12 Replies Latest reply on Jun 18, 2014 1:40 PM by john worthington
    Photoshop CS6 on Mac OSX 10.9.3 NO longer working!
    ERICH.STAEDLER
      Since updating the iMac from OSX 10.9.2 to OS10.9.3 Photoshop CS6 is longer loading. Is there an update?
        • 1. Re: Photoshop CS6 on Mac OSX 10.9.3 NO longer working!
          Level 7
          We've been testing 10.9.3 for months and haven't seen any problems like that.
          What exactly do you mean by "longer loading"?
          • 2. Re: Photoshop CS6 on Mac OSX 10.9.3 NO longer working!
            ERICH.STAEDLER Level 1
            Dear Chris Cox
            thanks for your reply:
            Am 16.05.2014 um 22:43 schrieb Chris Cox <forums_noreply@adobe.com<mailto:forums_noreply@adobe.com>>:
            created by Chris Cox<https://forums.adobe.com/people/Chris+Cox> in Photoshop General Discussion - View the full discussion<https://forums.adobe.com/message/6385735#6385735>
            • 3. Re: Photoshop CS6 on Mac OSX 10.9.3 NO longer working!
              xwiredx Level 1
              Chris,
              Will Adobe be supporting/updating Photoshop CS6 past OS X 10.9.3?
              Thanks!
              • 4. Re: Photoshop CS6 on Mac OSX 10.9.3 NO longer working!
                jrlu
                I updated to Mac OSX 10.9.3 a few days ago and I have mid 2011 model 15" mbp. After updating, there have been problems with the Liquify filter. Before the update, it was working smoothly. Now it's very slow and laggy. I checked preferences > performance and my graphics card is check marked and drawing mode is set at "basic". How can I resolve this?
                • 5. Re: Photoshop CS6 on Mac OSX 10.9.3 NO longer working!
                  john worthington Adobe Employee
                  You are probably in CPU mode and not using the faster GPU mode. Press the control key *immediately* after starting Liquify and a dialog will appear telling you why Liquify is not using the GPU.
                  • 6. Re: Photoshop CS6 on Mac OSX 10.9.3 NO longer working!
                    jrlu Level 1
                    I did what you said and this is the dialog box that showed up:
                    Up until a week ago, my graphics processor was working great. I am guessing the update had something to do with it.
                    How would I switch out of CPU mode and get it back to using GPU mode? What would you recommend?
                    • 7. Re: Photoshop CS6 on Mac OSX 10.9.3 NO longer working!
                      Please copy and paste your Help->System Info here. It also will report the max texture size for your Mac. Usually this is a GPU hardware limit and should not change because of an OS update.
                      • 8. Re: Photoshop CS6 on Mac OSX 10.9.3 NO longer working!
                        jrlu Level 1
                        Here you go
                        Adobe Photoshop Version: 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00) x64
                        Operating System: Mac OS 10.9.3
                        System architecture: Intel CPU Family:6, Model:42, Stepping:7 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, HyperThreading
                        Physical processor count: 4
                        Logical processor count: 8
                        Processor speed: 2000 MHz
                        Built-in memory: 8192 MB
                        Free memory: 4146 MB
                        Memory available to Photoshop: 6816 MB
                        Memory used by Photoshop: 70 %
                        Image tile size: 1028K
                        Image cache levels: 4
                        OpenGL Drawing: Enabled.
                        OpenGL Drawing Mode: Basic
                        OpenGL Allow Normal Mode: True.
                        OpenGL Allow Advanced Mode: True.
                        OpenGL Allow Old GPUs: Not Detected.
                        OpenGL Version: 2.1 ATI-1.22.25
                        OpenCL Unavailable
                        Video Card Vendor: ATI Technologies Inc.
