1. Re: Fast playback (multicam) won't stop until end of timeline reached
Mark Mapes May 14, 2014 10:29 AM (in response to JF TVCW)Yes, several others have reported this issue in other threads on this forum. I actually hit the problem myself a few times in 7.1, and a fix went into that release. But apparently we did not nail all the cases, and we have not been able to isolate a consistent repro case--which makes it very difficult for a developer to investigate further.
Please start by double-checking that you're on the current version--7.2.2 (Several customer have reported being up-to-date, but upon further review found they were on 7.0...) If you are on 7.2.2 and can reproduce the problem consistently, I'd like to either get a copy of the project or confer with you about troubleshooting it to isolate the key variables.
2. Re: Fast playback (multicam) won't stop until end of timeline reached
JF TVCW May 14, 2014 11:22 AM (in response to Mark Mapes)Hi Mark and thank you for your fast answer. I just double checked and yes, I am running the 7.2.2 Premiere Pro version. I also just tried to import one of my problematic multicam sequences in a new project to check if it would reproduce the problem but having only this sequence, the 2 cam sequence and the associated video clips works just fine. I am currently working on the first editing steps of a complex 50 multicam interviews project with more than 700 GB footage. Would you still like to have a copy of my project? Hoping that I can soon get Premiere to work fine because it is very time consuming not to be able to play at more than normal speed.
Thanks again.
3. Re: Fast playback (multicam) won't stop until end of timeline reached
MonkeyEatsMonkey May 25, 2014 10:04 AM (in response to Mark Mapes)I'm also having this issue on 7.2.2, but it's not always as bad as non-stop playback. Sometimes it just keeps playing for a few seconds after I press "K" or "Spacebar" to stop.
I'm editing a four-camera multicam clip, and it only happens when I'm editing in multicam mode. It pretty much makes multicam unusable. I would be happy to send you a copy of the project file if that would help.
MY FILES:
1920x1080 MPEG2 proxies at 17mbps (four streams)
Audio - 44.1Khz WAV exported from audition (one stream)
MY SYSTEM:
Intel Q9550 quad core at 2.83Ghz
EVGA Nvidia 560ti / 2GB VRAM
16Gigs of Patriot DDR3 RAM
Gigabyte Motherboard: GA-EP45-UD3P (Rev A3 / BIOS vF8c)
System Drive - 500GB WD Caviar Black running Windows 7
Media Drive - 2x 1TB WD Caviar Black (Internal RAID 0 )
4. Re: Fast playback (multicam) won't stop until end of timeline reached
JF TVCW May 27, 2014 8:13 AM (in response to MonkeyEatsMonkey)Thank you, MonkeyEatsMonkey,for sharing your case. I must say that for me too, it is not always as bad as non-stop playback. It even works fine on certain sequences... but it keeps doing it every day and it is really annoying and time consuming! Is it also related, I sometimes need to click twice or three times to move my cursor on my timeline; it will jump back to where it was playing before.
I really hope that Mark and the Adobe Staff can soon find a fix for that. Anything you can do, Mark?
5. Re: Fast playback (multicam) won't stop until end of timeline reached
MonkeyEatsMonkey Jul 14, 2014 10:42 AM (in response to Mark Mapes)This is still an issue in CC2014. In fact, it seems to have gotten worse.
Just playing back in multicam mode causes Premiere to completely ignore any commands from the mouse or keyboard!
This is becoming a huge obstacle for working on multicam projects in Premiere.
6. Re: Fast playback (multicam) won't stop until end of timeline reached
Betatono Jul 19, 2014 3:08 PM (in response to JF TVCW)same problem.... we need a solution !
7. Re: Fast playback (multicam) won't stop until end of timeline reached
Betatono Jul 19, 2014 4:43 PM (in response to Mark Mapes)Adobe... were are you... we need à solution to this UGLY problem ! We NEED Multicam
8. Re: Fast playback (multicam) won't stop until end of timeline reached
MonkeyEatsMonkey Jul 25, 2014 3:26 PM (in response to MonkeyEatsMonkey)Just to make sure it wasn't my machine, I also tested this out on my laptop. Still getting the issue there.
