4 Replies Latest reply on May 20, 2014 3:42 AM by Colin Flashman
    Data merge with a LOT images
    macklaudi
      Hi
      I have to create a lot of pages in InDesign with Data Merge, and have and Excel-fil with the data, and have created a template in InDesign, and everything works fine :-)
      My challange is that I have a LOT of images, and are there any way that I can do something else than putting the filelocation in the Excel-file, fx.: C:\Users\usNoName\Desktop\Productsheet production\852355354_prodouct_yellow_new2.jpg with every string.
      The productnumber is always in the imagename, in the above example: 85235535, so I an copy this text from elsewhere in the Excel-document.
      Is it possible to use * or any other characters to avoid typing every image location in every line.
      My hope was that I could just type something like: C:\Users\usNoName\Desktop\Productsheet production\**852355354**.jpg and that InDesign would find the correct image: 852355354_prodouct_yellow_new2.jpg
      Hope someone can help :-)
      /Klaus
        • 1. Re: Data merge with a LOT images
          MW Design Level 5
          If the images are in the same folder as the merge file/ID file, then you don't need a path. You can also use a relative path from the ID and data source folder as long as the images are under the ID folder.
          • 2. Re: Data merge with a LOT images
            SJRiegel Adobe Community Professional & MVP
            As far as I know, you will always have to have the full image name. Otherwise, if there were two files containing that number sequence, how would InDesign know which one to use?
            But if you have only one image for each product number, you can copy them all to one folder and use bridge to batch-rename them to just the product number. Then it's a simple matter in excel to bring the number over to the photos field and add .jpg
            =A1&".jpg"
            then, as NW said, put the data file in the folder with your images and you'll be good to go.
            • 3. Re: Data merge with a LOT images
              macklaudi Level 1
              Thanks for your suggestions.
              I would prefer NOT to rename the images, since these are used in other publications and then I (or other users) would have to update the links.
              I would also prefer to keep the images in separat folders, but I can see that this complicates the issue even further.
              /Klaus
              • 4. Re: Data merge with a LOT images
                Colin Flashman Adobe Community Professional
                Do what MW Design has suggested. If the image names don't clash and can successfully be consolidated into the one folder, put the images there and put the text file that will be used for the data merge there as well. If this is done, then only the filename will be required for the merge, and not its complete path.
                If the images MUST be in separate folders, then the full paths of the images have to be used.
                Colin
