1 Reply Latest reply on May 11, 2014 5:05 AM by Ned Murphy
    convert swf/fla
    fransman_83
      I have a problem with Flash converting. I have a one swf file that will not open in Adobe Flash. The problem , however, is the following . I want to edit swf file and to access the fla file , I use Sothink decompiler where I convert the same Swf file to fla . When I convert the file in decompiler 7.0 , I get to choose which flash format , from 6.0 to 12.0, I want to use. what I choose for version does not seem to matter ( except that the converter nobody seems gone well ) , the result is a failure when I then made my changes in the fla file in adobe flash and want to save it to the swf in the same program. following text is displayed several times :
      The problem occurs when I want to save. Wrong to . Swf in adobe flash . following problems appear repeatedly :
      / Applications / Adobe Flash CS6/Common/Configuration/Component Source / ActionScript 3.0/FLVPlayback/fl/video/UIManager.as , Line 449 1120 : Access of undefined property PLAYER .
      when I click on the error , I can edit the CONFIG :: PLAYER {
      besides it is also shown :
      / Applications / Adobe Flash CS6/Common/Configuration/Component Source / ActionScript 3.0/FLVPlayback/fl/video/UIManager.as , Line 452 1120 : Access of undefined property AIR.
      CONFIG :: Air {
      I convert fla file in the PC and Opens the adobe flash in mac . but don't thinks that's the problem
