2 Replies Latest reply on May 12, 2014 5:51 AM by VallleyNL
    Why won't adobe acrobat recognize some of my table as a text field?
    VallleyNL
      Hi there I've been working on a form in InDesign that has to be able to be filled in using Adobe Acrobat pdf viewer.
      This is because the people who need to fill in the form don't have/understand Adobe InDesign. Nor can I choose another way of working.
      So here are some Pictures, however i can't show you everything:
      This is what a part of the table looks like, 2 columns and multiple rows, only the right part will be editable.
      Proof that it is a table when i select it.
      When I go into Adobe acrobat with the interactive pdf. I choose the "Create form" or something button and choose this pdf. Then it will render some textfields, however it will only select some tables and not all! This is the problem.
      As you can see, i can fill in the others but not the center table.
      The groups of tables are all separate tables in separate text fields, I copied and pasted them and  changed the table.
      If you have any idea what i did wrong or how to fix it please help me!
      Thanks in advance,
      Marc.
