2 Replies Latest reply on May 14, 2014 6:21 AM by Willam van Weelden
    Will Robohelp 7 projects work with Robohelp 11?
    mlkuhnpdx
      Are there any compatibility issues with doing this?   I have some Robohelp 7 files to work with and am wondering if I should upgrade to Robohelp 11.   Thanks!
        • 1. Re: Will Robohelp 7 projects work with Robohelp 11?
          Jeff_Coatsworth Adobe Community Professional & MVP
          They should upgrade fine – just make sure that you have a backup copy made in case anything goes sideways ;>)
          Test out a copy of your RH 7 projects on a trial copy of RH11 to experiment.
          • 2. Re: Will Robohelp 7 projects work with Robohelp 11?
            Willam van Weelden Adobe Community Professional & MVP
            Just to add, after you upgrade from RoboHelp 7, run the Tools > Update
            DHTML effects in topics option. This is required because RoboHelp 7 has
            a different topic structure than later versions.
            Also, during upgrading from RoboHelp 7, I have encountered the error
            that .apj could not be found or openend. This happens on
            legacy projects created prior to RH7. If you encounter this, here's how
            to fix it:
            - Remove the project and restore from backup.
            - Create a new, blank project in RoboHelp 7.
            - Copy the missing file from the blank RH7 project into your project.
            - Try upgrading again. It will work fine now.
            Kind regards,
            Willam
