• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
missing images
New Here ,
May 17, 2007 May 17, 2007
I have a Word doc that I inherited, did some editing on it, replaced some images, and imported to Robohelp HTML.
When I generate the project most of my images do not display.
Oddly, some do, and I can't seem to find a reason why or why not.
I replaced some images in the source WORD doc via a paste from the clipboard. I probably also replaced some images in RoboHelp - also via a paste from the clipboard.
But - there seems to be no rhyme nor reason to which ones display (though I'm sure that's not true - I just don't know the reason).
Some images that do show are ones that I inserted (into the source doc - probably, but maybe into Robohelp) and some were in the doc when I inherited it.
I looked at the TrueCode, and all the references look the same: <img src="image014.jpg"....
But the directories on my local machine seem to have all the image files, while the ones on the file share where I generate has just the subset.
I'm hesitant to play with it alot, because when I generate my TOC pretty much goes away (only has the first book ) and rebuilding it is a major hassle.
But that's another problem - think I'll go post that separately.
Thanks for any help you can give me.
Oh - one more thing. If I right-click on an image or on a non-image in the generated version and select Properties, the file reference includes a path to my local machine.
Gail
I have probably passted some fromthe clipboard directly into Robohelp (again - pasting from ther clipboard).
I can't say that those are in and the others aren't though - because some of the ones that do appear are images that were in the Word doc when I inherited it.
Text Text
Views
420
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
If the path is absolute this is the reason why the images are not diplayed in the help. Change the path to a relative one and see what happens.
Votes
Translate
Translate
Report
Report
New Here ,
Ummm. how?
Votes
Translate
Translate
Report
Report
LEGEND ,
If you double click on an image in the RH topic, what shows as the path there? Is it the same path as in the output? Something like C:\Image1.jpg won't work if the output is in a different location. Typically when you add an image in RH, it is copied into the project directory and therefore is visible when the output is generated (i.e. it has a relative path). By cutting & pasting from your PC clipboard, the path created in Robohelp has got confused - not in the project directory. It would be better if you had saved the images to a directory and then added them. You may have to capture the images again and reload them. Let us know how you get on.
Votes
Translate
Translate
Report
Report
New Here ,
When I double click on an image in WYSIWYG, the image name is something like: image014.jpg, and it says 'Images in Project Folders:' with something like 'Data Display Files' in the drop down box.
There are many images in there - some that got copied to the publish site, and some not.
I'm hoping to find out how to get them all published - hoping that I'm not going to have to re-insert all of them. Am I dreaming?
Gail
Votes
Translate
Translate
Report
Report
LEGEND ,
LATEST
OK now we are getting somewhere. If the images are located in the Data Display Files folder in your project then the path to them - in the image Name field should be Data Display Files\image014.jpg. Try adding the path and report back.
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
