2 Replies Latest reply on May 16, 2007 11:16 AM by Rhouse61
    Audio not attaching to a slide.
    Rhouse61
      Captivate allows me to re-record for a slide, listen to it, and attach it through the audio library. As soon as I close the audio dialog box, the slide reverts back to no audio. Any advice on how to take care of this issue? I am suspecting that the file is corrupted. However, I really want to avoid having to start over.
        • 1. Re: Audio not attaching to a slide.
          CatBandit Level 3
          I'm a little unsure what you are saying. But check to see that no other audio file has the same name - if it does, rename the new one.
          Are you working on a project on a network drive? If so, try to open and work only on projects that are located locally (Drive C:\).
          Any help?
          • 2. Re: Audio not attaching to a slide.
            Rhouse61 Level 1
            Thanks for the advice. I tried to rename the file, but this didn't seem to work. I have alos noticed that it will do the same thing when importing a sound file.
            My file is not on a network either. It is saved to my C: drive.
            I have a feeling with 112 slides, something became corrupted. Looks like I am going to start all over again! Yikes!