                        Video Card Renderer: ATI Radeon HD 6490M OpenGL Engine
                        Display: 2
                        Display Depth:= 32
                        Display Bounds:=  top: 22, left: 1440, bottom: 1080, right: 3360
                        Video Renderer ID: 16915207
                        Video Card Memory: 235 MB
                        Video Rect Texture Size: 16384
                        OpenCL Unavailable
                        Display: 1
                        Main Display
                        Display Depth:= 32
                        Display Bounds:=  top: 0, left: 0, bottom: 900, right: 1440
                        Serial number: 92299702664043361605
                        Application folder: Macintosh HD:Applications:Adobe Photoshop CS6:
                        Photoshop scratch has async I/O enabled
                        Scratch volume(s):
                          Macintosh HD, 465.0G, 148.0G free
                        Required Plug-ins folder: Macintosh HD:Applications:Adobe Photoshop CS6:Adobe Photoshop CS6.app:Contents:Required:
                        Primary Plug-ins folder: Macintosh HD:Applications:Adobe Photoshop CS6:Plug-ins:
                        Additional Plug-ins folder: not set
                        Installed components:
                           adbeape.framework   adbeape   3.3.8.19346   66.1025012
                           AdbeScriptUIFlex.framework   AdbeScriptUIFlex   6.2.29.18602   66.490082
                           adobe_caps.framework   adobe_caps   6.0.29.0   1.276181
                           AdobeACE.framework   AdobeACE   2.19.18.19243   66.492997
                           AdobeAGM.framework   AdobeAGM   4.26.17.19243   66.492997
                           AdobeAXE8SharedExpat.framework   AdobeAXE8SharedExpat   3.7.101.18636   66.26830
                           AdobeAXEDOMCore.framework   AdobeAXEDOMCore   3.7.101.18636   66.26830
                           AdobeBIB.framework   AdobeBIB   1.2.02.19243   66.492997
                           AdobeBIBUtils.framework   AdobeBIBUtils   1.1.01   66.492997
                           AdobeCoolType.framework   AdobeCoolType   5.10.31.19243   66.492997
                           AdobeCrashReporter.framework   AdobeCrashReporter   6.0.20120201
                           AdobeExtendScript.framework   AdobeExtendScript   4.2.12.18602   66.490082
                           AdobeJP2K.framework   AdobeJP2K   2.0.0.18562   66.236923
                           AdobeLinguistic.framework      17206
                           AdobeMPS.framework   AdobeMPS   5.8.0.19463   66.495174
                           AdobeOwl.framework   AdobeOwl   4.0.93   66.496052
                           AdobePDFL.framework   AdobePDFL   10.0.1.18562   66.419471
                           AdobePDFSettings.framework   AdobePDFSettings   1.4
                           AdobePIP.framework   AdobePIP   6.0.0.1654
                           AdobeScCore.framework   AdobeScCore   4.2.12.18602   66.490082
                           AdobeUpdater.framework   AdobeUpdater   6.0.0.1452   "52.338651"
                           AdobeXMP.framework   AdobeXMPCore   66.145661   66.145661
                           AdobeXMPFiles.framework   AdobeXMPFiles   66.145661   66.145661
                           AdobeXMPScript.framework   AdobeXMPScript   66.145661   66.145661
                           ahclient.framework   ahclient   1.7.0.56
                           aif_core.framework   AdobeAIF   3.0.00   62.490293
                           aif_ocl.framework   AdobeAIF   3.0.00   62.490293
                           aif_ogl.framework   AdobeAIF   3.0.00   62.490293
                           AlignmentLib.framework   xcode   1.0.0.1
                           amtlib.framework   amtlib   6.0.0.75
                           boost_date_time.framework   boost_date_time   6.0.0.0
                           boost_signals.framework   boost_signals   6.0.0.0
                           boost_system.framework   boost_system   6.0.0.0
                           boost_threads.framework   boost_threads   6.0.0.0
                           Cg.framework   NVIDIA Cg
                           CIT.framework   CIT   2.0.5.19287   145486
                           data_flow.framework   AdobeAIF   3.0.00   62.490293
                           dvaaudiodevice.framework   dvaaudiodevice   6.0.0.0
                           dvacore.framework   dvacore   6.0.0.0
                           dvamarshal.framework   dvamarshal   6.0.0.0
                           dvamediatypes.framework   dvamediatypes   6.0.0.0
                           dvaplayer.framework   dvaplayer   6.0.0.0
                           dvatransport.framework   dvatransport   6.0.0.0
                           dvaunittesting.framework   dvaunittesting   6.0.0.0
                           dynamiclink.framework   dynamiclink   6.0.0.0
                           FileInfo.framework   FileInfo   66.145433   66.145433
                           filter_graph.framework   AdobeAIF   3.0.00   62.490293
                           hydra_filters.framework   AdobeAIF   3.0.00   62.490293
                           ICUConverter.framework   ICUConverter   3.61   "gtlib_3.0" "." "16615"
                           ICUData.framework   ICUData   3.61   "gtlib_3.0" "." "16615"
                           image_compiler.framework   AdobeAIF   3.0.00   62.490293
                           image_flow.framework   AdobeAIF   3.0.00   62.490293
                           image_runtime.framework   AdobeAIF   3.0.00   62.490293
                           LogSession.framework   LogSession   2.1.2.1652
                           mediacoreif.framework   mediacoreif   6.0.0.0
                           PlugPlug.framework   PlugPlug   3.0.0.383
