1. Re: The AcroPDF.PDF Class is no longer accessible from Visualbasic after update 11.0.0.7.
Test Screen Name May 14, 2014 4:08 AM (in response to Stef4Life)If you don't get a reply here I recommend you try the Acrobat SDK forum.
2. Re: The AcroPDF.PDF Class is no longer accessible from Visualbasic after update 11.0.0.7.
tomk May 14, 2014 4:56 AM (in response to Stef4Life)Neither does it work from Delphi....
3. Re: The AcroPDF.PDF Class is no longer accessible from Visualbasic after update 11.0.0.7.
apkhan May 16, 2014 9:13 AM (in response to Stef4Life)Sorry to hear about the issue.
Would it be possible to share sample project?
Thank You.
4. Re: The AcroPDF.PDF Class is no longer accessible from Visualbasic after update 11.0.0.7.
Smithyes May 16, 2014 9:32 AM (in response to Stef4Life)Not only does it not work in the VB6 IDE environment, _all_ applications that were built in VB6/Delphi that utilise the acropdf.dll activeX control will also be broken when a user updates to 11.0.07. Quite a major problem.
5. Re: The AcroPDF.PDF Class is no longer accessible from Visualbasic after update 11.0.0.7.
Warpitaly May 16, 2014 9:49 AM (in response to Smithyes)Same problem here.
To reproduce the issue: add Adobe control on a VB6 project; VB6 itself crashes when you start drawing the control on an empty form.
6. Re: The AcroPDF.PDF Class is no longer accessible from Visualbasic after update 11.0.0.7.
DashDeveloper May 16, 2014 10:01 AM (in response to Stef4Life)This appears to be a problem for Win32 native apps. I have not found any messages regarding this problem in the .NET arena.
7. Re: The AcroPDF.PDF Class is no longer accessible from Visualbasic after update 11.0.0.7.
Everton Alexandre Schuh May 16, 2014 10:03 AM (in response to Stef4Life)Mesmo problema em minha aplicação VB6
Tudo funcionava corretamente. Quando executei a atualização do Adobe Reader XI para 11.0.07 apareceu o erro na aplicação.
"O Visual Basic Parou de Funcionar"
Um problema fez com que o programa parasse de funcionar corretamente. O windows fechará o programa e o notificará caso uma solução esteja disponível.
O erro ocorre quando a aplicação esta rodando e ao abrir o formulário onde contém o componente baseado na dll AcroPDF.dll
O erro também ocorre ao abrir o formulário que contém o componente dentro do VB6 em modo de desenvolvimento..
Não é possivel nem retirar o componente do formulário pois não exibe o formulário e fecha o VB6.
Acredito q o problema esteja na DLL AcroPDF.dll e sua atualização
8. Re: The AcroPDF.PDF Class is no longer accessible from Visualbasic after update 11.0.0.7.
apkhan May 16, 2014 12:02 PM (in response to Stef4Life)We are currently investigating this issue to determine the cause.
Thank You
9. Re: The AcroPDF.PDF Class is no longer accessible from Visualbasic after update 11.0.0.7.
Smithyes May 16, 2014 12:05 PM (in response to DashDeveloper)Agreed, our .NET applications are unaffected.
10. Re: The AcroPDF.PDF Class is no longer accessible from Visualbasic after update 11.0.0.7.
Alberto DS May 19, 2014 9:49 AM (in response to Stef4Life)Waiting for a solution by Adobe, I copied the Adobe\Acrobat\ActiveX folder from a PC with Reader ver. 11.0.6 and all seems working fine
11. Re: The AcroPDF.PDF Class is no longer accessible from Visualbasic after update 11.0.0.7.
StanHawaii May 19, 2014 1:58 PM (in response to Alberto DS)How did you get AcroPDF.dll overwritten?
12. Re: The AcroPDF.PDF Class is no longer accessible from Visualbasic after update 11.0.0.7.
Alberto DS May 20, 2014 2:08 AM (in response to StanHawaii)First closed all programs
Renamed [CommonProgramFiles]\Adobe\Acrobat\ActiveX to [CommonProgramFiles]\Adobe\Acrobat\ActiveX.11.0.7.79
Copied [CommonProgramFiles]\Adobe\Acrobat\ActiveX folder from a PC with Reader ver. 11.0.6
So now I have Adobe Reader XI ver. 11.0.07 and AcroPDF.DLL ver. 11.0.6.70
13. Re: The AcroPDF.PDF Class is no longer accessible from Visualbasic after update 11.0.0.7.
narrasc2821 May 22, 2014 8:15 PM (in response to Stef4Life)We are having the same issue here and it is preventing staff from accessing our finance system. Only affecting windows 7 64bit PC's.
14. Re: The AcroPDF.PDF Class is no longer accessible from Visualbasic after update 11.0.0.7.
Everton Alexandre Schuh May 28, 2014 5:55 AM (in response to Stef4Life)PDF applications built with VB6 fail to work with 11.0.07
I never waited a position with this company Adobe.
Imagine if Microsoft company inform that all 32-bit computers stopped working after the last update performed because the windows no longer work on 32bit hardware.
That would be ridiculous.
But Adobe has done just that.
Unfortunately, 70% of Brazil's computers are generations old.
Systems in VB6 run on large companies.
So it is decreed. All Adobe Reader stopped their updates in version 11.0.06
