2 Replies Latest reply on May 11, 2014 1:21 AM by Noel Carboni
    viewing images on hi res monitor
    pjdphoto
      Hello everyone...
      I am new to this forum. I have a question that might be easy for some of you to explain.  I am using a dell 30 " monitor
      that has a  resolution of 2560 x 1600. When I am working in Bridge, viewing full screen produces a fuzzy picture but
      viewing at 100% produces a sharp picture but it is zoomed in too much. Is it possible to see the sharp picture but using
      the entire screen? Or is it not possible because that would distort the image. Once I save an image as a JPEG and
      I can utilize the whole screen and it is sharp. But while in bridge/photoshop full screen produces fuzzy image vs. viewing at 100%
      which produces a sharp one but zoomed in too close to appreciate the whole image. thanks for any help
        • 1. Re: viewing images on hi res monitor
          The only time you see the actual image pixels is when your viewing zoomed to 100%.  At any other zoom level your looking as a scale image not the actual image.  Print size image when view at 100% will not fit on your display for it can only display 2560x1600  a 4.1Mp  8:5 aspect ratio.  Most digital cameras even cell Phone capture images with more pixels and usually have a 4:3 or 3:2 aspect ratio images  some will also capture smaller image sized to HDTV a 16:9 aspect ratio 1920x1080 pixels  2.1 MP these will fit on your display and be a closer match to your display's 16:10 aspect ratio.
          If your working on a large or small image you can have Photoshop zoom it to fit on your display there will be border for image Aspect Ration and Your Displays area aspect ratio will differ .  If you zoom it to fill the screen  the zoom level will be above or below 100% the image will be softer if above 100% then the actual image.  Adobe Photoshop uses a quick scaling so the scaled image is not the best it could be scaled.  If you want to see a better display size image you could re-size the image up or down in size resampling the image you have with a interpolation method like bicubic or bicubic smoother.   The image will be better then Photoshop zooming the image.  But remember every time you resample an image you loose some image quality. Not a single original pixel remains you have a completely new image interpolated from an other.  I do not recommend resampling your image to fit on your low 100 ppi resolution display.
          When you print the image at a higher resolution then your display's 100PPI the printed image will be sharper and smaller then the image displayed on  your display.
          • 2. Re: viewing images on hi res monitor
            Noel Carboni Level 8
            There are settings in Bridge that govern the quality of the preview.  Change those, clear the cache, and see whether that helps you with the quality.
            -Noel
