Lose RTMP when I set up vhosts
CarphuntinGod May 16, 2014 7:01 AMPlease excuse the length and breadth of this post... but I've been working on this for a long time, trying to find out where I'm losing my rtmp in the process. I haven't found it... so you are seeing the long string of everything I'm doing currently to set up a new AMS 5.0 server to cross our old FMS 3.5 stuff to.
I'm trying to build on a server with three IPs and associated names. Names and IPs are in our DNS and properly associated
physicalserver.site.edu 999.999.999.001
vhost1live.site.edu 999.999.999.002
vhost2static.site.edu 999.999.999.003
I install AMS 5.
I then set Apache to listen to 80
Listen 80
# Listen 8134
I make sure AMS isn't listening on 80
ADAPTOR.HOSTPORT = :1935
I shut off proxy on 8134
HTTPPROXY.HOST =
in Adaptor.xml, I comment out the original hostport line and replace it with entries for my three IP's
<HostPort>999.999.999.001:1935,443</HostPort>
<HostPort>999.999.999.002:1935,443</HostPort>
<HostPort>999.999.999.003:1935,443</HostPort>
In Apache's httpd.conf, I set up vhosts
<VirtualHost 999.999.999.001>
ServerName physicalserver.site.edu
DocumentRoot "C:/Apache/physicalserver"
ErrorLog logs/physicalserver-error_log
TransferLog logs/physicalserver-access_log
</VirtualHost>
<VirtualHost 999.999.999.002>
ServerName vhost1live.site.edu
DocumentRoot "C:/Apache/vhost1live"
ErrorLog logs/vhost1live-error_log
TransferLog logs/vhost1live-access_log
</VirtualHost>
<VirtualHost 999.999.999.003>
ServerName vhost2static.site.edu
DocumentRoot "C:/Apache/vhost2static"
ErrorLog logs/vhost2static-error_log
TransferLog logs/vhost2static-access_log
</VirtualHost>
I also add the following to the httpd.conf
<Directory "C:/Apache/vhost2static">
Options -Indexes FollowSymLinks
AllowOverride None
Order allow,deny
Allow from all
</Directory>
<Directory "C:/Apache/physicalserver">
AllowOverride None
Order allow,deny
Allow from all
</Directory>
<Directory "C:/Apache/vhost1live">
AllowOverride None
Order allow,deny
Allow from all
</Directory>
In the AMS conf folder, within _defaultroot_, I dup the defaultvhost folder three times to create
vhost1live.site.edu
within those folders, i alter the vhost.xml file
I replace the default alias entry with the corresponding server
<Alias name=physicalserver"></Alias>
and the appsdir with
<AppsDir>C:\Apache\physicalserver\applications</AppsDir>
I have made three folders in c:/Apache, 1 to be the webroot of each of the servers
Into each of these folders, i copy the contents of the default installs webroot folder. I also copy in Applications. Finally, from the samples folder, I copy in the videoplayer folder.
Not going into great detail, inside this folder I try to alter the appropriate files so they all reference their own server (change localhost entries to vhost1live.site.edu, etc).
Since I know I'm setting up one vhost for Live work, and one for Static stuff, I've been changing these settings in AMS.ini
VOD_COMMON_DIR = C:\Apache\vhost2static.site.edu\vod
VOD_COMMON_DIR = C:\Apache\vhost2static\applications\vod\media
LIVE_DIR = C:\Apache\vhost1live\applications\live
In httpd.conf, i change the following
<Location /hds-live>
HttpStreamingEnabled true
HttpStreamingLiveEventPath "C:/Apache/vhost1live/applications"
HttpStreamingContentPath "C:/Apache/vhost1live/applications"
<Location /hls-live>
HLSHttpStreamingEnabled true
<Location /hls-vod>
HttpStreamingContentPath "C:/Apache/vhost2static/vod"
<Location /hds-vod>
When I have this done, and start the AMS and Apache services, I can generally have the index and videoplayer pages work. hds, http, and hls streaming will work (haven't tried a real live broadcast through it though...so not sure if inbound rtmp works).
BUT...the regular RTMP streams and RTMP via manifest files do not work.
Ideas?
