3 Replies Latest reply on Jun 18, 2014 2:28 PM by CulinaryGeek
    Variables not returning correct value if script is run in InDesign
    CulinaryGeek
      Ok, here is a snippet of my script.
      tell application "Adobe InDesign CC"
        set aspActiveDocument to active document
        tell view preferences of aspActiveDocument
        --get horizontal measurement units
        set aspOrigHorizonalMeasurementUnits to horizontal measurement units
        set aspOrigVerticalMeasurementUnits to vertical measurement units
        set aspTryThis to horizontal measurement units as string
        --set horizontal measurement units
        set horizontal measurement units to millimeters
        set vertical measurement units to millimeters
        end tell
        set aspDocHeight to item 3 of bounds of page 1 of aspActiveDocument
        set aspDocHeight to aspDocHeight as string
        set aspDocWidth to item 4 of bounds of page 1 of aspActiveDocument
        set aspDocWidth to aspDocWidth as string
        set aspSizeInfo to (aspDocWidth & " x " & aspDocHeight & " " & aspTryThis) as string
        display dialog aspSizeInfo
      end tell
      If I run it from AppleScript Editor I get: 215.9 x 279.4 millimeters
      If I save it as an Application I get: 215.9 x 279.4 <<constant ****zmms>>
      If I run the script from the scripts panel in InDesign I get: 215.9 x 279.4 <<constant ****zmms>>
      Anyone have any idea why or how to fix this issue?
        • 1. Re: Variables not returning correct value if script is run in InDesign
          Mary Posner Level 3
          I got the same results when I tested your script in CS5.5; it was okay when run via Script Debugger, but returned the raw code when saved as an app. I found the below in another discussion about coercing constants, and it seemed to work for me in CS5.5. Try adding this at the top of your script:
          run script "tell application \"Adobe InDesign CC\"" & return & "end tell"
          From what I understand, this may result in a bit of a performance hit as it's forcing the InDesign dictionary to load every time it's run, but it ran pretty quickly for me and did produce the correct dialog.
          • 2. Re: Variables not returning correct value if script is run in InDesign
            zeRafio
            HI CulinaryGeek,
            There is a problem with your code.
            You're asking for measurement units before setting them.
            If Indesign returns a constant expressed in <<chevrons>>, it's a bug.
            But your script could be simplified:
              end tell
              set aspSizeInfo to (""& aspDocWidth & " x " & aspDocHeight & " millimeters") as string
            end tell
