1 Reply Latest reply on May 12, 2007 8:49 PM by kglad
    Preloading Question
      Hi everyone,
      I am building a flash movie that will contain two "image" galleries. To keep initial load time down, I would like to load one gallery at startup and the other once a button is clicked. Does anyone know of an action script that can load certain library folders at different times?
      Thanks in advance,
        • 1. Re: Preloading Question
          if, by library folders, you mean folders that contain objects in your fla's library you can force flash to load objects when the playhead enters a frame other than 1, but not with actionscript.
          you can untick export in the first frame, and attach an instance of the object (off-stage if unneeded) to the frame you want. you must repeat this for each object you want to load with a frame other than 1.