People seem to be having this issue on a wide variety of setups. Has everyone taken the time to file a bug report for this?
9. Re: Fast playback (multicam) won't stop until end of timeline reached
Mark Mapes Jul 25, 2014 6:19 PM (in response to MonkeyEatsMonkey)A QE colleague and I put our heads together about this issue this afternoon. We remain unable to repro it in-house--at least not since one bug in this vein was fixed in 7.1 as I mentioned in Post #1 above. That plus the fact that a relatively small number of customers are reporting this problem leads us to believe that the bug is contingent on something common to your workflows or hardware configurations or content or ....
So in hopes of isolating the key, we came up with the following questions & requests. As you'll see, this is a bit of fishing expedition, but given that we have no way of knowing where the key is hiding, that's the best approach.
- Does this happen regardless of playback speed or only when the MC sequence is playing at greater than real time (via JKL)
- Does this occur regardless of the zoom level in the Timeline and the Program Monitor? If it happens only when you’re zoomed way in—or at least it seems more likely to happen in that case—please report how exactly you adjust the zoom level [in case you’re not aware, there are at least four ways to do this…]
- What is your exact workflow for starting and stopping playback? Do you do this entirely by keyboard, entirely by clicking buttons, or a combination?
- In the Program Monitor, is the Show Multi-Camera Preview Monitor option enabled?
- When the app is in the state where playback will not stop, does it help to toggle focus to another program and then back to Premiere?
- Is Mercury Transmit enabled? If so, with what hardware? Does the problem persist if you disable Transmit? [Note that with some configurations, Transmit is known to impact performance and responsiveness.]
- Where is your content stored? Internal hard drive? External drive? SAN? …
- If you experience both the case where playback cannot be stopped at all and the one where playback continues for several seconds after the Stop command, are there any patterns in the occurrence of these two behaviors?
Info about your multicam sequence(s)
- How exactly do you create your multicam sequences? By nesting one sequence in another and enabling multicam (old school)? By selecting clips in the Project panel and using the Create Multi-Camera Source Sequence command (the New Coke)? In PluralEyes?
- If you use multiple workflows, do you have problems stopping playback regardless of how a given sequence was created?
- If you use the Create Multi-Camera Source Sequence workflow, exactly what settings do you select in the dialog by the same name?
- Is “Multi-Camera Audio Follows Video” enabled? Using audio follow video on "switch cameras" MC clip?
- Have you used the Edit Cameras feature in the Source or Program Monitor?
- Have you changed the camera for an edited sequence by right-clicking the segment and selecting from the Multi-Camera submenu?
- What effects, if any, are applied to the multicam source sequence? To its constituent clips? In particular, have you toyed with Time Remapping, Speed/Duration, or any other effects that affect playback speed? Have you used Interpret Footage to change the frame rate of any clips in the multicam source sequence?
- Does it matter how many cameras the multicam sequence contains? That is, can you repro with only two cameras, or does this happen only when you’re working with, say, 8 or more?
- Does the duration of the multicam sequence matter? That is, can you repro with sequences that are only couple minutes long, or only with those longer than, say 15 minutes?
- Do you have more than one multicam sequence in the master sequence where you’re editing multicam cuts?
- What format(s) of clips are used?
Believe it or not, our list of questions was considerably longer. But we decided that a set of screenshots would be the most efficient way to gather this info:
- Your entire PPro workspace. If it’s spread across multiple monitors, make sure that the screenshot shows the PPro panels on all of them.
- Timeline Display Settings menu (accessed via the panel’s wrench icon. The first option is Show Video Thumbnails.)
- The Timeline panel menu (opened by right-clicking the panel’s tab. Top entry is Undock Frame.)
- Preferences>General
- Preferences>Playback
Rather than posting all these screenshots here, please send them directly to me. I'll email each of you momentarily. You can simply reply to the email and attach the screenshots. If you prefer, you can include your answers to all the questions above in the email, too.
We realize it will be a chore to fill in all these blanks and provide the screenshots. But in cases where we cannot reproduce a problem, collecting information from customers who are affected by the issue is the best way to nail it down. And our odds of getting a handle on it increase with each data point we receive. So we sincerely appreciate your cooperation.
