not only that particular one)
                    Then I ran the code from ESTK. Firefox started (good!), but was showing the contents of the file (not so good!).
                    Firfox did not open the url contained by the file:
                    Uwe
                    • 8. Re: Activating Browser window from within an InDesign Javascript
                      Muppet Mark Community Member
                      Hum, the forum emails you when mentioned… I didn't write that function… Probably/very likely a lift off one of the Ps boys…
                      That said I don't think what Roy wants can be done in just extendscript…
                      • 9. Re: Re: Re: Activating Browser window from within an InDesign Javascript
                        Jump_Over Community Member
                        There is a function created by Rorohiko Man - Kris Coppieters - kris@rorohiko.com
                        It writes url body contents into .txt file. No browser involved.
                        Playing with TXT could lead you to "extract information"
                        Code below uses this function:
                        var
                          mFolder = "~/Documents",
                          url = "http://sport.interia.pl/bundesliga/news-robert-lewandowski-krolem-strzelcow-bundesligi,nId,1423502",
                          fileName = url.split("/"),
                          fileName = fileName[fileName.length - 1],
                          mFile = File(mFolder + "/" + fileName + ".txt");
                        var urlData = GetURL(url, false);
                        if (urlData != null && urlData.body != null) {
                          mFile.open("w");
                          mFile.write(urlData.body);
                          mFile.close();
                        function GetURL(url,isBinary)
                          // This function consists of up to three 'nested' state machines.
                          // At the lowest level, there is a state machine that interprets UTF-8 and
                          // converts it to Unicode - i.e. the bytes that are received are looked at
                          // one by one, and the Unicode is calculated from the one to four bytes UTF-8
                          // code characters that compose it.
                          // The next level of state machine interprets line-based data - this is
                          // needed to interpret the HTTP headers as they are received.
                          // The third level state machine interprets the HTTP reply - based on the
                          // info gleaned from the headers it will process the HTTP data in the HTTP
                          // reply
                          // If things go wrong, GetURL() will return a null
                          var reply = null;
                          // Below some symbolic constants to name the different states - these
                          // make the code more readable.
                          const kUTF8CharState_Complete = 0;
                          const kUTF8CharState_PendingMultiByte = 1;
                          const kUTF8CharState_Binary = 2;
                          const kLineState_InProgress = 0;
                          const kLineState_SeenCR = 1;
                          const kProtocolState_Status = 1;
                          const kProtocolState_Headers = 2;
                          const kProtocolState_Body = 3;
                          const kProtocolState_Complete = 4;
                          const kProtocolState_TimeOut = 5;
                          do
                            // Chop the URL into pieces
                            var parsedURL = ParseURL(url);
                            // We only know how to handle HTTP - bail out if it is something else
                            if (parsedURL.protocol != "HTTP")
                              break;
                            // Open up a socket, and set the time out to 2 minutes. The timeout
                            // could be parametrized - I leave that as an exercise.
                            var socket = new Socket;
                            socket.timeout = 120;
                            // Open the socket in binary mode. Sockets could also be opened in UTF-8 mode
                            // That might seem a good idea to interpret UTF-8 data, but it does not work out
                            // well: the HTTP protocol gives us a body length in bytes. If we let the socket
                            // interpret UTF-8 then the body length we get from the header, and the number of
                            // characters we receive won't match - which makes things quite awkward.
                            // So we need to use BINARY mode, and we must convert the UTF-8 ourselves.
                            if (! socket.open(parsedURL.address + ":" + parsedURL.port,"BINARY"))
                              break;
                            // Dynamically build an HTTP 1.1 request.
