0 Replies Latest reply on May 7, 2014 12:30 PM by schiuma24
    xml not going to the right frame
    schiuma24 Level 1
      Here's the deal, Im trying to automate a layout.
      I have managed to:
      • Create the right number of pages
      • Create text frames
      • Populate text frames
      The populate text frame workflow is the following:
      Create a text frame with a script label to later match it with an xml attribute
      For example <myXMLelement output class = "sidebar"> would go into a text frame with a sidebar_content script label.
      The Problem:
      I have several "sidebar" elements on a page and I created several tex frames with its corresponding label for them,
      and all the XML elements get into the layout....BUT ON THE SAME TEXT FRAME!!!! $%@#%^&@
      the first "sidebar" gets into de first frame and then gets replaced by the next "sidebar" and so on.
      here is the complete code (the red part is where I think the problem is):
      main();
      function main(){
      ///////////TEMPLATE SELECTION DIAGLOG
      var myWorkFolder = Folder("/Applications/Adobe InDesign CS5.5/Scripts/Scripts Panel/Samples/JavaScript"); // working folder
      var showWorkFolder = Boolean(true); // shows(true)/hides(false) working folder in dialog
      var myPath = Folder("/Applications/Adobe InDesign CS5.5/Scripts/Scripts Panel/Samples/JavaScript");
      var strWinTitle = String("Library opener");
      var strWorkFolder = String("Working folder:");
      var strSelectLib = String("Select Template:");
      var strNoFiles = String("-- No libraries found --"); // shows if no libraries found
      ///////////////////////// SCRIPT /////////////////////////
      var myFiles = myWorkFolder.getFiles("*.indt");
      var myFilesNo = myFiles.length;
      var myLibFiles = Array();
      if(!myFilesNo){
           myLibFiles[0] = strNoFiles;
      }else{
           for(var i=0; i < myFilesNo; i++){
                myLibFiles.push(myFiles[i].displayName.substr(0,myFiles[i].displayName.lastIndexOf("."))) ;
      var myDialog = app.dialogs.add({name:strWinTitle, canCancel:true});
           with(myDialog){
                with(dialogColumns.add()){
                     if(showWorkFolder){
                          with(dialogRows.add()){
                               with(borderPanels.add()){
                                    staticTexts.add({staticLabel:strSelectLib});
                                    var myLib = dropdowns.add({stringList:myLibFiles, selectedIndex:0});
      if(myDialog.show() == true){
           if(myFilesNo){
                app.open(File(myFiles[myLib.selectedIndex]),true);
      myDialog.destroy();
      ///////END OF DIALOG////////////////////////////////////////////////
      /////opes xml file/////////////////////////////////
      myDoc.importXML(File.openDialog());
        var fileSep = "/";
      //Where fileSep is "/" you can change it though if you are on windows.
      if(File.fs=="Windows")
           fileSep = "\\";
      if (myDoc.pages.length != 1 )
            alert("This script must be run on an empty doc");
          exit();
          //discover how many pages
        var xml = myDoc.xmlElements[0];
      //////*****MAKES XPATH HAPPY AND COOPERATIVE*****////////////////////////////////////
      if( !xml.xmlAttributes.itemByName("xmlns:xml").isValid )
      xml.xmlAttributes.add( "xmlns:xml", "http://www.w3.org/XML/1998/namespace" );
      if( !xml.xmlAttributes.itemByName("xmlns:aid").isValid )
      xml.xmlAttributes.add( "xmlns:aid", "http://ns.adobe.com/Adobe InDesign/4.0/" );
      if( !xml.xmlAttributes.itemByName("xmlns:aid5").isValid )
      xml.xmlAttributes.add( "xmlns:aid", "http://ns.adobe.com/Adobe InDesign/5.0/" );
        var ditas= xml.evaluateXPathExpression("//page[string-length(@id) > 1]/ancestor::dita");
        var maxPage =0;
        var minPage = ditas[0].xmlElements.item("learningBECContent").xmlElements.item("learningBECContentbody" ).xmlElements.item("page").xmlAttributes.itemByName("id").value.replace("p","").replace(" ","");
        myDoc.documentPreferences.startPageNumber  = parseInt(minPage);
           for(x=1;x < ditas.length; x++)
      try{
      var page = ditas[x].xmlElements.item("learningBECContent").xmlElements.item("learningBECContentbody" ).xmlElements.item("page").xmlAttributes.itemByName("id").value.replace("p","").replace(" ","");
      //alert(page);
      maxPage = Math.max(minPage,maxPage);
      catch(e){
          page = "dita "+ x + " no page specified";
      $.writeln(maxPage + " Max page in this xmlfile");
        // add that many pages
      for (x=minPage; x <= maxPage;x++){
          if(x==1)
              myPage = myDoc.pages[0];
              else
              myPage = myDoc.pages.add();
          ////////ADDS TEXT FRAMES TO A.-Master (default master spread)
                             //var myMasterPage = myDoc.masterSpreads.itemByName("A-Master");
                             var myMainBodyRight = myDoc.textFrames.add();
                             var mySideBarRight1 = myDoc.textFrames.add();
                             var mySideBarRight2 = myDoc.textFrames.add();
                             var mySideBarRight3 = myDoc.textFrames.add();
                             var myMainBodyLeft = myDoc.textFrames.add();
                             var mySideBarLeft1 = myDoc.textFrames.add();
                             var mySideBarLeft2 = myDoc.textFrames.add();
                             var mySideBarLeft3 = myDoc.textFrames.add();
        ///////////FRAMES PARAMETERS////////////////////////////////////////////////////////////////
                             ///////////RIGHT SIDE//////////////////////////
                             myMainBodyRight.geometricBounds = ["0.4224 in", "3.5066 in", "10.985 in", "8.506 in"];