Mark
10. Re: Fast playback (multicam) won't stop until end of timeline reached
Mark Mapes Jul 25, 2014 6:42 PM (in response to Mark Mapes)In the course of collecting email address from the various threads on this issue, I found one that I don't recall seeing before, which happens to have a workaround posted: Playback won't stop in multicam sequence
If your PPro workspace is spread across multiple monitors, please try collecting all panels on one monitor and report whether that avoids the infinite playback.
11. Re: Fast playback (multicam) won't stop until end of timeline reached
Colton Media Productions Jul 26, 2014 9:14 AM (in response to Mark Mapes)I encountered the bug previously on multiple monitors and I think I remembered also having the problem on one monitor. Having said that, I'm now trying my one monitor workspace and it is not freezing for me. I'll let you know if I can figure out if it's coincidence or if it's actually solving the problem.
12. Re: Fast playback (multicam) won't stop until end of timeline reached
Stas_U Aug 15, 2014 9:14 PM (in response to Mark Mapes)This issue is really bad on my system!
The moment I start playback in multicam mode, Premiere becomes completely unresponsive to any commands from the mouse or keyboard. Playback continues, both video and audio keep playing, but there is no way to switch cameras or stop playback or do anything at all. Can't even close Premiere. Minimizing and then restoring the Premiere window helps about 1 times out of 20 -- playback will then stop. Most of the times I have to force close Premiere from the Task Manager.
I tried collecting all panels on one monitor. This allowed me to edit multicam for about a day, and then the issue came back. Not sure what that means. Having all panels on one monitor seems to make the issue happen less often, but it still does happen!
Mark -- can you please send me an email too so I can send you my screenshots?
System specs:
Premiere CC 8.0.1 (21)
Windows 7 64 bit, SP1
RAM: 24 GB
CPU: Intel Xeon X5680 @ 3.33Ghz (12 threads)
VIDEO: NVIDIA Quadro 4000
13. Re: Fast playback (multicam) won't stop until end of timeline reached
Stas_U Sep 29, 2014 12:56 PM (in response to Mark Mapes)The issue continues and it's killing me!
14. Re: Fast playback (multicam) won't stop until end of timeline reached
Colton Media Productions Oct 4, 2014 5:42 PM (in response to Stas_U)Everyone I am seeing marked improvement on this bug when you use a workspace that is only on one monitor, not streched across three. It can still lag and keep playing for 10-20 seconds but DOES eventually stop, which is still annoying but much less paralyzing and destructive.
15. Re: Fast playback (multicam) won't stop until end of timeline reached
golewis Oct 9, 2014 11:32 AM (in response to JF TVCW)I would like to follow this thread: having same issue.
- Multi-cam sequence
- Sony PMW 200 footage - MXF format
- Dual monitors.
- Nvidia GTX 285 Card
Not sure that this has been mentioned, but the problem on my system seems to occur more specifically when I have the multi-cam clip selected. Then playback will continue until either several seconds after being stopped or the end of clip.
Looking forward to resolution. Many thanks to Adobe Team.
16. Re: Fast playback (multicam) won't stop until end of timeline reached
Mark Mapes Oct 11, 2014 1:26 AM (in response to golewis)Golewis: If you disable the second monitor, does this issue persist?
17. Re: Fast playback (multicam) won't stop until end of timeline reached
golewis Oct 12, 2014 9:39 AM (in response to Mark Mapes)I have not yet tried without the second monitor but will test it.
I turned off the full screen display from within Premiere and instead opened a reference monitor on my second screen. But I still get slow response to the play/pause of the sequence, although it does eventually stop. I will take the additional step of disabling my second monitor completely to see if there is any change.
18. Re: Re: Fast playback (multicam) won't stop until end of timeline reached
MonkeyEatsMonkey Oct 12, 2014 10:20 AM (in response to Mark Mapes)I've been working on a project that was fine until today, then it started doing the non-stop playback thing in multicam mode.
Tried disabling my second monitor, and it didn't help. Here's a screen grab.
For what it's worth, none of my projects have started out with this problem, but tend to develop it after I've been editing for a while.
AND I went ahead and filled out your list of questions.
