2 Replies Latest reply on May 16, 2014 12:49 AM by Silkrooster
    Select multiple layers
    gibbel
      Hello
      i want to select areas in two or more layers that have identical pixels in both (all) layers. For example if it is two black and white pictures aligned on top of each others i want to select the areas where there are black pixels in both.
      can i do that?
      /G
        • 1. Re: Select multiple layers
          Save and load the selection using the respective menu commands.
          MYlenium
          • 2. Re: Select multiple layers
            Silkrooster Adobe Community Professional & MVP
            Just a thought, heck I don't even know if it would work. But In theory or well...
            With two layers you could set the top layer to difference, then in the channels panel alt select or opt select the rgb thumbnail. That should select the differences then if necessary it is a simple matter to invert the selection.
            But the proper way besides what Mylenium mentioned, is to use the modifier keys to add, subtract, or  intersect selections.
            The beauty of the way Mylenium's method is if you make a mistake, you don't have much to do to reselect since it is saved for you and you can retrieve it any time as long as you save the file itself in a format that support alpha channels, such as psd or tiff.