                            if (isBinary)
                              var request =
                                "GET /" + parsedURL.path + " HTTP/1.1\n" +
                                "Host: " + parsedURL.address + "\n" +
                                "User-Agent: InDesign ExtendScript\n" +
                                "Accept: */*\n" +
                                "Connection: keep-alive\n\n";
                            else
                              var request =
                                "Accept: text/xml,text/*,*/*\n" +
                                "Accept-Encoding:\n" +
                                "Connection: keep-alive\n" +
                                "Accept-Language: *\n" +
                                "Accept-Charset: utf-8\n\n";
                            // Send the request out
                            socket.write(request);
                            // readState keeps track of our three state machines
                            var readState =
                              buffer: "",
                              bufPos: 0,
                              // Lowest level state machine: UTF-8 conversion. If we're handling binary data
                              // the state is set to kUTF8CharState_Binary which is a 'stuck' state - it
                              // remains in that state all the time. If the data really is UTF-8 the state
                              // flicks between kUTF8CharState_PendingMultiByte and kUTF8CharState_Complete
                              curCharState: isBinary ? kUTF8CharState_Binary : kUTF8CharState_Complete,
                              curCharCode: 0,
                              pendingUTF8Bytes: 0,
                              // Second level state machine: allows us to handle lines and line endings
                              // This state machine can process CR, LF, or CR+LF line endings properly
                              // The state flicks between kLineState_InProgress and kLineState_SeenCR
                              lineState: kLineState_InProgress,
                              curLine: "",
                              line: "",
                              isLineReadyToProcess: false,
                              // Third level state machine: handle HTTP reply. This state gradually
                              // progresses through kProtocolState_Status, kProtocolState_Headers,
                              // kProtocolState_Body, kProtocolState_Complete.
                              // contentBytesPending is part of this state - it keeps track of how many
                              // bytes of the body still need to be fetched.
                              protocolState: kProtocolState_Status,
                              contentBytesPending: null,
                              dataAvailable: true,
                              // The HTTP packet data, chopped up in convenient pieces.
                              status: "",
                              headers: {},
                              body: ""
                            // Main loop: we loop until we hit kProtocolState_Complete as well as an empty data buffer
                            // (meaning all data has been processed) or until something timed out.
                            while
                              ! (readState.protocolState == kProtocolState_Complete && readState.buffer.length <= readState.bufPos)
                              readState.protocolState != kProtocolState_TimeOut
                              // If all data in the buffer has been processed, clear the old stuff
                              // away - this makes things more efficient
                              if (readState.bufPos > 0 && readState.buffer.length == readState.bufPos)
                                readState.buffer = "";
                                readState.bufPos = 0;
                              // If there is no data in the buffer, try to get some from the socket
                              if (readState.buffer == "")
                                // If we're handling the body of the HTTP reply, we can try to optimize
                                // things by reading big blobs of data. Also, we need to look out for
                                // completion of the transaction.
                                if (readState.protocolState == kProtocolState_Body)
                                  // readState.contentBytesPending==null means that the headers did not
                                  // contain a length value for the body - in which case we need to process
                                  // data until the socket is closed by the server
                                  if (readState.contentBytesPending == null)
                                    if (! readState.dataAvailable && ! socket.connected)
                                      // The server is finished with us - we're done
                                      socket = null;
                                      readState.protocolState = kProtocolState_Complete;
                                    else
                                      // Attempt to read a byte
                                      readState.buffer += socket.read(1);
                                      readState.dataAvailable = readState.buffer.length > 0;
                                  else
                                    // If the socket is suddenly disconnected, the server pulled the
                                    // rug from underneath us. Register this as a time out problem and
                                    // bail out.
                                      socket = null;
                                      readState.protocolState = kProtocolState_TimeOut;
                                    else
                                      // Try to get as much data as needed from the socket. We might
                                      // receive less than we've asked for.
                                      readState.buffer = socket.read(readState.contentBytesPending);
                                      readState.contentBytesPending -= readState.buffer.length;
                                      // Check if we've received as much as we were promised in the headers
                                      // If so, we're done with the socket.
                                      if (readState.contentBytesPending == 0)
                                        socket.close();
                                        socket = null;
                                      // If we're downloading binary data, we can immediately shove the
                                      // whole buffer into the body data - there's no UTF-8 to worry about
                                      if (isBinary)
                                        readState.body += readState.buffer;
                                else if (readState.protocolState != kProtocolState_Complete)
                                  // We're reading headers or status right now - look out
                                  // for server disconnects
                                    socket = null;
                                  else
                              // The previous stretch of code got us as much data as possible into
                              // the buffer (but that might be nothing, zilch). If there is data,
                              // we process a single byte here.
