7 Replies Latest reply on May 13, 2014 10:16 PM by hasvi
    Correct my script
    hasvi Level 1
      Hi
      Its running but 'Advanced Type default setting' value is not updated in my Indesign file. Pls correct my script.
      var w = new Window ("dialog", "Template Checklist", undefined, {closeButton: false});
      w.alignChildren = "left";
      var check1  = w.add ("checkbox", undefined, "Preference settings");
         if (check1.value == true)
          //this is 'Advanced Type' default setting
          myDocument.viewPreferences.horizontalMeasurementUnits = MeasurementUnits.inches;
          myDocument.viewPreferences.verticalMeasurementUnits = MeasurementUnits.inches;
          myDocument.viewPreferences.rulerOrigin = RulerOrigin.pageOrigin;
          myDocument.textPreferences.superscriptPosition=33;
          myDocument.textPreferences.superscriptSize=70;
          myDocument.textPreferences.subscriptPosition=33;
          myDocument.textPreferences.subscriptSize=70;
          myDocument.textPreferences.smallCap=75;
          app.imePreferences.inlineInput=true;
      var buttons = w.add ("group");
      buttons.add ("button", undefined, "Ok");
      buttons.add ("button", undefined, "Cancel");
      w.show ();
      var ProgressBar = function(/*str*/title)
           var w = new Window('palette', ' '+title, {x:0, y:0, width:340, height:60}),
                pb = w.add('progressbar', {x:20, y:12, width:300, height:12}, 0, 100),
                st = w.add('statictext', {x:10, y:36, width:320, height:20}, '');
           st.justify = 'center';
           w.center();
           this.reset = function(msg,maxValue)
                st.text = msg;
                pb.value = 0;
                pb.maxvalue = maxValue||0;
                pb.visible = !!maxValue;
                w.show();
           this.hit = function() {++pb.value;};
           this.hide = function() {w.hide();};
           this.close = function() {w.close();};
      //      SAMPLE CODE
      function main()
           var pBar = new ProgressBar("Running");
           var i;
           // Routine #1
           pBar.reset("Please wait Processing ...", 100);
           for( i=0 ; i < 100; ++i, pBar.hit() )
                $.sleep(10);
           // Routine #2
           pBar.close();
      main();
      exit();
      by
      hasvi
        • 1. Re: Correct my script
          Chinnadk Level 4
          Hi Hasvi,
          Corrected code.
          w.show ();
          var myDocument = app.activeDocument;
               w.center();
                    st.text = msg;
                    pb.value = 0;
                    w.show();
          //      SAMPLE CODE
          function main()
               var i;
               // Routine #1
                    $.sleep(10);
               // Routine #2
               pBar.close();
          main();
          exit();
          • 2. Re: Correct my script
            hasvi Level 1
            Hi Chinna,
            thanks again
            by
            Hasvi
            • 3. Re: Correct my script
              hasvi Level 1
              Hi Chinna,
              If I select the ok button the 'processing completed' dialog is running, if I give cancel that time also its running. How to stop this 'processing completed' dialog running script for 'Cancel' button.
              by
              hasvi
              • 4. Re: Correct my script
                Chinnadk Level 4
                Hi Hasvi,
                Replace the above line(6th line of your script) with below,
                var Exit = 0;
                var cancel = buttons.add ("button", undefined, "Cancel")
                        cancel.onClick = function()
                                w.close();
                                Exit = 1;
                w.show ();
                if(Exit ==1)
                        this.exit();
                Regards,
                Chinna
                • 5. Re: Correct my script
                  hasvi Level 1
                  Hi Chinna,
                  This is script is perfect for click on 'Cancel', but if I click on 'Ok' button, one big dialog box opened I press Esc key after that only 'processing completed' running. Pls help  for this issue.
                  by
                  hasvi
                  • 6. Re: Correct my script
                    Chinnadk Level 4
                    Hi Hasvi,
                    Try this,
                    var Exit = 0;
                                    w.close();
                                    Exit = 1;
                    w.show ();
                    if(Exit ==1)
                            this.exit();
                         w.center();
                              st.text = msg;
                              pb.value = 0;
                              w.show();
                    //      SAMPLE CODE
                    function main()
                         var i;
                         // Routine #1
                              $.sleep(10);
                         // Routine #2
                         pBar.close();
                    main();
                    exit();
                    Regards,
                    Chinna
                    • 7. Re: Correct my script
                      hasvi Level 1
                      Hi chinna,
                      Excellent thanks again
                      by
                      hasvi
