2 Replies Latest reply on May 9, 2014 2:59 PM by George_Johnson
    Acrobat Pro 9/Livecycle Desinger ES2 versus Acrobat Pro XI/Livecycle Desinger ES4
    maninblack
      We have a form that was created in Livecycle Desinger ES2 some time ago and we want to create a very similar form in Livecycle Desinger ES4, in particular a "submit" button that utilizes javascript.  I created a new "submit" button using Livecycle Desinger ES4.  I copied the javascript from the form created in Livecycle Desinger ES2 into Livecycle Desinger ES4.  When we open the form in Acrobat Pro XI and select the "submit" button, we get a window entitled "Check Names" that opens and reads Microsoft Outlook does not recognize "1.  Double-click the attachment."  As a first time used of javascript I am pretty lost.
      Below is the javascript, any idea what causes the issue?
      topmostSubform.Page1.Button2::click - (JavaScript, client)
      //@@SUBMITURL "mailto:christopher.fagan@mascocabinetry.com?subject=Submitting Completed Form&body=Instructions to add this form to a responses file:\n1. Double-click the attachment.\n2. Acrobat will prompt you to select a responses file.&ui=false"
      AdobePatentID="B643"
      var AdobePatentID = "AdobePatentID=\"B643\"";
      // initiate some constants
      var METADATA_ANNOT_NAME     = "adhocFormState";
      var PROP_RESPONDENT_NAME    = "respondentName";
      var PROP_RESPONDENT_EMAIL   = "respondentEmail";
      var currentDoc;
      if (typeof(xfa) == "object")
          currentDoc = event.target;
      else
          currentDoc = this;
      // Only on Viewer/Reader older than 9.0, we'll do the following tasks.
      var bAnonymous = false;
      var bContinue = true;
      if (app.viewerVersion < 9.0) {
          // show the email/name dialog if not anonymous
          if (!bAnonymous && !currentDoc.dynamicXFAForm) {
              var result = currentDoc.askUserIdentity(currentDoc);
              if (result == null)
                  bContinue = false;
              else {
                  var annot = currentDoc.getAnnot(0, METADATA_ANNOT_NAME);
                  if (annot != null) {
                      var arrProps = new Array();
                      arrProps = annot.contents.split(";");
                      currentDoc.setProperty(arrProps, PROP_RESPONDENT_NAME, result.name);
                      currentDoc.setProperty(arrProps, PROP_RESPONDENT_EMAIL, result.email);
                      annot.contents = arrProps.join(";");
          // show the select client dialog
          if (bContinue) {
              var result = currentDoc.askEmailClient(currentDoc);
              if (result == null)
                  bContinue = false;
              else if (!result.send)  {
                  app.execMenuItem("SaveAs");
                  bContinue = false;
      // submit the form
      if (bContinue) {
          var rawURL = "slpapprovals@mascocabinetry.com?subject=Submitting Completed Form&body=Instructions to add this form to a responses file:\n1. Double-click the attachment.\n2. Acrobat will prompt you to select a responses file.&ui=false";
          var submitURL;
              submitURL = "mailto:" + rawURL;
          else
              submitURL = "mailto:" + escape(rawURL);
          currentDoc.submitForm({
              cURL: submitURL,
              cSubmitAs: "PDF"
