0 Replies Latest reply on May 17, 2007 7:23 AM by kdavisAtDuke
    Optimization bug
    kdavisAtDuke
      I am using the Flex Builder 2.01 Eclipse plugin on a MacBook Pro. I have some code which takes an object tree and recursively wraps all of the Array properties of objects to ArrayCollections. So for example, the tree starts with an object Foo, which has a bunch of properties on it. One of these properties could be an Array. This Array property will be replaced by an ArrayCollection, and then for each object in the array, the same process is performed. Here is some example code:
      public static function convertObject( o:Object ):Object
      var classInfo:XML = describeType( o );
      if ( classInfo.@name.toString() == "Object" )
      for ( var key:String in o )
      var value:Object = o[key];
      if ( value is Array )
      o[key] = convertToArrayCollection( o, value as Array );
      return o;
      public static function convertToArrayCollection( parent:Object, value:Array ):ArrayCollection
      var arrayCollection:ArrayCollection = new ArrayCollection();
      arrayCollection.source = value;
      for ( var i:int = 0; i < value.length; i++ )
      convertObject( value , changeListener );
      return ArrayCollection(arrayCollection);
      So, when I use the default compiler settings in Flex Builder 2.01, this will intermittently fail. The behavior I get is that when I iterate through the properties of the object I am converting, some of the properties are not there, and other properties are duplicated. So for example, if my object has these properties:
      foo
      bar
      myarray
      When I iterate through all the properties, I get
      foo
      bar
      foo
      bar
      instead of
      foo
      bar
      myarray
      I first tried to debug this issue, thinking there was some problem with my code. But whenever I ran the debug version, I didn't see the problem. Finally, under compiler options, I set -debug=true and -optimize=false and the problem appears to have went away. So, it appears that there is some problem with the optimization in the compiler.
