4 Replies Latest reply on May 14, 2014 3:12 AM by Jakes Cusack
    change image on mouseover/mouseout
    Jakes Cusack
      Hello All, today I have been trying to change an image/symbol when I hover over the image
      I have tried
      Then I add
      mouseover
      $(this.lookupSelector("pink_dot_new ")).attr("src","images/Pink_dot_light.png");
      mouseout
      $(this.lookupSelector("pink_dot_new")).attr("src", "images/Pink_dot_light.png");
      And
      mouseover
      $(this.lookupSelector("ImageHolder")).css('background-image', 'url(images/Pink_dot_light.png)');
      mouseout
      I am not sure what I am missing? Can anybody help?
        • 1. Re: change image on mouseover/mouseout
          resdesign Adobe Community Professional & MVP
          What version of Animate are you using? Why are you using this old syntax instead of the native syntax?
          for a symbol use sym.getSymnbol('name')
          is image holder a div, a rectangle in your symbol?
          Here is what I would do.
          have the symbol with the image inside and use this on your events.
          sym.getSymbol('symbol name').$('imagename').css({'background-image':'url("images/newimagepath.png")'});
          • 2. Re: change image on mouseover/mouseout
            Jakes Cusack Level 1
            Many thanks redesign, I am using 3.0 so i should be using the native syntax.
            I am still not getting any joy with the code
            sym.getSymbol('_dot_new').$('Pink_dot.png').css({'background-image':'url("images/Pink_dot_ light.png")'});
            I have a "Pink_dot.png" that i converted into a symbol and added it to my page, the symbol is called "_dot_new" then i added a mouseover and a mouseout event to the symbol and added the code but it doesn't seem to do anything? is there an order i have o follow? I also have a click event on the dot that once click a fancy box pop will appear with an image
            Many thanks again, very much appreciated
            J
            • 3. Re: change image on mouseover/mouseout
              Sorry i was out for a while. So i did not mean the name of the image but its name as it appears in the elements panel - most likely it is Pink_dot.
              So here is what you should have to change the image
              I am not sure what the name of your symbol is in the elements panel but in your code it looks like your symbol is named _dot_new
              sym.getSymbol('_dot_new').$('Pink_dot').css({'background-image':'url("images/Pink_dot_light.png")'});
              addresses the symbol   +   addresses the  image element   + css  wit the name of the new image
              incidently, you might want to add: 'background-repeat': 'no-repeat'
              Sample here:
              dot images.zip - Box
              • 4. Re: change image on mouseover/mouseout
                Many thanks redesign, very much appreciated, really helpful
