• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Is there a RoboHelp shortcut for toggling case, like Shift-F3 in Word?
Participant ,
May 13, 2014 May 13, 2014
In Word I often use Shift-F3 to change the case of selected text, toggling between Initial Caps, ALL CAPS, and lowercase.
Is there a way of achieving the equivalent In Robohelp?
My muscle memory works for other shortcuts, like CTRL-K for a link, which are common between Word and RoboHelp (and other apps, such as Excel), but it fails on this one. I'd be happy to retrain it if there was a new shortcut to learn.
(I watched @maxwell Hoffman's  webhinar on RoboHelp shortcuts, but it didn't include one for this.)
Views
396
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
May 14, 2014 May 14, 2014
No shortcut in RoboHelp. You could try a macro program such as Macro Express to set something up. There are also some free apps that do the same.
@petergrainge
Votes
Translate
Translate
Report
Report
New Here ,
Aug 11, 2014 Aug 11, 2014
Hi, Peter, Is it possible at all? Perhaps a menu item I'm overlooking? This is a major pain for me as many of my source docs come with uppercase titles. In the past, I've written macros in Word to open, change, save, and close bulk groups of Word docs, but it sure would be nice if I could do it as part of my normal formatting routine in RH. Thanks, Shelley
Votes
Translate
Translate
Report
Report
Contributor ,
I'm not familiar with creating macros (in anything), but there are shortcut keys that you can use to accomplish changing from uppercase to lowercase (and then to sentence case).
CTRL+D - Opens the Font window.
ALT+W - Changes to lowercase.
ALT+Z - Changes to capitalize.
You can't change from all caps to just capitalized. You'd have to first change to lowercase and then go back in and change to capitalize.  So... it could be that you could create a macro to do all of this.
Votes
Translate
Translate
Report
Report
Community Expert ,
Aug 12, 2014 Aug 12, 2014
Sorry but it is a macro solution. Also using a macro does not actually change the text, instead it applies a span tag so that it displays as required. Thus iPad would appear as IPAD but the HTML would achieve that by applying a span tag. That will be ignored if you have generate printed documentation and there you would still get iPad.
I think you would be better off reverting to fixing the problem in Word first.
@petergrainge
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
Ok. Thanks, Peter. That's what I thought, I just wanted to double check that I wasn't missing anything. Thanks again!
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
