1 Reply Latest reply on May 16, 2014 4:37 AM by hemanthR
    Loading An Edge composition at a certain frame
    goombaccino Level 1
      What I would like to do is to load  my Edge composition at a certain frame.
      I would like to tell the Edge composition where to stop at, within my html file.
      This because I need to load the comp at a different position in the timeline, depending on the html page where I need to place it.
      I was able to start playing the comp
      <script type="application/javascript">
        var comp;
        AdobeEdge.bootstrapCallback(function(compId) {
        // "comp" is now equivalent to the Stage's "sym" variable.
        comp = AdobeEdge.getComposition(compId).getStage();
        comp.play();
      </script>
      but I would actually want to tell the comp to play at a label.. something like
      comp.play("label");
      but thats not working...
      I am not very familiar with js since I come from After Effects, so it would be nice if someone could provide an example or point another discussion where this problem was solved.
        • 1. Re: Loading An Edge composition at a certain frame
          hemanthR Adobe Employee
          You will not be able to play from  a label on stage timeline from bootstrap callback as the timeline playback has not started.
          A workaround is to store the label name  you wish to play from in a global variable in bootstrap call back function and using that label to play from in the 0th second trigger
          I know the explanation above is bit confusing,so i have attached a example here.
          IN main.html i save the label(red) to play from in
          AdobeEdge.playFrom = "red";
          Than in the 0th second trigger read that label and play from there like
          sym.play(AdobeEdge.playFrom);
          Sample here playFmor.zip - Google Drive
