4 Replies Latest reply on May 10, 2014 3:08 AM by Atiqur Sumon
    Can't get this droplet to save a JPEG...
    ophello
      I'm getting an error that it can't find the document after it's opened. The actions seem to run just fine, but it stops short of actually saving the file into the newly created folder. It also doesn't close the last document.
      Can anyone find a problem with my script? I seem to have hit a brick wall here.
      (I'm running Photoshop CS6.)
      ____________
      on open mgItems
           set myDate to (get current date)
           set y to year of myDate as text
           set m to month of myDate as integer
           set d to day of myDate as integer
           if d < 10 then
                set d to "0" & d as text
           else
                set d to d as text
           end if
           if m < 10 then
                set m to "0" & m as text
           else
                set m to m as text
           end if
      set y to text -2 thru -1 of y
      set myReleaseDate to y & m & d & "_iPadResized"
      repeat with mgThisItem in mgItems
           tell application "System Events"
                set targetFolderPath to path of container of disk item (mgThisItem as text)
           end tell
           tell application "Adobe Photoshop CS6"
                activate
                try
                     open mgThisItem
                set mgDocName to name of current document
                set text item delimiters of AppleScript to ".tif"
                set mgShortName to text item 1 of mgDocName
                set mgPackageFilePath to targetFolderPath & myReleaseDate
                my createFolders(POSIX path of file (mgPackageFilePath))
                set display dialogs to never
                set thisdoc to current document
                set docHeight to height of thisdoc
                set docWidth to width of thisdoc
                tell thisdoc
                     flatten document
                     if docHeight / docWidth > 0.75 then
                          do action "iPad_tall" from "iPad Resize"
                     else
                          do action "iPad_wide" from "iPad Resize"
                     end if
                     save in file mgPackageFilePath as JPEG with options {quality:12}
                end tell
                close the current document saving no
             on error e
                  display dialog e
             end try
        end tell
      end repeat
      display dialog "Files resized for iPad"
      end open
      on createFolders(pathString)
           do shell script "mkdir -p " & quoted form of pathString
      end createFolders
