18 Replies Latest reply on May 17, 2014 5:57 AM by rob day
    Booklet printing to PDF results in white dotted lines around some placed images
    BoppyW Level 1
      Hi folks,
      I have come across an issue that is causing white dotted boxes to appear around some, but not all, images when I use the Print Booklet function and output to PDF. The boxes do not happen when I print to PDF without the booklet option. This leads me to believe there is some issue with the Acrobat version the Booklet function uses but I can't see any way to specify this in the Booklet print set up.
      I'm using Windows 8.1, ID CC and the images are PSDs with JPGs over the top and outlined text on a different layer. These are placed over a graduated coloured box which is on a different layer again.
      Is this something anyone knows how to work around?
      Thanks in advance for advice,