YES, but it's a gradual process. First starting with fast-play, then affecting any normal speed as well. - Does this occur regardless of the zoom level in the Timeline and the Program Monitor? If it happens only when you’re zoomed way in—or at least it seems more likely to happen in that case—please report how exactly you adjust the zoom level [in case you’re not aware, there are at least four ways to do this…]
Zoom level doesn't seem to have any effect on the behavior. I use the +/- keys and also the zoom slider at the bottom of the timeline. - What is your exact workflow for starting and stopping playback? Do you do this entirely by keyboard, entirely by clicking buttons, or a combination?
I use both the keyboard (JKL and spacebar) and the mouse (play button on program monitor). - In the Program Monitor, is the Show Multi-Camera Preview Monitor option enabled?
No, but I've tested it with/without, and it doesn't change anything. - When the app is in the state where playback will not stop, does it help to toggle focus to another program and then back to Premiere?
No. - Is Mercury Transmit enabled? If so, with what hardware? Does the problem persist if you disable Transmit? [Note that with some configurations, Transmit is known to impact performance and responsiveness.]
It's enabled. I'll try it with Transmit disabled and let you know if there's a change. - Where is your content stored? Internal hard drive? External drive? SAN? …
Content is stored on an internal RAID 0 with two 1TB Western Digital Black drives. - If you experience both the case where playback cannot be stopped at all and the one where playback continues for several seconds after the Stop command, are there any patterns in the occurrence of these two behaviors?
The behavior tends to begin after I've been editing a project for several hours, and gets worse as the project gets more complex.
I've tried Old School and New Coke. No difference. I still can't get Plural Eyes to work with the new (2014+) versions of Premiere. - If you use multiple workflows, do you have problems stopping playback regardless of how a given sequence was created?
Yes. - If you use the Create Multi-Camera Source Sequence workflow, exactly what settings do you select in the dialog by the same name?
I sync by audio, and I have the sequence inherit the clip parameters. - Is “Multi-Camera Audio Follows Video” enabled? Using audio follow video on "switch cameras" MC clip?
No. I typically use a separate audio source. - Have you used the Edit Cameras feature in the Source or Program Monitor?
This must be new. I haven't tried it yet. - Have you changed the camera for an edited sequence by right-clicking the segment and selecting from the Multi-Camera submenu?
Yes. I've found this to be the safest way of changing angles when it starts giving me non-stop playback. - What effects, if any, are applied to the multicam source sequence? To its constituent clips? In particular, have you toyed with Time Remapping, Speed/Duration, or any other effects that affect playback speed? Have you used Interpret Footage to change the frame rate of any clips in the multicam source sequence?
I use Warp Stabilizer quite a bit. None of these projects have any changes to clip speed or frame rate. - Does it matter how many cameras the multicam sequence contains? That is, can you repro with only two cameras, or does this happen only when you’re working with, say, 8 or more?
I haven't had this occur with fewer than three cameras. But most of what I do is 3-5 cameras, so I may not be the best person to ask. - Does the duration of the multicam sequence matter? That is, can you repro with sequences that are only couple minutes long, or only with those longer than, say 15 minutes?
The sequence I'm working on now is less than three minutes long, and I'm getting this behavior. I've also had it occur on sequences that are over 15 minutes. Those are the frustrating ones. - Do you have more than one multicam sequence in the master sequence where you’re editing multicam cuts?
No. - What format(s) of clips are used?
MTS and MOV (all H.264)
19. Re: Fast playback (multicam) won't stop until end of timeline reached
golewis Oct 12, 2014 10:43 AM (in response to Mark Mapes)Just tested again. Here's what I got.
First I can say that having the second monitor on or off made no difference. All results were seen with both one monitor as well as two.
I was initially baffled at attempting to recreate the problem because even with my memory reaching it's limits (around 4GB on 6GB system) I was still getting great responsiveness. Then I remebered to turn on Multi-camera display mode. Once I did responsiveness started to shudder but remained within acceptable limits. I.e. I would hit the space bar and after about a half second the playhead stopped.
I tried jumping around the sequence, selecting clips, rapid starts and stops, playing source clips then back to sequence, and the worst I got was a small maybe half second lag.
