16 Replies Latest reply on May 14, 2014 11:09 PM by Flex harUI
    Module shrink issue
    jfb00 Pioneer
      Hi All,
      My app have a menu, each option of the menu call a module as:
      public function itemClickHandler(event:MenuEvent):void{
           switch(event.label){
                          case "MenuA":
                              loadModule("ModuleA.swf");
                              break;
                          default:
                              break;
      public function loadModule(moduleName:String):void{
                 myModule.unloadModule();
                          myModule.url= moduleName+'?_ts='+fileTimestamp;
                          myModule.loadModule();
      <s:ModuleLoader id="myModule" width="100%" height="100%" url="Home.swf?_ts=" unload="chkDirty()" />
      This particular Module shrink. Other modules doesn't have this issue.
      The module Shrink more every time finish the remote call of data from a loop.
      Here is my module:
      <s:Module xmlns:fx="http://ns.adobe.com/mxml/2009"
                xmlns:mx="library://ns.adobe.com/flex/mx"
                creationComplete="init()"
                width="100%" height="100%">
          <fx:Script>
              <![CDATA[
      public function init():void{
                      //load styles
                      this.styleManager.loadStyleDeclarations("styles/styles.swf",true);
      private function refreshData():void{
                      arrayLength ++;
                      if (arrayLength < 4){
                          SM_RO.getData();
                     }else{
                          //pass data to datagrid
      //I try this without luck:
      this.percentHeight = 100;
      this.percentWidth = 100;
      private function getData_Handler(event:ResultEvent):void{
           refreshData();
          </fx:Script>
      <fx:Declarations>
              <mx:RemoteObject id="SM_RO" destination="ColdFusion" source="{cfcPath}" concurrency="multiple" >
                  <mx:method name="getData" result="getData_Handler(event)" fault="FlexGlobals.topLevelApplication.error_Handler(event)" concurrency="multiple" />
            </mx:RemoteObject>
      </fx:Declarations>
      <mx:Panel width="100%" height="100%" title="{winTitle}" >
              <mx:ComboBox id="rmc_cb" rowCount="15" visible="false" ></mx:ComboBox>
              <grids:ExtendedAdvancedDataGrid ...
      </mx:Panel>
      </s:Module>
      I am using FB 4.7 with SDK 4.11. Does anyone have the same issue? Is anything like this reported before?
      Any ideas?
      Thanks!
