0 Replies Latest reply: May 8, 2014 8:48 AM by ks1014 RSS
    CF11 and ODBC socket DSN creation error
    ks1014 Community Member
      I recently installed CF11 (Enterprise in Trial mode) on a new Server 2012 R2 system. I have an ERP application that uses a Progress database. I installed the vendor specific 64bit ODBC driver (Progress OpenEdge 10.2B) and configured it in the 64bit ODBC Data Source Mgr on the server. I tested the connection from within the Data Source Mgr and it was successful. When I attempt to create a DSN in CF11 though the vendor specific driver does not appear in the dropdown list. I tried to create a DSN using "ODBC Socket" and filled in the same "Data Source Name" as that used in the OS's Data Source Mgr, but after a minute or so this error appears, "The ColdFusion ODBC Server service is not running or has not been installed." I confirmed that the CF11 ODBC Server and Agent services are running on this server so I am not sure why this error is claiming otherwise.
      I would greatly appreciate any assistance on this. I was able to create a MS SQL DSN in CF11 with no problem, so at least some are working.
      Kevin
