• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
Error 105 - while compiling with adt
Participant ,
May 10, 2014 May 10, 2014
I am getting this error "error 105: application.iPhone.InfoAdditions contains an invalid value"
while packaging my application with adt for ios.
The command I used is this "c:\Program Files\Adobe\Adobe Flash CS5.5\AIR2.6\bin\adt" -package -target ipa-ad-hoc -provisioning-profile VCPDevelopmentProvProfile.mobileprovision -storetype pkcs12 -keystore VCP.p12 -storepass PASSWORD vcp.ipa TestAir-app.xml TestAir.swf
while the contents of TestAir-app.xml are as mentioned below. Can someone please point out the problem as this is really hampering our work (Thanks in advance).
<?xml version="1.0" encoding="UTF-8" standalone="no" ?>
<application xmlns="http://ns.adobe.com/air/application/13.0">
  <id>in.co.canon.coe.vcp</id>
  <versionNumber>1.0</versionNumber>
  <filename>TestAir</filename>
  <description/>
  <!-- To localize the description, use the following format for the description element.<description><text xml:lang="en">English App description goes here</text><text xml:lang="fr">French App description goes here</text><text xml:lang="ja">Japanese App description goes here</text></description>-->
  <name>TestAir</name>
  <!-- To localize the name, use the following format for the name element.<name><text xml:lang="en">English App name goes here</text><text xml:lang="fr">French App name goes here</text><text xml:lang="ja">Japanese App name goes here</text></name>-->
  <copyright/>
  <initialWindow>
    <content>TestAir.swf</content>
    <systemChrome>standard</systemChrome>
    <transparent>false</transparent>
    <visible>true</visible>
    <fullScreen>false</fullScreen>
    <aspectRatio>landscape</aspectRatio>
    <renderMode>auto</renderMode>
    <autoOrients>false</autoOrients></initialWindow>
  <icon/>
  <customUpdateUI>false</customUpdateUI>
  <allowBrowserInvocation>false</allowBrowserInvocation>
  <iPhone>
    <InfoAdditions>
      <![CDATA[<key>UIDeviceFamily</key><array><string>1</string><string>2</string></array>]]>
    </InfoAdditions>
    <requestedDisplayResolution>standard</requestedDisplayResolution>
  </iPhone>
</application>
Thanks and Regards,
Nitesh
TOPICS
Development
Views
1.8K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Beginner ,
Apr 17, 2015 Apr 17, 2015
same things.... +1
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Can you provide the sample.swf and -app.xml files , so that we could test it locally ?
-Tushar,
Adobe AIR team
Votes
Translate
Translate
Report
Report
Thank you for reply.
I provide files.
http://quq.jp/fb_project.zip
It's a flash builder project files. included swf,xml.
error screen shot:
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Apr 19, 2015 Apr 19, 2015
Hi EknDesign,
Can you please upload the above files on Dropbox? The above site doesn't seem to be accessible from here, and I'm unable to download the sample project.
-Tushar
EDIT : Never mind, I managed to get the files. Thanks.
-Tushar
Votes
Translate
Translate
Report
Report
Apr 20, 2015 Apr 20, 2015
Hi.
Dropbox link is here.
Dropbox - fb_project.zip‌
thank you.
Votes
Translate
Translate
Report
Report
Aug 04, 2015 Aug 04, 2015
LATEST
Hi
I tried to move
/Library/Java/Extensions/ *.* files to another location.
It was fix in my case.
These files were required in other my projects.
Thank you!
Votes
Translate
Translate
Report
Report
May 25, 2015 May 25, 2015
I found error log! (AIR SDK 17)
stack trace:
java.lang.Exception:
/Users/xxxxx/Documents/works/fb_project/bin-debug/AOT/game1-app.xml(72): error 105: application.iPhone.InfoAdditions contains an invalid value
  at com.adobe.flexide.multiplatform.ios.launching.IOSLaunchHandler.doPackage(IOSLaunchHandler.java:704)
  at com.adobe.flexide.multiplatform.ios.launching.IOSLaunchHandler.launch(IOSLaunchHandler.java:255)
  at com.adobe.flexide.launching.multiplatform.MultiPlatformLaunchDelegate.launch(MultiPlatformLaunchDelegate.java:184)
  at com.adobe.flexide.launching.AbstractFlexLaunchDelegate.launch(AbstractFlexLaunchDelegate.java:244)
  at com.adobe.flexide.launching.AbstractFlexLaunchDelegate.launch(AbstractFlexLaunchDelegate.java:134)
  at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:854)
  at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:703)
  at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(DebugUIPlugin.java:928)
  at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlugin.java:1132)
  at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
session data:
eclipse.buildId=M20110909-1335
java.version=1.6.0_65
java.vendor=Apple Inc.
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=ja_JP
Framework arguments:  -keyring /Users/xxxxx/.eclipse_keyring -showlocation
Command-line arguments:  -os macosx -ws cocoa -arch x86_64 -keyring /Users/xxxxx/.eclipse_keyring -consoleLog -showlocation
Votes
Translate
Translate
Report
Report
New Here ,
Jun 12, 2015 Jun 12, 2015
Hi guys
Any update on this? I am hitting the same thing.
I am using
  <requestedDisplayResolution excludeDevices="iPad3,1 iPad3,2 iPad3,3 iPad3,4 iPad3,5 iPad3,6">standard
Votes
Translate
Translate
Report
Report
LEGEND ,
What you are doing is the opposite of what you're supposed to do. You need to set the requested resolution to be 'high' to comply with Apple requirements. But you can then add devices in the exclude list where you don't want them to be Retina. I think you could just remove the whole exclude list.
Votes
Translate
Translate
Report
Report
New Here ,
Jun 13, 2015 Jun 13, 2015
Now that makes sense. I'm wondering how I missed that!
Thank you.
Votes
Translate
Translate
Report
Report
