6 Replies Latest reply on May 12, 2014 1:27 AM by Laubender
    Please correct my Hyphenation setting script
    hasvi Level 1
      1. I want to set hyphenation=false for all the heading levels, That heading level details are saved in .txt file format. For instance 'Heading detail.txt' has heading level paragraph style names: H1, H2, BT, CT, CN.
      2. Otherwise if hyphenation=true in normal paragraph styles (like TX, EXT) I have to change the hyphenation setting. This one I have completed as like below script
      app.activeDocument.paragraphStyles.everyItem().properties={
          hyphenateWordsLongerThan:6,
          hyphenateAfterFirst:3,
          hyphenateBeforeLast:3,
          hyphenateLadderLimit:2,
          hyphenationZone:"1p",
          hyphenateCapitalizedWords:true,
          hyphenateLastWord:false,
          hyphenateAcrossColumns:false,
      if(myPara[i].hyphenation=false)
      I want to implement the 1st point detail in my script, so please correct my script.
        • 1. Re: Please correct my Hyphenation setting script
          Chinnadk Level 4
          Hi Hasvi,
          Try the below method,
          var doc = app.activeDocument;
          var regex1=new RegExp("\\w*H1");
          var pstyles = doc.paragraphStyles.everyItem().name;
          try{
              for (var i=1;i<pstyles.length;i++)
                  if(regex1.test(pstyles[i]))
                      var h1 = pstyles[i].match(regex1).toString();
                      doc.paragraphStyles.item(h1).hyphenation = false;
          catch(e){}
          Regards,
          Chinna
          • 2. Re: Please correct my Hyphenation setting script
            hasvi Level 1
            Its working properly, but how can we get all the Heading levels like "H1, H2, H3, CT,...." in this script?
            thanks
            • 3. Re: Please correct my Hyphenation setting script
              hasvi Level 1
              I got the answer, its working
              var myDoc=app.activeDocument;
              var myStyle=new Array("H1","H2","H3");
              for(var i=0;i<myStyle.length;i++)
                      if(myDoc.paragraphStyles.item(myStyle[i]).isValid)
                       myDoc.paragraphStyles.item(myStyle[i]).hyphenation = false;
              alert("ok");
              But, any option for compare with txt file?
              thanks
              • 4. Re: Please correct my Hyphenation setting script
                Chinnadk Level 4
                Hi Hasvi,
                Here it is.
                var pstyles = doc.allParagraphStyles;
                var file = File('c:/1.txt');  //Style name should be separeted by ,(only comma not comma then space) in text file
                file.open('r');
                var content = file.read();
                for(var i=1;i<pstyles.length;i++){
                    for(var j =0;j<Split(content).length;j++)
                            if(pstyles[i].name == Split(content)[j])
                                    pstyles[i].hyphenation = false;
                file.close();
                function Split(str) {
                    return str.split(',');
                Regards,
                Chinna
                • 5. Re: Please correct my Hyphenation setting script
                  hasvi Level 1
                  Hi Chinna,
                  Brilliant thanks for your timing help, thank you again.
                  by
                  hasvi
                  • 6. Re: Please correct my Hyphenation setting script
                    @Hasvi – so the 10 points should go to Chinna, don't you think ;-)
                    Uwe