                              if (readState.buffer.length > readState.bufPos)
                                // Fetch a byte
                                var cCode = readState.buffer.charCodeAt(readState.bufPos++);
                                switch (readState.curCharState)
                                  case kUTF8CharState_Binary:
                                    // Don't use the UTF-8 state machine on binary data
                                    readState.curCharCode = cCode;
                                    readState.multiByteRemaining = 0;
                                    break;
                                  case kUTF8CharState_Complete:
                                    // Interpret the various UTF-8 encodings - 1, 2, 3, or 4
                                    // consecutive bytes encode a single Unicode character. It's all
                                    // bit-fiddling here: depending on the masks used, the bytes contain
                                    // 3, 4, 5, 6 bits of the whole character.
                                    // Check
                                    // http://en.wikipedia.org/wiki/UTF-8
                                    if (cCode <= 127)
                                    else if ((cCode & 0xE0) == 0xC0)
                                      readState.curCharCode = cCode & 0x1F;
                                      readState.curCharState = kUTF8CharState_PendingMultiByte;
                                      readState.pendingUTF8Bytes = 1;
                                    else if ((cCode & 0xF0) == 0xE0)
                                      readState.curCharCode = cCode & 0x0F;
                                      readState.pendingUTF8Bytes = 2;
                                    else if ((cCode & 0xF8) == 0xF0)
                                      readState.curCharCode = cCode & 0x07;
                                      readState.pendingUTF8Bytes = 3;
                                    else
                                      // bad UTF-8 char
                                      readState.pendingUTF8Bytes = 0;
                                    break;
                                  case kUTF8CharState_PendingMultiByte:
                                    if ((cCode & 0xC0) == 0x80)
                                      readState.curCharCode = (readState.curCharCode << 6) | (cCode & 0x3F);
                                      readState.pendingUTF8Bytes--;
                                      if (readState.pendingUTF8Bytes == 0)
                                        readState.curCharState = kUTF8CharState_Complete;
                                    else
                                      // bad UTF-8 char
                                    break;
                                // If we've got a complete byte or Unicode char available, we process it
                                if (readState.curCharState == kUTF8CharState_Complete || readState.curCharState == kUTF8CharState_Binary)
                                  cCode = readState.curCharCode;
                                  var c = String.fromCharCode(readState.curCharCode);
                                  if (readState.protocolState == kProtocolState_Body || readState.protocolState == kProtocolState_Complete)
                                    // Once past the headers, we simply append new bytes to the body of the HTTP reply
                                    readState.body += c;
                                  else
                                    // While reading the headers, we look out for CR, LF or CRLF sequences
                                    if (readState.lineState == kLineState_SeenCR)
                                      // We saw a CR in the previous round - so whatever follows,
                                      // the line is now ready to be processed.
                                      readState.line = readState.curLine;
                                      readState.isLineReadyToProcess = true;
                                      readState.curLine = "";
                                      readState.lineState = kLineState_InProgress;
                                      // The CR might be followed by another one, or
                                      // it might be followed by a LF (which we ignore)
                                      // or any other character (which we process).
                                      if (cCode == 13) // CR
                                        readState.lineState = kLineState_SeenCR;
                                      else if (cCode != 10) // no LF
                                        readState.curLine += c;
                                    else if (readState.lineState == kLineState_InProgress)
                                      // If we're in the midsts of reading characters and we encounter
                                      // a CR, we switch to the 'SeenCR' state - a LF might or might not
                                      // follow.
                                      // If we hit a straight LF, we can process the line, and get ready
                                      // for the next one
                                      else if (cCode == 10) // LF
                                      else
                                        // Any other character is appended to the current line
                                    if (readState.isLineReadyToProcess)
                                      // We've got a complete line to process
                                      readState.isLineReadyToProcess = false;
                                      if (readState.protocolState == kProtocolState_Status)
                                        // The very first line is a status line. After that switch to
                                        // 'Headers' state
                                        readState.status = readState.line;
                                        readState.protocolState = kProtocolState_Headers;
                                      else if (readState.protocolState == kProtocolState_Headers)
                                        // An empty line signifies the end of the headers - get ready
                                        // for the body.
                                        if (readState.line == "")
                                          readState.protocolState = kProtocolState_Body;
                                        else
                                          // Tear the header line apart, and interpret it if it is
                                          // useful (currently, the only header we process is 'Content-Length'
                                          // so we know exactly how many bytes of body data will follow.