But when I selected the audio tracks (4 linked tracks within the clip) then hit the spacebar to playback, I could not stop playback with either the spacebar or the Program monitor control button. I would have to wait what seemed about 10 seconds before my inputs were recognized.
Screenshot attached (and yes I know I have out of sequence audio - darn it.) Hope this helps.
20. Re: Fast playback (multicam) won't stop until end of timeline reached
Colton Media Productions Oct 12, 2014 10:46 AM (in response to golewis)Next time I have this problem I'll deselect audio and see if that helps.
Weird.
Chris Colton
970-444-2542
Coltonmp.com
Please excuse any brief wording or spelling errors, this message was sent
from my mobile phone.
21. Re: Fast playback (multicam) won't stop until end of timeline reached
MonkeyEatsMonkey Oct 12, 2014 11:58 AM (in response to Mark Mapes)Another interesting/frustrating thing I've noticed is that not only does this behavior make my keyboard unresponsive within Premiere, but it also disables my ability to change my system volume with my keyboard. I can still change my system volume with my mouse, but not with my keyboard controls. The keyboard functions fine otherwise (outside of Premiere).
22. Re: Re: Fast playback (multicam) won't stop until end of timeline reached
noarprodz Nov 4, 2014 6:11 PM (in response to JF TVCW)Just to share my own experience on this problem. I've also experienced this non-stop play in multicam mode on PPRO CC 2014 8.1 on Windows 8.1
My project :
8 cams (5 MPEG-2 422 Long Gop in 1080i50
1 ProRes 422
2 H264 DSLR
all these cams in multicam mode on Video 1 track
and 1 ProRes 422HQ 1080i50 in Video 2 track as PGM for reference
Timeline in 1080p25
Machine :
2x Intel Xeon E5 2630 @ 2.3 GHz
64 GB RAM
GeForce GTX 680 4 GB RAM
Windows 8.1 Pro x64
3 displays in 1920x1080@60Hz
1 Blackmagic Mini Monitor as... monitor
Medias of this project are equitally dispatched on 2 sets of HD (Raid 0) @ 280-300 MB/S read.
PPro interface is dispatched on my 3 monitors.
So I seems that my machine has got enough ressources to handle this kind of project.
THE PROBLEM :
When I hit play, then stop, my playhead keeps moving few seconds (between 2 and sometimes more than 10 seconds)
WHAT I DID
Try to disable mercury on the blackmagic
Disable antivirus, and all useless resident softs
Try to reboot
Update the NVidia drivers
Update the Blackmagic drivers
Disable Cuda acceleration
and so many others things...
MY "SOLUTION"
After the reading of this thread, I tried to disable 2 of my 3 graphic card outputs and set PPro interface on 1 monitor only. The playback continues to play after I hit stop but less longer.
Hope this will help some of you guys...
noar
23. Re: Fast playback (multicam) won't stop until end of timeline reached
ibhhvcc Oct 14, 2014 1:36 PM (in response to JF TVCW)Not sure if Adobe is still hunting after this bug but I have the same issue as the above poster, and the same solution. I can reproduce the results anytime I shuttle (JKL) backward or forward. The only way to stop the playhead is by changing the monitor displays within windows to anything different. Anything that gets the monitors to shut off momentarily stops the playhead.
I am running Premiere Pro 2014.1 (8.1.0). The issue only occurs with a multicam sequence when the program monitor is set to "Multi-Camera" display. I can post more details about my system and project if that would be helpful.
24. Re: Fast playback (multicam) won't stop until end of timeline reached
Colton Media Productions Oct 14, 2014 1:39 PM (in response to ibhhvcc)ᐧ
Deselecting all the audio tracks seems to help on my system as well as
having all workspaces on one monitor. Lessens the problem but it can still
happen.
25. Re: Fast playback (multicam) won't stop until end of timeline reached
ibhhvcc Oct 14, 2014 2:07 PM (in response to JF TVCW)Here are my answers to above questions:
Only JKL
Cannot reproduce issue zoomed all the way out on timeline. Issue occurs on all other zoom levels (changed with +/- key or Alt + scroll wheel)
Only keyboard
Issue happens regardless
No
Internal Raid 0 (4 HDDs)
Issue happens each time I hit J or L more than two times in either direction. Sometimes it stops after many seconds, sometimes it doesn't stop at all. I have not detected a pattern. Info about your multicam sequence(s)
New coke
Only one workflow
All default settings except for "clip marker." One marker in each clip.