                           UpdaterNotifications.framework   UpdaterNotifications   6.0.0.24   "6.0.0.24"
                           wrservices.framework
                        Required plug-ins:
                           Accented Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Adaptive Wide Angle 13.0, Copyright © 2012 Adobe Systems Incorporated - from the file “Adaptive Wide Angle.plugin”
                           ADM 3.10x16, Copyright © 1987-2008 Adobe Systems Inc.  All rights reserved. - from the file “AdobeADM.bundle”
                           Angled Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Average 13.0 20120315.r.428 2012/03/15:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “Average.plugin”
                           Bas Relief 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           BMP 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Camera Raw 7.0 (308), Copyright © 2012 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
                           Chalk & Charcoal 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Chrome 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Cineon 13.0 20120315.r.428 2012/03/15:21:00:00  ©2002-2012 Adobe Systems Incorporated - from the file “Cineon.plugin”
                           Clouds 13.0 20120315.r.428 2012/03/15:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “Clouds.plugin”
                           Collada DAE 13.0 20120315.r.428 2012/03/15:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
                           Color Halftone 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Colored Pencil 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           CompuServe GIF 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Conté Crayon 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Craquelure 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Crop and Straighten Photos 13.0 20120315.r.428 2012/03/15:21:00:00  ©2003-2012 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
                           Crop and Straighten Photos Filter 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Crosshatch 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Crystallize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Cutout 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Dark Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           De-Interlace 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Difference Clouds 13.0 20120315.r.428 2012/03/15:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “Clouds.plugin”
                           Diffuse Glow 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Displace 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Dry Brush 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Eazel Acquire 13.0 20120315.r.428 2012/03/15:21:00:00  ©1997-2012 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
                           Embed Watermark NO VERSION - from the file “DigiSign.plugin”
                           Enable Async I/O 13.0 20120315.r.428 2012/03/15:21:00:00  © 2004-2012 Adobe Systems Incorporated - from the file “Enable Async IO.plugin”
                           Extrude 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           FastCore Routines 13.0 20120315.r.428 2012/03/15:21:00:00  ©1990-2012 Adobe Systems Incorporated - from the file “FastCore.plugin”
                           Fibers 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Film Grain 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Filter Gallery 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Fresco 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Glass 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Glowing Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Graphic Pen 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Halftone Pattern 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           HDRMergeUI 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
                           IFF Format 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Ink Outlines 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           JPEG 2000 13.0 20120315.r.428 2012/03/15:21:00:00  ©2001-2012 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
                           Lens Blur 13.0, Copyright © 2002-2012 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
                           Lens Correction 13.0, Copyright © 2002-2012 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
                           Lens Flare 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Liquify 13.0, Copyright © 2001-2012 Adobe Systems Incorporated - from the file “Liquify.plugin”
                           Matlab Operation 13.0 20120315.r.428 2012/03/15:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
                           Measurement Core 13.0 20120315.r.428 2012/03/15:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
                           Mezzotint 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           MMXCore Routines 13.0 20120315.r.428 2012/03/15:21:00:00  ©1990-2012 Adobe Systems Incorporated - from the file “MMXCore.plugin”
                           Mosaic Tiles 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Multiprocessor Support 13.0 20120315.r.428 2012/03/15:21:00:00  ©1990-2012 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
                           Neon Glow 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Note Paper 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           NTSC Colors 13.0 20120315.r.428 2012/03/15:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
                           Ocean Ripple 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Oil Paint 13.0, Copyright © 2011 Adobe Systems Incorporated - from the file “Oil Paint.plugin”