        mySideBarRight1.geometricBounds = ["0.4224 in", "15.34 in", "2.93 in", "18 in"];
        mySideBarRight2.geometricBounds = ["3.09 in", "15.34 in", "5.6 in", "18 in"];
        mySideBarRight3.geometricBounds = ["5.77 in", "15.34 in", "8.2 in", "18 in"];
                            myMainBodyRight.label = "body_content";
        mySideBarRight1.label = "sidebar_content";
                             mySideBarRight2.label = "sidebar_content";
        mySideBarRight3.label = "sidebar_content";
                             ///////////LEFT SIDE///////////////////////////
                            myMainBodyLeft.geometricBounds = ["0.4224 in", "10 in", "10.9 in", "15 in"];
        mySideBarLeft1.geometricBounds = ["0.4224 in", ".5 in", "2.93 in", "3.5 in"];
        mySideBarLeft2.geometricBounds = ["3.09 in", ".5 in", "5.6 in", "3.5 in"];
        mySideBarLeft3.geometricBounds = ["5.77 in", ".5 in", "8.2 in", "3.5 in"];
                            myMainBodyLeft.label = "body_content";
        mySideBarLeft1.label = "sidebar_content";
                             mySideBarLeft2.label = "sidebar_content";
        mySideBarLeft3.label = "sidebar_content";
                            /////////GET THE XML IN//////////////////////////////////////////////////////////////////
                                              var allTextFrames = toArray(myDoc.textFrames);
                                              var bodyTextFrames = selectWhere("body_content", "label", allTextFrames);
                                              var sidebarTextFrames = selectWhere("sidebar_content", "label", allTextFrames);
                                              var bodyDitas= xml.evaluateXPathExpression("//dita[not(@outputclass='sidebar')]");
                                              var sidebarDitas= xml.evaluateXPathExpression("//dita[@outputclass='sidebar']");
                                              $.writeln( ditas.length + " ditas");
                                              $.writeln( bodyDitas.length + " body ditas");
                                              $.writeln( sidebarDitas.length + " sidebar ditas");
                                              $.writeln( bodyTextFrames.length + " body_content textframes in this doc");
                                              $.writeln( sidebarTextFrames.length + " sidebar_content textframes in this doc");
                                              //Fill TextFrames on page[//dita//page/@id] with ditas based on //dita/@outputclass until you run out of frames or content
                                              for(x=0;x < Math.min(allTextFrames.length, ditas.length) ;x++)
                                              try{
                                                  var type= ditas[x].xmlAttributes.itemByName("outputclass").value;
                                              catch(e){
                                                  page = "1";
                                              $.writeln("proc page "+ page + " as "+ type);
                                              try{
                                              if(type == "sidebar")
                                                    var pageBodyTextFrames = selectWhere("sidebar_content", "label", myDoc.pages[page-parseInt(minPage)].textFrames);
                                              else
                                              var pageBodyTextFrames = selectWhere("body_content", "label", myDoc.pages[page-parseInt(minPage)].textFrames);
                                              var newTextFrame = pageBodyTextFrames[0];
                                              ditas[x].placeXML(newTextFrame);
                                              catch(e){
                                                  $.writeln("Error on page "+page+ " discarding");
                                                  $.writeln(e.message);
                                              //app.doScript(new File(app.activeScript.parent.fsName+fileSep+"FindChangeByList.jsx"), ScriptLanguage.javascript);
                                              function addThreadedTextFrame(page, frame){
                                              var threadTextFrame = page.textFrames.add({geometricBounds:[0, 0, 1 + ' in', 1 + ' in']});
                                              threadTextFrame.move( [20, 0 ] );
                                              frame.nextTextFrame = threadTextFrame;
                                              return threadTextFrame;
                                              function selectWhere(value, key, array){
                                                  var i = array.length; var t; var filtered = [];
                                                  while(i--){
                                                          t = array[i];
                                                          if(t && t[key] == value){
                                                              filtered.push(t);
                                                  return filtered;
                                              function toArray(objects){
                                                  var i = objects.length; var array = [];
                                                  while(i--){
                                                          array.push(objects[i]);
                                                  return array;
                                              function countTheseElements(xmlfrag, xpath){
                                              var c = 0;
                                              for(x=0; x < xmlfrag.length;x++)
                                                      $.writeln(xmlfrag[x].xmlElement[0].length);