                                          var headerLine = readState.line.split(":");
                                          var headerTag = headerLine[0].replace(/^\s*(.*\S)\s*$/,"$1");
                                          headerLine = headerLine.slice(1).join(":");
                                          headerLine = headerLine.replace(/^\s*(.*\S)\s*$/,"$1");
                                          readState.headers[headerTag] = headerLine;
                                          if (headerTag == "Content-Length")
                                            readState.contentBytesPending = parseInt(headerLine);
                                            if (isNaN(readState.contentBytesPending) || readState.contentBytesPending <= 0)
                                              readState.contentBytesPending = null;
                                            else
                                              readState.contentBytesPending -= (readState.buffer.length - readState.bufPos);
                            // If we have not yet cleaned up the socket we do it here
                            if (socket != null)
                              socket.close();
                              socket = null;
                            reply =
                              status: readState.status,
                              headers: readState.headers,
                              body: readState.body
                          while (false);
                          return reply;
                        function ParseURL(url)
                          url=url.replace(/([a-z]*):\/\/([-\._a-z0-9A-Z]*)(:[0-9]*)?\/?(.*)/,"$1/$2/$3/$4");
                          url=url.split("/");
                          if (url[2] == "undefined") url[2] = "80";
                          var parsedURL =
                            protocol: url[0].toUpperCase(),
                            address: url[1],
                            port: url[2],
                            path: ""
                          url = url.slice(3);
                          parsedURL.path = url.join("/");
                          if (parsedURL.port.charAt(0) == ':')
                            parsedURL.port = parsedURL.port.slice(1);
                          if (parsedURL.port != "")
                            parsedURL.port = parseInt(parsedURL.port);
                          if (parsedURL.port == "" || parsedURL.port < 0 || parsedURL.port > 65535)
                            parsedURL.port = 80;
                          parsedURL.path = parsedURL.path;
                          return parsedURL;
                        TXT should be written in MyDocuments folder. File is named using last part of URL.
                        It need a few seconds to run (15 on my side)
                        Jarek
                        • 10. Re: Re: Re: Re: Activating Browser window from within an InDesign Javascript
                          @Jarek – just tested the posted code by Kris with your suggested url, that should lead to Robert Lewandowski :-)
                          The script generated a txt file. Took a little longer to write the file. About 60 seconds.
                          However the file generated was empty.
                          0 Bytes.
                          Checked the URL with my browser. No problem. Cmd+u in Firefox was showing the html code. Ok. Nothing unusual.
                          <!DOCTYPE html><!--[if lt IE 7]> <html class="no-js ie6 oldie" lang="pl"> <![endif]-->
                          <!--[if IE 7]>    <html class="no-js ie7 oldie" lang="pl"> <![endif]-->
                          <!--[if IE 8]>    <html class="no-js ie8 oldie" lang="pl"> <![endif]-->
                          <!--[if gt IE 8]><!--> <html class="no-js" lang="pl"> <!--<![endif]-->
                          <head>
                          <meta charset="UTF-8">
                          Then I tried with a differnt url. This time a www address of my favourite pub here in my hometown.
                          A rather small web site.
                          That worked.
                          Here some lines of html revealed by the browser:
                          <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
                          <html xmlns="http://www.w3.org/1999/xhtml" lang="en" xml:lang="en">
                          <head>
                           <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
                          vs. the code in the text file written:
                          <head>
                          No difference to spot. Also all used special characters used in the html, like umlauts, were written well (not presented here).
                          But I had to be careful what encoding I have to chose when opening the file by TextEdit.app on OSX 10.6.8.
                          "Automatic" did not work. Therefore double-clicking the file generated an error message, that something's wrong with the encoding of UTF8.
                          Then I tried with "Western Europe (Mac OS Roman)".
                          That finally did the trick. :-)
                          So, I have one positive sample and one negative one.
                          Jarek, I think, you tested that code with that particular url and it worked fine for you.
                          What to make out of this now?
                          Uwe
                          • 11. Re: Activating Browser window from within an InDesign Javascript
                            OK. Ill wait a little longer, but it looks like I cant do what I need simply in JS.
                            The difference in my request and the answers suggested is I already have the page open in the browser, and need to get at the variable data hidden in the page.
                            I will wait a little longer to see if any one else has an ideas, otherwise I will assume it cannot be done.
                            Thanks anyway.
                            Roy
                            • 12. Re: Activating Browser window from within an InDesign Javascript
                              This is what I suspected… Your problem lies with the URL of of the already open browser… Do your main code in JS and call out a do script to get this string…?
