2 Replies Latest reply on May 13, 2014 8:40 AM by Peter Spier
    Column guides will NOT unlock!
    bondo59260
      Here's the scenario:
      Creating an variable column width layout you set up the columns, go to View>Grids & Guides and uncheck Lock Column Guides. Once done you should be able to select a column guide and move it. Not happening; they're still locked.
      I've looked for anything I can think of in ID that locks or unlocks and nothing has worked.
      Has anyone experienced this and have a solution?
      I've never experienced this before in InDesign, and I teach an InDesign class so it was particularly embarrassing not having a solution to this problem.
      The lab is running InDesignCC on Windows 98 (don't know the version)