No, it is not enabled, but enabling does not solve issue.
No
No
Rotation, scale, position and Lumetri. Applied to constituent clips. One clip of multicam sequence has had Speed/Duration changed. Audio and video fades applied to multicam.
Only tried it with 2 cams.
Restarted PP and now cannot repro. Can't answer this question but original sequence was 36 mins long when repro was possible.
No
MXF
26. Re: Fast playback (multicam) won't stop until end of timeline reached
noarprodz Oct 14, 2014 2:27 PM (in response to JF TVCW)Just find out that when this problem occurs (even on 1 monitor display mode now...), each time I resize a PPro panel (no matter which panel : timeline, project, etc.) the problem dissapear temporaly. Hope this helps Adobe engineers... It's really anoying to work in multicam mode.
27. Re: Fast playback (multicam) won't stop until end of timeline reached
Colton Media Productions Oct 14, 2014 2:33 PM (in response to noarprodz)ᐧ
That's a really really weird workaround but I'll try it.
28. Re: Fast playback (multicam) won't stop until end of timeline reached
Nelson.R Oct 17, 2014 4:31 PM (in response to JF TVCW)Thanks a lot guys. I have a slow machine so it still lags a little, but the interface freezing I had doesn't happen anymore, as long as I don't have an audio file selected while playing. For your info, I'm Running win 7 x64, and intel i3 2100 CPU @ 3.1GHz, 8 GBytes DDR3 Memory, and a NVIDIA GeForce 210 Graphics card with 1024 MBytes of memory. Adobe Premiere Pro CC 2014.1 8.1.0 (81) Build. I have 3 cameras on a multicam sequence that i made by creating a new sequence from a sequence. Two are MTS format with AVCHD Video, 1920 by 1080, 29 fps and 256kbps. One is MOV Format with Quick Time Movie, 1920 by 1080, 59 fps and 17915 kbps. I edit in 1/4 quality due to lagging. I work on two screens by dragging my project monitor onto my second monitor.
Thaks for the help, now I just dont select an audio if i want to play the sequence.
29. Re: Re: Fast playback (multicam) won't stop until end of timeline reached
noarprodz Nov 4, 2014 6:13 PM (in response to Mark Mapes)Here are my answers to Mark :
Regardless but more often @ fast play
Regardless the zoom level.
Keyboard only
Yes
Yes but not everytime.
Mercury Transmit disabled. Tried both. Same problem.
Internal Sata III HDD (2 x 3 To Raid 0 @ 300 MB/s read/write)
I had both cases but I don't know exactly what causes each case.
Old school method. Manual sync in a sequence by nesting
Didn't test
N/A
No. Audio is out of the multicam clip. Only video in the nested multicam clip.
I did both and exact same problem in both cases
No. Only by keyboard shortcut or clic on a camera picture in the multicam window
No video effect, no audio effect. Juste the source footage.
Yes it happen with many cams. My actual project contains 8
I don't know. My actual projet is 1h30.
Yes. I've got one multicam sequence on Track 1. One reference clip (ProRes 422 HQ 1080p25) on track 2. And 2 audio tracks stereo.
2xCanon C300 (MPEG-2 4:2:2 Long Gop), 2xCanon 5D (MOV H264), 3xSony (MPEG-2 4:2:2 Long Gop) and 1 BMPCC (ProRes 422)
My config:
I'm all yours to send you more stuff. I really need Adobe to correct this multicam problem ! My work is a nightmare actually
Thanks for your help !
30. Re: Fast playback (multicam) won't stop until end of timeline reached
noarprodz Nov 5, 2014 12:29 AM (in response to noarprodz)Hi guys. I tried something this morning that I didn't test so far. In my master sequence, I collapsed all tracks (to have no thumbnails, no waveform, etc.). The reactivity of my "stop" is much better and almost useable to edit a multicam (that's still not what I expect form a professionnal software but that's better...)
Hope this help to find out the cause of this bug.