                           OpenEXR 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Paint Daubs 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Palette Knife 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Patchwork 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Paths to Illustrator 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           PCX 13.0 20120315.r.428 2012/03/15:21:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “PCX.plugin”
                           Photocopy 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Photoshop 3D Engine 13.0 20120315.r.428 2012/03/15:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
                           Picture Package Filter 13.0 20120315.r.428 2012/03/15:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
                           Pinch 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Pixar 13.0 20120315.r.428 2012/03/15:21:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “Pixar.plugin”
                           Plaster 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Plastic Wrap 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           PNG 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Pointillize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Polar Coordinates 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Portable Bit Map 13.0 20120315.r.428 2012/03/15:21:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “PBM.plugin”
                           Poster Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Radial Blur 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Radiance 13.0 20120315.r.428 2012/03/15:21:00:00  ©2003-2012 Adobe Systems Incorporated - from the file “Radiance.plugin”
                           Read Watermark NO VERSION - from the file “DigiRead.plugin”
                           Reticulation 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Ripple 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Rough Pastels 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Save for Web 13.0, Copyright © 1999-2012 Adobe Systems Incorporated - from the file “Save for Web.plugin”
                           ScriptingSupport 13.0, Copyright © 2012 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
                           Shear 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Smart Blur 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Smudge Stick 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Solarize 13.0 20120315.r.428 2012/03/15:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “Solarize.plugin”
                           Spatter 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Spherize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Sponge 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Sprayed Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Stained Glass 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Stamp 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Sumi-e 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Targa 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Texturizer 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Tiles 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Torn Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Twirl 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Underpainting 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Vanishing Point 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
                           Water Paper 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Watercolor 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Wave 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Wind 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Wireless Bitmap 13.0 20120315.r.428 2012/03/15:21:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “WBMP.plugin”
                           ZigZag 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                        Optional and third party plug-ins:
                           Subtle Patterns 12.0, Copyright © 2010 Adobe Systems Incorporated - from the file “SubtlePatternsPlugin.plugin”
                        Plug-ins that failed to load: NONE
                        Flash:
                           Subtle Patterns
                           Mini Bridge
                           Kuler
                        Installed TWAIN devices: NONE
                        • 9. Re: Photoshop CS6 on Mac OSX 10.9.3 NO longer working!
                          Level 7
                          Firstt, go install the Photoshop CS66 updates. You're still on 13.0.0.
                          • 10. Re: Photoshop CS6 on Mac OSX 10.9.3 NO longer working!
                            Your MBP may have two GPUs: a weaker lower power Intel GPU and a stronger higher power ATI GPU. Check in your Energy Saver Preferences and see if you have an "Automatic graphics switching" check box. If you have this please uncheck it and reboot. Then Launch Liquify with the control key and see if you still get the drop-back message.
                            • 11. Re: Photoshop CS6 on Mac OSX 10.9.3 NO longer working!
                              jrlu Level 1
                              I went to my energy saving preferences and found that "Automatic graphics switching" check box you mentioned. I unchecked it and rebooted and relaunched Liquify. The same message popped up.
                              this is what my performance settings are at currently:
                              • 12. Re: Photoshop CS6 on Mac OSX 10.9.3 NO longer working!
                                With OS10.9.3 your OpenGL video card driver is reporting Video Card Memory of 235 MB. Liquify requires a minimum of 256MB. It may be the newer OS is using up more of the video cards memory and reporting there is less available for applications like Photoshop.
